Old 09-07-2004, 03:45 PM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default EJ18 ECU into EJ22 ECU harness
I just picked up a EJ18 ECU and was wanting to put it into my MY99 EJ22 harness. I'm just experimenting right now but before I put it in, I was wondering what kind of things might happen.
One of my guess is that it may throw a CEL or two.... It may or maynot run better.... etc.
Any guesses or hints or "you should not change ECU" replies?
FuJi K is offline   Reply With Quote
Old 09-07-2004, 07:17 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
why do you want to do this? Just for shiats and giggles?
If it ain't broke....don't fix it.
Is the Ej18 ECU you picked up OBD2 or OBD1?
Legacy777 is offline   Reply With Quote
Old 09-07-2004, 11:40 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
yea it's just an experiment.
The ECU is off of a MY93 automatic FWD, so my guess is it may throw a CEL somewhere.
Old 09-08-2004, 05:36 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I would go with that one.
Old 09-08-2004, 05:08 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
There are going to be a number of wires from your OBD-II car that won't be read by that OBD-I ECU. A large number of the pin placements are the same, but there are some that would need to be moved to run properly off of the 1.8l ECU. But as has been said, what is the point of this little operation???
Old 09-08-2004, 06:15 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I was wondering how the car would run with this ECU. I was in search for a knock sensor off a MY90-MY93 legacy for my car because I figured that those knock sensors would still be in good condition. I just happen to run into an MY93 Impreza so I figured I might as well take some stuff off of it. So I grabbed the ECU.
I'm really debating if I should plug it in or not... I may be able to go faster without that speed limiter that I have with my stock ECU....just testing...
Old 09-08-2004, 11:55 PM   #7
Legacy777
Member#: 4800
if it's obd1.....the connectors won't even work.....
anyone repinned a obd1 ej18 ecu plugs to work with obd1 ej22 ecu mellow65 Subaru Conversions 0 03-18-2009 09:50 PM
Would 93 ej22 ecu work on 93 ej18? maxim Subaru Conversions 4 10-26-2004 05:20 PM
ej25 ecu into ej22 stock turbocolin Subaru Conversions 1 11-21-2003 01:13 AM
ej25 ecu into ej22 turbocolin Engine Management & Tuning 0 11-20-2003 03:56 PM
Splicen and dicen a 93 ecu into a 96 harness ?'s serious Engine Management & Tuning 0 01-27-2003 09:24 PM
