Old 09-04-2004, 06:30 PM   #1
SeaRex
Member#: 31034
2003 WRX Wagon
Default spark plug gap NGK Iridium plugs?
Hi,
What gap should I use for my stock WRX using NGK Iridium spark plugs--BKR6E-IX (stock heat range)?
Is it 0.030"?
Sean
SeaRex is offline   Reply With Quote
Old 09-04-2004, 06:34 PM   #2
seattle944t
Member#: 18308
2005 WRX STi
You shouldn't need to re-gap Iriduim plugs, they come with a different gap that is set for the application and the Iriduim electrode.
http://www.densoiridium.com/sparkplugspecs.php
EDIT: Forgot this link:
http://www.densoiridium.com/faq.php
seattle944t is offline   Reply With Quote
Old 09-04-2004, 08:40 PM   #3
SeaRex
Member#: 31034
2003 WRX Wagon
NGK says (for 2002 WRXes, they don't list 2003s) that the OEM gap is 0.030. I assume it's good to stay right there then? http://www.ngk.com/results_app.asp?AAIA=1378773 and http://www.ngksparkplugs.com/apps/ca...60000&country=
Cheers,
Sean
Old 09-07-2004, 08:38 PM   #4
SeaRex
Member#: 31034
2003 WRX Wagon
Ran into trouble today ... found out there are 2 NGK Iridiums in the stock heat range, "BKR6EIX" and "wide-gap" "BKR6EIX-11."
Which should I use on a stock motor and what ought my gap be?
Thanks,
Sean
Old 09-07-2004, 08:46 PM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Thanks,
Sean
The -11 is for NA applications....do NOT USE them in the WRX.
If you dedeide to up the boost, you may wish to go to a colder heat range plug---"xxx7xxx" plug and gapped a bit tighter....026"-.028".
Iridium plugs CAN be 'gapped', but extreme care must be used to accomplish it properly.
Old 09-08-2004, 12:58 PM   #6
SeaRex
Member#: 31034
2003 WRX Wagon
Thanks!
So if I use the non "-11" and a gap of 0.030, I should be fine, right? (I need brakes and tyres and still a knock sensor, so it looks like my plan for an Access Port is put off for another year.)
Cheers,
Sean
Old 09-08-2004, 01:15 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Thanks!
Yes....although unless you have over 60k miles on the stock plugs, they should be good.
The plugs you get should be pre-gapped.....check them BUT....be VERY-VERY careful with the tip of the center electrode!!!!! the very end of the tip is ***EXTREMELY*** easy to break off!!! and/or the center electrode can be snapped off at the ceramic.....BAD JUJU!!!
..... ask me how I know these things .........
THIS is why it is NOT a good idea for someone to try to 'gap' iridium plugs unless you know the possible pitfalls and how to avoid them
Old 09-08-2004, 01:32 PM   #8
SeaRex
Member#: 31034
2003 WRX Wagon
Thanks!
My '03 WRX wagon has about 57,000 on it. Thanks for the advice! (Getting those Iridium NGK plugs isn't easy, btw.)
Cheers,
Sean
Old 09-11-2004, 12:46 PM   #9
SeaRex
Member#: 31034
2003 WRX Wagon
Okay, got the plugs. Hopefully will find time around soccer tomorrow to install them.
One question: the plugs have a washer on them. Am I correct in assuming I leave it on?
Cheers,
Sean
(P.S. I just got "approval" for Pirelli PZero Nero M+S tires and Hawk HPS pads!! I'll be calling TireRack Monday <very very big grin>.
Old 09-11-2004, 05:21 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Yes, the washer is installed....15ft-lbs on the plugs .....and DON'T cross thread them
.....order the SS brake lines, too.....she'll never know
Old 09-11-2004, 11:18 PM   #11
SeaRex
Member#: 31034
2003 WRX Wagon
Hehe.
Am going to use anti-seize, should I go 10lbs on the plugs if I do?
I already have braided steel brake lines and superblue fluid <g>.
Cheers,
Sean
Old 09-12-2004, 02:34 AM   #12
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
If you use anti-seize, use it VERY sparingly....and DO NOT get ANY on anything but the threads.....do NOT use any anti-seize that contains graphite !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
IMO, properly torqued plugs should not need anti-seize unless the vehicle is used where the roads are salted in the winter or if the vehicle is used in some sort of severe service/environment.
Old 09-12-2004, 05:11 PM   #13
SeaRex
Member#: 31034
2003 WRX Wagon
Almost. Then I gave up. I got everything out of the way in short order. Then, I got the driver-side electrodes out.
But, I never tackled the plugs.
The radiator-side plug on the driver side I could get to. The firewall-side plug would have been next to impossible. The plug hole is below the level of the shelf that the washer bottle sits on. I had two universal joints and adapters for my torque wrench, but there was no way I'd have been able to get in and out of that firewall-side plug hole, not and be confident of not cross-threading etc.
=8?(
Did Subaru install those when the engine was out of the bay?
Looks like I have to pay someone to install those. Sigh. The passenger side plugs seemed easier to access.
Everything went back fine, the whole remove and reinstall took an hour.
Cheers,
Sean
Old 09-12-2004, 09:05 PM   #14
Amazake
Member#: 9889
sea rex
use a 3" extension and a small rachet
start with the socket facing you just past the slot for the plug ( ratchet towards glass ) and then turn the socket towards you and the hole for the plug you have to lift up a bit while turning to get it in there
then just give a nice squeeze to break it loose
once it is broken just remove ratchet leaving the socket on the plug and spin the plug out by hand
if you are worried about cross theading install the plug by hand
it will feel very unnatural if you are cross threading the plug
as far a torque just try to remmber how much forse it was to take themoff then attempt to replicate that.
if you went in CT I would gladly give you a hand
Amazake is offline   Reply With Quote
Old 09-12-2004, 09:49 PM   #15
SeaRex
Member#: 31034
2003 WRX Wagon
Thanks.
Part of the problem is that my torque wrench is 1/2-in drive, no way I'm getting that in there ... even with universal joints and extensions.
Thanks for the suggestion, though.
Cheers,
Sean
NGK iridium plugs - questions between types Siper2 Normally Aspirated Powertrain 5 06-20-2006 09:19 PM
Spark Plug Gap: NGK Iridium markreda Factory 2.0L Turbo Powertrain 5 11-13-2005 06:07 AM
Gapping an Iridium plug QwikRex Factory 2.0L Turbo Powertrain 7 04-23-2004 03:06 PM
Denso Iridium vs. NGK Iridium plugs? Thai Silk Factory 2.0L Turbo Powertrain 5 03-14-2004 03:22 PM
Are Denso or NGK Iridium plugs worth getting? SubaruWRC Normally Aspirated Powertrain 7 12-17-2002 02:30 AM
Message Board Statistics All times are GMT -4. The time now is 02:39 AM.
