Old 09-11-2004, 06:24 PM   #1
gsaint77
Member#: 65522
1996 subaru outback
green
Subaru Banner NEED more HP on my 96 subaru ouback 2.5L
I have a 96 SUBARU OUTBACK 2.5 L AUTOMATIC STOCK 155HP . I WOULD TO ACHIEVE AT LEAST 225 TO 260HP WITH THIS CAR WITHOUT TURBO. IS IT POSSIBLE CAN SOMEONE HELP ME PUT DOWN A LIST OF WHAT SHOULD I START WITH TO ACHIEVE THIS WITHOUT TURBO. AND LATER IF I WANT MORE I WILL PUT A TURBO. I WAS LOOKING AT A SUBARU THAT ARE IN UNITED KINGDOM SITES AND THEIR CAR HAVE B4 EJ25TT 2.5 WITH TWIN TURBO AUTOMATIC. I CHECK OTHER WEBSITE MY MIND WAS AMAZED AT COBBTUNING AND XCCELERATION , http://www.xcceleration.com/ . http://cobbtuning.com/legacy/. THIS IS THE THE LIST THAT I PUT TOGETHER SO FAR PLEASE LE ME KNOW IF ITS POSSIBLE. 1 COLD AIR INTAKE , DUAL CAT-BACK EXAUST SYSTEM LIKE THE 2005 SUBARU OUTBACK . POWER PULLEY. Cylinder Head Package DOHC. STAGE1 SHORT BLOCK. HEADERS, STREET PERFOMANCE CAMS, HIGH LIFT VALVETRAIN, TORQUE CONVERTER FOR THE AUTOMATIC TRANSMISSION, FUEL MANAGEMENT SYSTEM, UPGRADE THE COMPUTER CHIP. Venom 400 Control Module:, A BIGGER THROTTLE BODIES SO THE CAR COULD BREATH IN THIS CAR, .AEM 4-Channel, Twin-Cap Digital C2DI Ignition Module, SPARK PLUGS DENSO IRADIUM,Nology HotWires spark plug wires set. IF IM MISSING ANYTHING ELSE PLEASE FEEL FREE TO HELP ME OUT WITH THIS PROJECT. THE AMOUNT I WOULD LIKE TO SPEND WOULD BE $4000 DOLLARS. ANY IDEA WOULD BE WONDERFUL.
gsaint77 is offline   Reply With Quote
Old 09-11-2004, 09:26 PM   #2
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Maybe you could invest in a caps key?
You will never complete your list under 4k. Sorry, thats the truth. For info on a serious N/A build, Dcoty is the guy to talk to, but I'd do some more research before asking him questions.
For my 4k, I'd buy a set of equal-length headers, straight midpipe, and a WRX axleback. Add on a good panel filter (Cone filter intake kits are worthless on your car), new plugs (NGK-v powa, or anything copper), fuel filter and an S-AFC... and you'll have a good start.
Then, I'd invest in a port and polish of the heads, TWE stage II cams, or Cobb spicy cams, uprated tq converter and a set of good rubber. I'm sure there are plenty of other people how can advise you too... in the meantime, search, search, search.
jamesfacts is offline   Reply With Quote
Old 09-11-2004, 09:35 PM   #3
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
That VENOM400 Control Module is a pile of crap. Might as well go on EBAY and buy one of those .99$ resistors. You'll get the same performance (none) and spend $399.01 less.
But on a serious note, You should spend that $4000 and do an engine swap because you would have to spend twice that to get 260HP out of your NA motor.
RyansJDMgc8 is offline   Reply With Quote
Old 09-12-2004, 01:42 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Without turbo? The Cobb stage 3 package will get you close to 220... Otherwise, you need a turbo or two more cylinders.
And loose the caps.
Stage 2 but need more hp aaron_westb Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 55 05-31-2010 11:21 PM
How did SOA get 7 more hp On newer 2.5?? brett-01 Normally Aspirated Powertrain 38 11-02-2007 01:30 AM
Lapping Day on July 12th, need more Hp ! what to do.. 70mach1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-03-2007 04:19 PM
I need some info on Subaru impreza 2.5L with aftermarket turbo Clemens9 Normally Aspirated with bolt-on Forced Induction Powertrain 20 09-23-2001 07:10 PM
