Old 09-10-2004, 01:36 AM   #1
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
Default New 2.5l STi shortblock with 2.0l WRX heads?
Will the new 2.5l STi block work with 2.0l WRX heads? Anything I need to know to about accessories to make this work or is it a direct replacement? Any info would be great.
neversatisfied is offline   Reply With Quote
Old 09-10-2004, 02:05 AM   #2
dothespeedlimit
Member#: 55980
car. car!
car?
yes it will work and yes the shortblock is a direct swap.
dothespeedlimit is offline   Reply With Quote
Old 09-10-2004, 08:22 AM   #3
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
I've put together two of them in the past 6 months (Speedy Gp, 2point5literwrx) Speedy's has the USDM Sti cams in it too!!! You'll need the Sti head gaskets though. Don't forget to cap off the extra breather on the top of the block near the back of the block.
Jose
Pacobeagle is offline   Reply With Quote
Old 09-10-2004, 08:39 AM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
It is a direct swap like Pacobeagle1 said. The one thing that stumped me for a while was an extra vacuum line on the Tumble generator valve on the drivers side. It turns out that the line does not connect to anything (at least on an 02).
LiquidForce is offline   Reply With Quote
Old 09-10-2004, 10:51 AM   #5
Davenow
Member#: 23676
Jose
and how does it run with stock WRX heads and cams?
WHats the change like?
Old 09-10-2004, 12:53 PM   #6
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
Yeah, what he said.
As I am also considering this swap.
RALLYT-WRX is offline   Reply With Quote
Old 09-10-2004, 12:58 PM   #7
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Well, 2point5literwrx's motor is still breaking in. I finished it right before hurricane Frances. Speedy Gp's motor, however, running the same thing but using the USDM sti cams made 305hp and 303tq on the dyno. His mods are APS dr650, vf22, sti pink injectors, 255lph pump, utec, Denso IK22, UP and Dp. These motors pull down low like stink. Feels very good. Also, turbo spool up on the VF22 is slightly better due to increased displacement.
Jose
Old 09-10-2004, 01:01 PM   #8
doogie1
Member#: 46149
2002 wrx STI HYBRID
wr blue
I have the swap with the stock wrx heads(except i have shimless buckets ) everything bolts up and like someone mentioned you need the ej257 head gasket but everything else oil pump, etc you can use from the wrx. I couldn't ask for anything more, trust me you'll not be dissapointed but you definately need a bigger turbo than stock....i have a vf30 301hp and 317tq at 14.5psi.
doogie1 is offline   Reply With Quote
Old 09-10-2004, 01:22 PM   #9
RALLYT-WRX
Member#: 9369
BLOD
Cool!
That's exactly what I wanted to hear, I guess now it's time to start saving my Pennies.
Old 09-10-2004, 01:53 PM   #10
AspWhtRex
Member#: 29393
2015 WRX
wrbp
whoa awesome numbers off a vf30 with only 14.5 psi
AspWhtRex is offline   Reply With Quote
Old 09-10-2004, 02:01 PM   #11
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Doogie, What Intercooler Are You Using?
Jose
Old 09-10-2004, 03:01 PM   #12
LiquidForce
Member#: 12811
2002 2.5l Wrx
At a minimum you would want to use a vf22. I am running a vf34 and my top end really drops off.
You can see comparisons of other setups on this dyno here >
http://www.dyno4mance.com/news/SEDynoDay.php
Old 09-10-2004, 03:08 PM   #13
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Do the USDM STi Cams show a marked improvement up top?
fogdor is offline   Reply With Quote
Old 09-10-2004, 03:18 PM   #14
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
No. Same duration as wrx cams with more lift.
Old 09-10-2004, 04:48 PM   #15
doogie1
Member#: 46149
2002 wrx STI HYBRID
wr blue
Hey jose, im running a greddy fmic and a greddy type-s bov 100% venting
Old 09-10-2004, 06:17 PM   #16
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Doogie,
Seriously, those are some impressive numbers considering that the VF30 is a smaller turbo than the VF22. Where does your power and better yet the torque peak at?
Jose
Old 09-10-2004, 11:21 PM   #17
wrx_snobordr
Member#: 49343
02 wrx
I am just trying to see if i am gettign this right. I can take an STI shortblock and put my wrx heads on it and it will run fine? The wrx wiring harness will work also? How about the ecu, wouldnt the engine run lean due to the extra displacement? I know it would be best if you upgraded the turbo and intercooler but what about a piggy back?
matt
wrx_snobordr is offline   Reply With Quote
Old 09-11-2004, 03:49 AM   #18
doogie1
Member#: 46149
2002 wrx STI HYBRID
wr blue
Hey jose, the turbo has full boost at 3000 rpm and this is due to the displacement and the boost doesn't taper off at all it holds it to redline i was also impressed by the numbers considering that i have a unichip my tuner has had alot of experience with unichips for a long time. By the way all this is still on stock fuel system and i have aps tumbler deletes.
Old 09-11-2004, 06:48 AM   #19
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Sweet. What are you using for tranny? These guys down here are using the Sti gearset not RA.
Jose
Old 09-11-2004, 08:45 PM   #20
doogie1
Member#: 46149
2002 wrx STI HYBRID
wr blue
Jose, my tranny is stock. The clutch is also stock with about 2500 miles on it so far.....Matt yes you can just slap your stock heads on the sti shortblock but make sure you get the gasket set when you get the block. You don't have to get the whole set but at least get the sti head gaskets. When the shop was breaking in the motor it had nothing to adjust any fuel the unichip was unplugged because they had a wideband on it and the ecu was adapting extreemly well that it didn't need any additional fuel and further into the breaking even taking it to 6k rpm at 10psi it was still doing fine. Well that was in the break in period i don't think it would be a good idea to leave it like that without some fuel adjustments after the break in period, hope that helps.
Old 09-12-2004, 12:25 PM   #21
koki
Member#: 45289
im interested on doing this swap can anybody point me in the right direction on where can i get a hold of one of this blocks?
koki is offline   Reply With Quote
Old 09-12-2004, 01:15 PM   #22
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
MAD REX is offline   Reply With Quote
Old 09-15-2004, 01:56 AM   #23
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
I am running a Greddy T67 with Blitz FMIC. I dont think my turbo will have a problem keeping up.
Old 09-15-2004, 02:11 AM   #24
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
I would be very wary of doing any business with flat4engineering:
http://forums.nasioc.com/forums/showthread.php?t=619011
Theoretically, you can order the shortblock from any Subaru dealer.
Old 09-15-2004, 03:32 PM   #25
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
Ouch, thanks for the heads up man.
2.5L Sti Shortblock with 2.0 L WRX heads - Need STi Dipstick? skimobile Built Motor Discussion 5 06-13-2007 08:53 PM
2.5L crawford shortblock on 2.0L 2004 WRX heads mistaboosta Built Motor Discussion 11 04-05-2006 06:27 PM
what i am doing with my new 2.5l sti shortblock sonic rx Built Motor Discussion 3 03-31-2006 06:48 AM
2.5L STI shortblock on JDM heads and ECU? powerlabs Subaru Conversions 3 03-14-2006 07:21 PM
FS MD: 2.5L STi Shortblock, 2.5L Gasket Kit, STi Pinks (565CC) bryan carbon Private 'For Sale' Classifieds 3 01-27-2004 10:37 PM
