Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 09-04-2004, 04:50 PM   #1
o3burn
Member#: 67864
1985 GL 4dr
white
Question PVC Valve
I am going to replace the pvc valve. Where is it? 85 GL with ea85 engine.
-BTW Any Ideas about stalling and low idle speeds???
o3burn is offline   Reply With Quote
Old 09-04-2004, 05:04 PM   #2
silvershad0w
Member#: 54124
1988 Subaru RX, x3
White, White, Black
stalling and low idle speeds are a good sign of a vacuum leak. PCV valve could be the culprit. When replacing it, make sure you get a Subaru OEM part, the AutoZone/ aftermarket ones have been known to leak right of the box, causing a vacuum leak condition. On the turbo models I own, the PCV valve is on the intake manifold, but a carb car could be different. It should be fairly easy to find, just trace the large PCV hoses around until you see a suspicious part, pull off the hose look inside and see if it looks like a valve. 10 minutes or less of exploring with a flashlight and you should be set.
Be very careful of any plastic T's or parts on the PCV system, they do get brittle and will snap. A lot of times they are cracked and cause vacuum leaks, doing the 'blow test' on those parts is an easy way to check them (clean them up first) If all your vacuum lines are old and dry rotted, might as well replace those while your at it too. You can check vacuum lines with WD40 with the engine running, if you have a leak, it will suck in the wd40 and the idle will climb slightly.
(The engine designation is ea82)
silvershad0w is offline   Reply With Quote
Old 09-05-2004, 12:44 AM   #3
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
PCV Valve is on the back side in the center of the intake... below the carb on the back if you have one... or below the throttle body if its EFI. I agree, be sure to use a genuine subaru one. be careful with the hoses as the hose that goes to the PCV valve is like $8. May be more now because last time I broke mine was back in like 1999.
Flowmastered87GL is offline   Reply With Quote
bypass valve hardware ?? nolanator Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-02-2010 11:26 AM
2005 PVC valve and fuel filter not serviceable? drkwtsn Service & Maintenance 24 12-13-2008 10:50 AM
PVC support strength.. (didn't even use PVC!) Fish Off-Topic 17 04-02-2006 10:52 AM
Is there PVC Pipe Glue? Need to fix leaks in some PVC pipe. Cjchaps Off-Topic 14 12-28-2004 08:40 PM
Damn PVC valve! steve Vancouver Impreza Club Forum -- VIC 1 04-15-2003 03:21 PM
