Old 09-08-2004, 05:59 PM   #1
DieselClown
Member#: 36135
2005 WRX
Default will SSR comps that fit an 03 fit on an 05 wrx?
Just curious before I commit. They are 225/40/18. If I get Eibach Prokits, will they fit no problem?
Thanks.
Steve
DieselClown is offline   Reply With Quote
Old 09-08-2004, 06:29 PM   #2
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Yes, they both have the same bolt pattern.
dbrier is offline   Reply With Quote
Old 09-08-2004, 07:00 PM   #3
DieselClown
Member#: 36135
2005 WRX
shoot, i didnt even realize it typing it but will the 225/40/18 be a little on the thin side? Not only do I hate how thin sidewalls look, I drive into the city often and potholes are everywhere. I'm generally very careful but if it's thin then I'll probably throw on new tires when I get them. What's the highest sidewall tire I can throw onto these rims with an Eibach Prokit drop on the 05 rex?
Old 09-08-2004, 09:00 PM   #4
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
Well if you up the Side wall you'll throw off your speedo, but you may be able to squeeze 45/18's under the fenders but that'll be cutting it close. If you stay with the 225/40/18 you'll fit ok. Its almost the same size as a 225/45/17 which I have with a 1.5" drop in front and 1" drop in back.
Just checked a 225/45/17 has an overall diamater of 25" while a 225/40/18 is 25.1" so it'll fit just fine. Any bigger and you might run into issues. Good Luck!
NWWagon is offline   Reply With Quote
Old 09-08-2004, 09:23 PM   #5
imprezavness
Member#: 59563
2004 white WRX
confused
wait are you guys just talking about tires cuz your post said ssr comps so please remember that 05 wrx come with 5x114.3, not the normal 02-04 5x100
imprezavness is offline   Reply With Quote
Old 09-08-2004, 09:33 PM   #6
BillJC
Member#: 31002
I thought only the 05 STI's had the bigger bolt pattern? The bolt pattern of the 05's looked the same as the 02-04's at my local dealer.
BillJC is offline   Reply With Quote
Old 09-08-2004, 10:30 PM   #7
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Wrong
Originally Posted by BillJC
I thought only the 05 STI's had the bigger bolt pattern? The bolt pattern of the 05 WRX looked the same as the 02-04's at my local dealer.
Correct
Only the 05 STi has the larger bolt pattern
Old 09-08-2004, 10:39 PM   #8
DieselClown
Member#: 36135
2005 WRX
sorry, i was curious if ssr comps in 18x8 that was previously on an 03 wrx with kuhmo 712's in 225/40/18 will fit on an 05 wrx with eibach prokits. I realize now that 225/40/18 is actually the perfect size to be as close as stock correct? Anyway, if they fit then I'm golden but if the ride isn't as good, then I might think about a softer tire. I don't know. Either way, 18's on NYC roads might not be the best idea but I'll think about this one. Thanks for the help.
Old 09-09-2004, 09:23 AM   #9
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
yes they will fit a 2005 WRX but, not a 2005 STi
Old 09-10-2004, 06:46 PM   #10
DieselClown
Member#: 36135
2005 WRX
thanks for the confimation luke. One last question, do u guys sell the actual stickers that come with the wheels? I plan on painting them bronze but I really like how they looked with the SSR logo on the spoke. Thanks.
Steve
Will 06 WRX Front and Rear Calipers fit on my 05 WRX? mrtrex Brakes, Steering & Suspension 2 01-06-2006 09:04 PM
Just put on an STi exhust on my 05 wrx and it sounds... darksands Factory 2.0L Turbo Powertrain 8 07-06-2005 02:02 PM
When will SSR comps be out in 17x8.5 for an 05 STi? Got Pink? Tire & Wheel 5 12-08-2004 11:53 AM
Will Forge BOV that is a direct fit for factory intercooler fit on STI intercooler? NYC TURBO Factory 2.0L Turbo Powertrain 5 11-30-2002 12:34 AM
SSR Comp. width, tire size and fit...... Red Rocket Brakes, Steering & Suspension 0 12-05-2001 05:16 PM
Message Board Statistics All times are GMT -4. The time now is 08:24 PM.
