Old 09-01-2004, 04:18 AM   #1
dcwrx2
Member#: 69005
'04 4EAT Wgn
Default UP/DP combo w/ or w/o ECU mod?
For '04+ WRX, if one mod'ed with cat-less UP/DP only, and the other one mod'ed cat-less UP/DP + ECU, I'm sure there will be obvious difference at high-end power; but I'm wondering, how much difference in terms of the turbo spool up time at low RPM?
If I'm more concern on the low RPM driveability, is stock ECU good enough with UP/DP mods?
dcwrx2 is offline   Reply With Quote
Old 09-01-2004, 06:44 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
you should be ok. but to get all the benefits
from up/dp you should get some form of tuning.
guess it also depends on which up/dp.
but with no tune/chip/ecu my invidia tbe
would occassionally to strange things.
after the install of piggy-back unichip
the event did not reoccur.
disclaimer: depends on which up/dp..
Ben
Old 09-01-2004, 08:25 AM   #3
Daboro's Rex
Member#: 55915
04 WRX stage 1/2
Wr blue pearl
Hey jaxscuby what kinda strange things did it do. I am getting a PDE DP and a Invidia Catback. did you have the TI or just the SS. I heard that the TI would hit something on the bottom because it was so light that it just moved to much, but the SS was good.
Let me know what strange things you are talking about.
Thanks
CUrt
Daboro's Rex is offline   Reply With Quote
Fs:UR 44mm EWG UP/DP combo, APS 70mm, Borla Hush, 20g x2, SSAC TMIC, and more SnowMann Engine/Power/Exhaust 35 11-18-2007 02:24 AM
HKS up/dp or Perrin up/dp JCKing71 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-13-2006 12:54 AM
Ebay UP/DP combo or Megan UP/DP? WrXDrivR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-30-2006 01:54 AM
Stock ECU reflash for UP/DP combo mnrstrider Engine Management & Tuning 1 05-08-2006 04:12 PM
Just installed new UP/DP combo. w0rx4me Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-13-2005 09:12 PM
