Old 10-21-2000, 08:49 PM   #1
JZ oo7
Member#: 2032
2000 Impreza 2.5 RS
Blue Ridge Pearl
Question UD Pulley + 400 watt rms
anyone having a UD pulley and running about 400 watt rms total through 2 amps without a cap, or 2nd battery? if so, do you experience a lot of dimming in the lights at night? thanks...i did a search, but i didn't find anyone with the same critira.
JZ
JZ oo7 is offline   Reply With Quote
Old 10-21-2000, 09:21 PM   #2
SIRS
Member#: 1758
Post
I too would like to know if anyone has had any problems with this since I am running 2x300 and 4x100.
SIRS is offline   Reply With Quote
Old 10-21-2000, 10:20 PM   #3
Nat
Member#: 759
2004 WRX
2000 SV650
Post
I have a Fosgate amp 50x4 and 100x1 and notice a little dimming at night with the UD pulley. The car does runa a little underpowered at idle, but as soon as you start moving at any speed the alternator cranks out enough juice (13.5+ V), so I am not worried. With everything on (wipers, heater, etc) the car will see just about 12V flat, but like I said as soon as you start moving it'll jump up to about 14V.
Nat is offline   Reply With Quote
Old 10-22-2000, 12:43 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
First off, I have the factory performance guage pack installed in my car. I have 2 amps, one running 350x1 RMS and another running 125x2 RMS. By my count, that makes 600 watts RMS.
Normal running power seems to be 14+ volts. Sitting idle with the lights on, I can see the voltage meeting from the performance guage pack thump with my subs, but it never goes lower than 13V. I can turn everything off, and just run the turn signal and it flickers down towards 12 volts.
I don't have a second battery or a cap yet, but can honestly say that I haven't had any problems with lights fadding or lower power than I normal with the URpulley. The big thing was it took a little longer than I would have liked for the AC to cool off. And that's a huge thing in Phoenix.
Hope this helps some.
kastle is offline   Reply With Quote
FS: Clarion 400 watt amp, Kenwood 1000 watt amp & more PowerTrip SCIC Private Classifieds 17 08-20-2009 03:58 PM
New in box: USAcoustics 400 watt RMS class D mono subwoofer amp rex n effect Private 'For Sale' Classifieds 13 10-25-2004 07:19 PM
FS: JBL P80.4 360-Watt RMS 4-Channel Power Amplifier kingrukus Canada Region Forum 1 04-11-2004 01:09 PM
UD pulley or light weight stock size pulley? Derres Catalano Normally Aspirated Powertrain 1 02-14-2001 01:56 AM
Pulley sizes for all models and the UD pulley MPREZYA Technical Forum Archive 0 08-14-2000 01:06 AM
