Old 09-02-2004, 10:46 PM   #1
wrxited
Member#: 58289
Impreza WRX STi Just got my 2004 STI , need help with audio
Ok guys, I just got my 2004 WRX STI today, and I love it, but I'm going to need some tunes in here. So first of all, does this car have speakers at all, or just holes for them? And I'm looking for good sound inside the car, I don't want everybody and their mother to hear me, or add alot of weight to the car. All the help will be greatly appreciated.
wrxited is offline   Reply With Quote
Old 09-02-2004, 10:59 PM   #2
RemlapaN
Member#: 58251
2004 Sti
GT35R 530whp @ 27psi
there are no speakers in the doors, but the wires are there. Also, you cannot just mount a 6.5 or 5.25" speaker in the door, you need a subaru adapter. www.iaperformance.com has some.
Since it doesnt sound like you want to go totally nuts on the stereo, i would recommend a decent set of 6.5's up front, with a decent amount of bass. If this doesnt get you the amount of sound that you want, look into adding a subwoofer. Probably something like a JL 12W3, infinity kappa, or some other middle of the line sub.
An amp for your front speakers would be a good idea, but it is not necessary if you are budget conscious.
For speakers, infinity kappa's, mbquarts, focals are all good higher end choices.
If you want brand matching for everything, alpine type-r's are decent, and they make very good receivers as well.
RemlapaN is offline   Reply With Quote
Old 09-02-2004, 11:36 PM   #3
wrxited
Member#: 58289
thanks
Old 09-02-2004, 11:41 PM   #4
brunetmj
Member#: 8023
2004 2.5 RS
When you install the head unit remember to hook up the white wire on the car harness to pin out with power antenna wire from the head unit harness. This white wire provides power to the antenna amp. You wont get AM/FM reception unless you do.
brunetmj is offline   Reply With Quote
Old 09-03-2004, 01:19 AM   #5
wrxited
Member#: 58289
that's a good hint , thanks
Old 09-03-2004, 01:30 AM   #6
dithergizzard
Member#: 58232
As far as choosing the components of your system, I would suggest you not limit yourself to a small selection of products/brands and search around on this forum. The more threads you browse through, the more complete a picture you see of the diverse car audio market. Check other websites, too, such as those devoted entirely to car audio. And finally, make sure you listen to speakers/subs before you buy any: that is the only way to truly pick the ideal setup for your preferences.
DG
dithergizzard is offline   Reply With Quote
Old 09-03-2004, 07:42 AM   #7
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
DG
Agreed. And another way I suggest you look at this is the following. First decide if you are willing to use an external amplifier for your speakers or not. If not, then that can make a difference on what HU you choose. I would recommend one of the V-drive Alpine's to make sure you have a decent amount of power for the speakers. And using HU power on speakers can help shape the selection of what speakers work best off that amount of power. Also, if you don't want any subs I would go ahead and recommend running front and rear speakers (coaxials) as well. A couple of brands for a non-externally amplified systems are Alpine Type-S and Infinity Reference.
If you do decide to get an external amp, then the whole rest of the world opens up for you.
offset
offset is offline   Reply With Quote
Old 09-04-2004, 06:44 AM   #8
wrxited
Member#: 58289
Alpine Type-S and Infinity, how much do these run about? Price?
Old 09-04-2004, 08:51 AM   #9
mbraun20
Member#: 33235
2011 Subaru WRX
i had a alpince deck alpine type s speakers all around a alpine type 2 sub eclipse 5 cahnnel amp and i think it sounded awesome. and i too hate alot of bass
mbraun20 is offline   Reply With Quote
Old 09-04-2004, 09:12 AM   #10
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Looks like on eBay the ALPINE SPS-170A (6.5" front coax) and ALPINE SPS-130A (5.25" rear cox) are running about $60 after shipping each pair. Just do a search on the model names, but run through the auctions and see how has the most reasonable shipping. Sometimes you can find a vendor who sells both models and get a bit of a deal on shipping when buying two sets of speakers.
It looks like the Infinity run about $10 more or so than the Alpine. The model names are Infinity Reference 6002i and Infinity Reference 5002i.
Also, there is nothing wrong with these models on eBay typically as they are brand new in the box. I bought some Alpine Type-S coax for my wife (some day I will upgrade those for her, but they are really nice for now off just HU power), and they were absolutely fine.
offset
Old 09-04-2004, 09:16 AM   #11
jaypride
Member#: 33424
2004 STI
Blue/Gold
If you just want "something" then you could set a factory set up. They usually go cheap either here or on Ebay. With the upgraded speakers it sounds decent.
jaypride is offline   Reply With Quote
Old 09-04-2004, 11:15 AM   #12
wrxited
Member#: 58289
ok , I wan't stereo, but not stock, the stock stereo from factory that I had on my WRX 2004, sucked!! It sounded like tin cans, I don't want big heavy subs on the back of the car, but I do want good quality sound that I can hear inside the car.
Old 09-04-2004, 05:19 PM   #13
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
That was the draw for the Alpine Type-S for me as they seem to have pretty decent bass response on aftermarket HU power. It seems a lot of people had claimed that about them, and I agree that they do fairly well for the cost and amount of power used. Just remember though you will probably need some spacers, which you can make or have a local shape make or get some from IAPerformance.com.
offset
Old 09-15-2004, 07:14 PM   #14
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
brunetmj- you are a genius! i have been searching for that exact piece of information. i knew that had to be it but i wasnt sure which wire. thank you thank you.
adeliciouspizza is offline   Reply With Quote
Got my turbo kit, need help with voltage clamp :( qtr_wrx Normally Aspirated with bolt-on Forced Induction Powertrain 3 12-06-2009 04:11 AM
Just got a 2004 STI mardreracing Newbies & FAQs 1 11-18-2007 01:07 PM
Just got my 06 STi.. Just had my first accident ever. *pics* Drive_STIck General Community 50 06-20-2007 06:35 PM
Just got a 2004 STI.. Buffster19 General Community 20 06-23-2005 12:20 PM
Just got my 2004 WRX! WanganRunner Newbies & FAQs 4 01-09-2004 10:58 PM
