Old 09-07-2004, 01:03 PM   #1
trustWRX
Member#: 40431
2009 Scion XB
Default K&N panel filter vs Paper factory Air filter
Any of you guys running these? If so, any difference at all? Spool time, throttle response?
Ive read about the oil getting into the MAF but is that due to normal oiling or over-oiling the filter to begin with?
trustWRX is offline   Reply With Quote
Old 09-07-2004, 01:14 PM   #2
Alizarin
Member#: 53769
2004 WRX JDM STi v8
IAM = 0 FTL :(
I put one in my 04 about 3 weeks after I first got the car. I noticed a slightly deeper exhaust note and some more low-end grunt off the line. I think overall it was a worthwhile mod. Haven't checked the MAF, but it's about time for the filter's first cleaning so I'll make sure to check it out.
BTW, for those that have them, how often do you clean/reoil it?
Alizarin is offline   Reply With Quote
Old 09-07-2004, 03:02 PM   #3
sonicblue
Member#: 25227
2012 Escape
If you can feel the difference from a K&N, you're in the top 0.00000000001% of auto mechanics! As much as they may claim performance gain, I can't imagine it's tangible. IMO, you buy a K&N because they're economically better deals than paper filters, not because they'll "do" anything that those other filters won't. I've driven 3 cars right after putting in a K&N and heck if I can tell......
Alizarin - it's about time for it's first "real" cleaning? How much do you drive? Shouldn't need to be cleaned until 50K miles! Prior to that, you can just remove it, bang out any big particles and replace.
sonicblue is offline   Reply With Quote
Old 09-07-2004, 03:22 PM   #4
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Thumbs up
After hearing about all MAF isssues w/ K&N I opted for a "Green" brand hi-flow filter (non oil/pleated paper-cloth). I had been running K&N on 3 other vehicles over ~10 years, but not this time. The Green provided notable improvement in both spool up time (~300 rmp less)and smoother pulling from 3000 to 4500rpm in my '04 WRX (5,900k). No other intake mods on the car, only a cat-back exhaust. The filter is very worth wild in my book, it works!!! Who knows or cares about expectancy, its the cost of two fill ups. I only have 1K on it, but, so far its all good.
N
REDrum is offline   Reply With Quote
Old 09-07-2004, 03:33 PM   #5
peterex
Member#: 27021
2015 WRX
300 rpms off your spool time with just an air filter? Did the air filter box also have an uppipe in it?
peterex is online now   Reply With Quote
Old 09-07-2004, 04:24 PM   #6
hondaeater69
Member#: 60324
I agree, you will see no NOTICEABLE difference with a high flow air filter. I think it becomes more important as you increase the horses around it. They've proven it to flow more air, so when you when you start upgrading things and need more air, you need that extra air you get out of a high flow filter. Air filters that are less efficient will become less efficient my magnitudes once you start increasing horse power and the need for more air. Stock I would imagine it really does nothing more but save you a few bucks in the long run.
So, on a stage 4 car, I would say do a test with a highflow and then switch it back to an OEM style, and see if there a restriction there, i would imagine there will be one, however small it will be. I'm sure someone has done this before, no?
paper cone air filters with 5" ID? nhluhr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-02-2005 02:51 AM
Factory Air Filter jonney_boy Service & Maintenance 6 09-19-2004 11:04 PM
pinholes in my paper element air filter bigpaulo Service & Maintenance 1 11-07-2003 04:06 PM
K&N Typhoon Intake Vs. AEM Cold Air Intake? SCCARacr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-12-2003 11:26 PM
Oil and oil filter? Spark plugs and air filter? TimCat General Forum Archive 5 01-18-2001 11:27 PM
