Old 09-04-2004, 05:52 PM   #1
linux>windows
Member#: 49517
Default How the hell do you get the header bolts off
Ok, i was trying to figure out how to get the header bolts off, they're on there like cement, i am buying a new motor soon and want everything to go smoothly,
linux>windows is offline   Reply With Quote
Old 09-04-2004, 06:18 PM   #2
squeech
Member#: 38280
2000 2.5RS w/ EJ205
tuned @ teh Ghetto Garage
From the engine manifold or the cat?
I had more trouble removing the bolts at the cat flange than from the engine. The manifold nuts were quite tight from the factory, but I was able to pull them off with a simple 14mm socket and a 6 inch extension, and then by hand after a few turns. The bolts themselves are studs in the engine, and don't come off (but I'm sure you knew that )
If anything, you should really only need some WD-40 if they are rusted on or something.
squeech is offline   Reply With Quote
Old 09-04-2004, 07:14 PM   #3
kay95
Member#: 45494
95 impreza L awd
green
i snapped my cat to mid pipe bolts
and had to grind two of my header studs
kay95 is offline   Reply With Quote
Old 09-04-2004, 07:58 PM   #4
Defiantguy
Member#: 41268
2015 WRX
nothing a extension and a nice breaker bar couldn't handle.
Defiantguy is offline   Reply With Quote
Old 09-04-2004, 09:29 PM   #5
Rokan211
Member#: 66601
02 Impreza RS
i gave up after about 30 seconds, lubed it up with some wd 40 and busted out an air wrench at my uncles gurage
Rokan211 is offline   Reply With Quote
Old 09-04-2004, 10:34 PM   #6
rawrFERNY
Member#: 51517
2007 Outlander LS
i removed the headers to the end of the cat and then i placed it on the ground, positioned a wrench so i could stomp on it, and that worked.... might take a little longer but its the easiest way.
rawrFERNY is offline   Reply With Quote
Old 09-04-2004, 11:31 PM   #7
Blue98leg
Member#: 65036
2013 WRX
yeah i had the same problem my solution involved a steady hand and a plasma cutter. good luck
Blue98leg is offline   Reply With Quote
Old 09-04-2004, 11:34 PM   #8
linux>windows
Member#: 49517
thanks
Old 09-05-2004, 01:51 AM   #9
Member#: 54294
2001 *RIP*BRP 2.5 RS
use a socket wrench and put a crescent rench on the end so it forms and L and if the tools are good enough quality you can make enough torque to get them off.
2.5rsCoupe@dfw is offline   Reply With Quote
Old 09-07-2004, 02:39 PM   #10
Defiantguy
Member#: 41268
2015 WRX
its all about leverage people!
Old 09-07-2004, 03:03 PM   #11
chip4761
Member#: 55867
2005 Saabaru
AS
if your engine leaks enough oil, they come off real smooth
chip4761 is offline   Reply With Quote
Old 09-07-2004, 03:09 PM   #12
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
I didn't realize this thread was still going. I'll throw in my 2 cents. Use some liquid wrench spray, let it sit for at least a few hours, then come back and try the bolts with a good breaker bar, at least 2 feet. You should be able to pick up a breaker bar with a 1/2" driver at your local auto parts store for a few bucks. I've noticed hardware stores tend to charge more.
j
ilmaestro is offline   Reply With Quote
Old 09-07-2004, 04:11 PM   #13
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
Your statement about the studs is only half right. True, those studs are into the engine block, but they do come out. When I did my header all 6 studs came right out of the engine with the nuts still rusted in place. I ended up just replacing all 6 nuts and studs at the same time.
bigdweeb is offline   Reply With Quote
Old 09-20-2004, 11:47 PM   #14
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Get an electric impact wrench. You can find them cheap on the fly-by-night tool sites.
cjfike is offline   Reply With Quote
Old 09-21-2004, 10:01 AM   #15
BlackAndBlue
Member#: 40617
PB Blast4r is teh shiz
owns wd40 for takin off bolts
BlackAndBlue is offline   Reply With Quote
Old 09-21-2004, 12:38 PM   #16
Jejunum
Member#: 15773
2011 Impreza WRX
hey what size is are the bolts and nuts that go at the engine manifold -> header junction? im missing one (should i be worried about driving like this?)
Jejunum is offline   Reply With Quote
Old 09-21-2004, 01:02 PM   #17
Slack
Member#: 17548
Nuff said.
Mick
Slack is offline   Reply With Quote
Old 09-22-2004, 11:37 AM   #18
Reece
Member#: 18877
2015 WRX
couple months at the gym... if that doesn't work you can try steroids...
Reece is offline   Reply With Quote
How the hell do you change the rear defroster light? obyone Interior & Exterior Modification 6 05-07-2007 04:58 AM
How in the hell do you get bolts off?!? JayD707 Newbies & FAQs 29 10-04-2004 10:11 AM
How in the devil do you get the DEFI EGT probe to stay attached to the NPT fitting? BoostdBoxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-02-2004 12:29 PM
How the hell do you get rid of toenail fungus? BrysImpreza Off-Topic 18 11-26-2003 11:55 PM
Once struts are off how the hell do you get them back on? spshultz Brakes, Steering & Suspension 10 07-03-2002 12:39 AM
