Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 09-08-2004, 10:54 AM   #1
Carlos Fandango
Member#: 16206
Default can someone confirm the ratios of the 05 sti 6 speed?
am looking at importing one of these boxes from over there complete with dccd.
I am told that they do under 3k rpm at 70mph which is roughly what i am looking for.
Am hoping someone out there can confirm this, or even better, if you have the actual ratios, it would be a big help!
thanks in advance.
Carlos.
Carlos Fandango is offline   Reply With Quote
Old 09-08-2004, 12:10 PM   #2
Hye-Teck
Member#: 46087
i'll take a pic of my dash while in motion today and show u speeds while in different gears.
Hye-Teck is offline   Reply With Quote
Old 09-08-2004, 12:11 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
1st: 3.636
2nd: 2.375
3rd: 1.761
4th:1.346
5th:0.971
6th: 0.756
reverse: 3.545
Final: 3.90
70 mph should be ~ 2800 rpm in 6th gear.
mbiker97 is offline   Reply With Quote
Old 09-08-2004, 12:24 PM   #4
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
mbiker the ratio's you just named are the USDM ratio's. Carlos said he was going to be importing one so I'm assuming he meant JDM
Here is the JDM ratio's.
1st: 3.636
2nd: 2.375
3rd: 1.761
4th: 1.346
5th: 1.062
6th: 0.842
70mph in 6th should be about 3100 RPM if I remember right from last time I was in my car.
MustGoFast is offline   Reply With Quote
Old 09-08-2004, 12:29 PM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Since Carlos said "over there" I assumed he was importing a USDM tranny, much like guys import our short block. Good info nontheless.
Old 09-08-2004, 05:00 PM   #6
Hye-Teck
Member#: 46087
well since u have all the info needed, i don't think u need pictures now
Old 09-09-2004, 07:07 AM   #7
Carlos Fandango
Member#: 16206
thanks guys, you are spot on.
I am in fact in the UK and was going to bring in a USDM 6MT from the states.
To set things straight, I need a gearbox which might be able to handle 500+lbft from 3000rpm. Trouble is with that much torque I want the gears to be spread over >200mph (with a 7500rpm redline). Your 6 speed seems to have better gearing than the 6 speed from japan and the UK (longer 5th and 6th only) but is still shorter than my 5 speed which is of course spread over only 5 gears, hence using the torque more which is what I wanted to do.
I was told the 05 sti had longer gears than previous models, but until now was not aware of the ratios
The one I am really keen to see is the forester sti as I believe 8k rpm in 6th in that is around 217mph. I appreciate that I won't get anywhere near there but the top speed of the box is a good indication of how well it is spread over the gears.
My current fifth is a 0.738 with a 3.9 final drive, so is longer, but there is no guarantee that it can take it. I know the same can be said for the 6mt but at least the gears are that much bigger, as is the casing, and it is still a pleasant synchro box.
But if I have a theoretical 200mph, I would rather that it were spread over 5 gears than 6, else with 500lbft I will be forever reaching for the next gear.
Info is very much appreciate, but does anyone know how it compares the the forester six speed?
I suspect that may be the better bet.
05 STI 6 Speed, 3 Used VF39s, Brembos... WorldOne NWIC Vendor Classifieds 11 11-17-2012 11:43 AM
New 05 sti 6 speed shifter assembly gingertooth Drivetrain 6 05-02-2007 03:13 AM
OEM 05 Sti 6 speed shift knob wrxxed Private 'Wanted' Classifieds 2 03-23-2005 09:42 PM
SPT short throw shifter for 04/05 STi 6-speed tranny JDM addict Private 'For Sale' Classifieds 28 09-17-2004 02:53 PM
Can someone confirm/deny rumors of aluminum bits on the 92X BIGSKYWRX Brakes, Steering & Suspension 0 07-03-2004 04:12 PM
