#1 |
Vendor
Vendor Sales Rating: (2)
Member#: 41426
South East
We have completed the first stage of testing with fitting the 2005 Turbo Legacy brakes onto a 2002 WRX. Currently we are running the front 12.4" setup only, but will have the rear vented setup on by this weekend!
![]() Below is a link to photos of the test fit and final install. 2005 Legacy Turbo Brake Upgrade 17" or larger wheels are required for these brakes. These kits will bolt up to any year WRX, Impreza or Legacy, as long as you are on 17" or larger wheels! The specs: Stock 2005 Turbo Legacy Front Brakes 12.4" Rotors, Thicker than stock WRX More Rotor Surface used than stock WRX 2 piston caliper (larger than stock wrx caliper) Larger Pad Surface Current Kits with Stock Pads - Bobcats are on the way! Stock 2005 Turbo Legacy Rear Brakes Vented Rear Rotors *other specs to come 9/13* Kit 1: Fronts - Ready to ship now! $650 shipped LH + RH OE Front Rotors - 12.4" LH + RH Front Brake Calipers w/brackets OE Subaru Front Brake Pads w/full hardware kit Kit 2: Rears - Ready to ship now! $550 shipped LH + RH OE Rear Rotors - Vented 11.4" LH + RH Rear Brake Calipers w/brackets OE Subaru Rear Brake Pads w/full hardware kit Kit 3: Fronts & Rears - Ready to ship now! $1150 shipped LH + RH OE Front Rotors - 12.4" LH + RH Front Brake Calipers w/brackets OE Subaru Front Brake Pads w/full hardware kit LH + RH OE Rear Rotors - Vented LH + RH Rear Brake Calipers w/brackets OE Subaru Rear Brake Pads w/full hardware kit We are expecting Carbotech pads in very near future for both the fronts & rears and kits with those will be added as they are available. Folger Subaru Steven Rankins - parts@folgerautomotive.com (to order)
#4 | |
Vendor
Member#: 41426
South East
![]() Steven |
#6 |
Guest
Member#:
yank yo teethies out stopping power!!
#8 | |
Vendor
Member#: 41426
South East
![]() Steven |
#9 |
Member#: 30440
South East
Vehicle:03 WRX WR Blue |
Nice work. They certainly look nice.
Stopping power is still more dependent on your tires. Are these sliding calipers like the OEM WRX brakes? How would you rate these against the STi (non-Brembo) 4-pot set-up? Pads for that upgrade are significantly cheaper than most upgrade set-ups. Any idea on cost for Legacy pads? |
#10 |
Member Sales Rating: (2)
Member#: 51280
South East
Vehicle:06 VF-39 is good |
IIRC they are floating calipers front and rear....fixed calipers (like the 4 pots) 'feel' better as a result of less compliance in the system.
The whole rear brake looks just like the old turbo legacy but is bigger in diameter. |
#12 | |
Vendor
Member#: 41426
South East
![]() Steven |
#14 |
Member Sales Rating: (9)
Member#: 5583
BAIC
Vehicle:96' Ver.2 Wagon White |
Nice! Finaly. I have been asking and wondering about this for some time. Glad you took the initiative and are figuring this out. I'll be waiting on the rear info as I am in the same boat as InfamousDX. I was going to do H6's but I will definately wait to see how this pans out.
#15 |
Member Sales Rating: (4)
Member#: 2127
RMIC
Vehicle:09 STi dgm Cobb Stage 2 |
How does the front 12.4" 2 pot legacy set-up compare to the subaru 4-pot front set-up. For the price you can get the 4 pots for less, but is there are big difference performance wise with the turbo legacy set-up?
Thanks |
#16 |
Member Sales Rating: (43)
Member#: 36838
Vehicle:2000 RS Sedan 2004 STi w/RS body swap |
The legacy setup has larger diameter rotors (as they require 17in wheels). Larger rotors with more mass, so better brake modulation along with more mass to absorb heat when driving hard, reducing brake fade.
I'd also wager to say that the 2-pot setup has more brake torque than the 4-pots, as the WRX 2-pot calipers have more brake torque than the 4-pots. It would be equivalent to a cheaper BBK alternative for the WRX. These would probably make a mean Auto-x setup...lighter weight than a stoptech or brembo setup. Would give you the same brake modulation as a BBK and better fade resistance than a stock setup. And I'll say it again, BBK's don't make you stop faster. They just absorb/dissipate more heat than stock setups allowing for more repeated stops w/o brake fade. I'd drop my 4-pots in a sec for this if I didn't want to stay on 16in wheels. -- Dave |
#17 |
Member Sales Rating: (7)
Member#: 5673
Vehicle:2002 WRX/2005 LGT 09 Ducati M696/ZX6R |
Can I use the same brake lines?
Can I reuse the speed bleeders from my WRX calipers? Does the thicker rotors mean you're changing the wheel offset too? Last edited by bemani; 09-09-2004 at 04:51 PM. |
#18 |
Member#: 39366
Vehicle:2003 Impreza 2.5RS Midnight Black Pearl |
at that price you can piece together a better aftermarket setup, what are the advantages of getting these installed? I am confused, $700 just for fronts you can roll some deep stopping power aftermarket, rotors, pads, ss lines, and ahve money left over for a caliper paint kit :-)
#19 | |
Vendor
Member#: 41426
South East
Steven |
#21 |
Member#: 19502
South East
Vehicle:2010 Impreza with no scoop. =( |
Having personally driven several cars with different brake setups I can honestly say that this is one of the best bang for the buck setups out there. Steven gave me a ride in the car and it just plain stops. There isn't an aftermarket setup out there for that price that can even come close. We're talking 12.4" rotors with calipers and pads.... I'd love to see a setup that can touch that price.
#22 | |
Vendor
Member#: 41426
South East
Speed Bleeders, maybe (I will post which size bleeders you will need. Some cars use small front, big rear, some use the oposite, and still some even different. lol...) Offset change. I don't belive so. The hats appear to be the same thickness. If there is a change it is very minimal. I will measure the hats this weekend. Steven |
#23 | |
Vendor
Member#: 41426
South East
![]() (maybe an extra discount on your order for all of your help keeping up with the questions. )Steven |
#24 |
Vendor
Member#: 41426
South East
And finally:
I have had a few minutes to review all of the prices on the fronts & rears. It looks like we will be able to do the Fronts for $650 shipped, the rears for $550 shipped and the full setup for $1150 shipped!! I have also taken a measurement on the rear vented rotors, and updated that in the original post (11.4"). Bobcats are still a little ways out, however I would still recomend this kit with the stock pads, if you just can't wait! We will be able to get factory shims for the bobcats, they are included with the stock pads. For those wondering how much bobcats will add to this kit, you can figure ~$50-75 per end (front/rear).Keep the comments rolling! ![]() Steven |
#25 |
Member#: 5583
BAIC
Nice! $550 for the rears is a great alternative to trying to convert to rear Brembo's, for those of us who who have the fronts and are looking for a little better front/rear bias.
| Thread Tools | |
| Display Modes | |
| 93 Turbo Legacy Brake Kit | Joynt93 | VIC Private Classifieds | 5 | 10-12-2009 02:18 AM |
| FS: Turbo Legacy Brakes | blackbart | Private 'For Sale' Classifieds | 0 | 10-31-2005 12:29 AM |
| OK who knows the scoop on the 05 turbo legacy 5 speed tranny? | blackie | Transmission (AT/MT) & Driveline | 0 | 11-06-2004 02:58 PM |
| Turbo Legacy brakes | Robin | Legacy Forum | 3 | 07-10-2002 10:21 AM |
