Old 09-12-2004, 10:50 AM   #1
REX Tuner
Member#: 52895
2004 WRX VF43'd
Subaru Banner How to remove wax on black trim pieces
Looking for any tips and or products that can remove wax from the black plastic trim pieces (ie side skirts) I've tried a few things and have been unsuccessfull.
Thanks, sorry for the lame post.
REX Tuner is offline   Reply With Quote
Old 09-12-2004, 11:20 AM   #2
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
What have you tried? Denatured alcohol may do the trick. Try it in an inconspicuous place, side skirts are *raw* plastic, much different than some of the other plastics on our cars. Another good way to remove a substance is to read the label and find out what is in it that will give you a clue as to what will remove it.
Kent
wrx plus is offline   Reply With Quote
Old 09-12-2004, 11:45 AM   #3
REX Tuner
Member#: 52895
2004 WRX VF43'd
I've tried everything from hot water/soap to a tooth brush with brake cleaner (non-chlorinated). The brake cleaner worked after several "treatments" with no ill effects. I'm guessing there has to be a better/faster way. In I realize the best way to get it off is not to get any on it. I've give the denatured alcohol a shot.
Thanks.
Old 09-12-2004, 11:55 AM   #4
brunetmj
Member#: 8023
2004 2.5 RS
It will eventually wear off. I am not picking on you here as I have done the same thing. It is why I prefer a cream type wax and stay away from sprays and even paste wax (unless well controlled). I apply the wax at a good distance
from the plastic and work carefully when I approach it.
Just thought this was an opportunity to pass on a good tip for waxing.
brunetmj is offline   Reply With Quote
Old 09-12-2004, 12:07 PM   #5
RSarte
Member#: 4965
2004 WWhite Evo8 GSR
2010 Outback 2.5i Premium
WD-40 worked for me! U can wash it after with soap or not and it should be fine.
RSarte is offline   Reply With Quote
Old 09-12-2004, 12:14 PM   #6
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
Ok, seriously, get some spray on vinyl/plastic glosser and a small sponge. Spray a few times on the sponge and clean the outside trim with that. It should take teh white marks right off, and if it doesnt, after a day or 2 you wont even see it anymore. I do this to my sideskirts once a week and they look so much better with a matte gloss to them than they did as plain dry plastic when i brought the car home. They wont be over glossy like tire glaze but they will have some bit of shine to them and it will help protect them from the suns harmful uv rays :-)
G3Red04WRX is offline   Reply With Quote
Old 09-12-2004, 12:18 PM   #7
ChrisL2
Member#: 1444
Mother's Back to Black works great for that type of problem.
I've used it with great results.
ChrisL2 is offline   Reply With Quote
Old 09-12-2004, 12:40 PM   #8
REX Tuner
Member#: 52895
2004 WRX VF43'd
I use this as well. I find it merely hides the wax temporarily as a opposed to removing it. Great stuff though.
I've been using Meguiars Gold Class liquid. I try to be cautious in the application of it. But inevitably I always manage to graze the trim. The WRX isn't to bad for trim, the wifes Frontier however is a pain (door handles, rear bumper and such.) Thank god it not an Avalanche.
I tried WD-40 once a long time ago. Maybe it's time to try it agin.
I appreciate the tips, remarkably no flames.
Thanks,
Chris.
Old 09-12-2004, 01:05 PM   #9
Tobey
Member#: 21400
2015 WRX Limited
ISM
i got my jeep fender flares back to new with a pressure washer. you have to be careful though, it's easy to booger it up!
Tobey is offline   Reply With Quote
Old 09-12-2004, 01:30 PM   #10
REX Tuner
Member#: 52895
2004 WRX VF43'd
Yep I tried that too 1700 PSI with a pencil jet. It worked a little not a 100%. I guess there is no easy solution other than persistence and determination. Maybe I can combine the Black to Black, denatured alcohol, WD-40, brake cleaner, and run it through the pressure washer. .
thanks,
Old 09-12-2004, 03:13 PM   #11
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Peanut butter works also - not kidding...
Hank3 is offline   Reply With Quote
Old 09-12-2004, 03:30 PM   #12
Tobey
Member#: 21400
2015 WRX Limited
ISM
hey betty crocker, he's trying to fix his trim pieces not make samich!! totally joking with you man, you have to admit it sounds funny.
that's funny though, and i always have to wonder how someone actually comes up with these kinds of home-made solutions. imagine washing your car and saying "hmmm i wonder if peanut butter would take that wax off my black trim"...
Old 09-12-2004, 03:46 PM   #13
Hank3
Member#: 16157
'03 Mazda P5 <><
- I thought this idea was wacky too, but it most certainly works. I used to use it all the time on my Xterra as it had numerous areas with black trim pieces.
Old 09-12-2004, 04:04 PM   #14
G3Red04WRX
Member#: 66611
sure sounds funny, yea. Just thinking about some guy sittin on his driveway lookin at his sideskirts thinking "Ive tried everything in the garage, might as well go check the kitchen closet....."
Old 09-12-2004, 04:40 PM   #15
REX Tuner
Member#: 52895
2004 WRX VF43'd
Chunky or Smooth??
Old 09-12-2004, 06:05 PM   #16
Whiplash
Member#: 5589
'04 WRX
'99 Legacy Wagon
Hes right. Works like a charm. The oils in the peanut butter break down the wax.
I just wanna know who the first person to try this was...
Whiplash is offline   Reply With Quote
Old 09-12-2004, 06:11 PM   #17
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Did you try household dish degergent, it breaks down wax pretty well.
whos got a kitchen fix for shoe polish..
i have white bits all over my black trim around the 1/4 windows from scraping off auto-x numbers, its in the paint too
Jay
Old 09-12-2004, 07:40 PM   #18
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
What also works really well, especially on textured trim surfaces (not smooth) is your regular pink eraser. No joke. "Erasing" it with it comes right off.
volkl23 is offline   Reply With Quote
Old 09-12-2004, 08:05 PM   #19
lark6
Member#: 2715
70 911T
Smooth peanut butter does work as do the little "pink pearl" erasers. You can also use Goo Gone or isopropyl (a/k/a rubbing) alcohol but make sure that you go over the parts with a protectant like Back to Black afterward as the alcohols will cause the plastic to whiten over time. Jay: try those on your shoe polish runoff too.
The Mr. Clean Magic Eraser works great on getting ground-in crud out of the textured plastic handles on my fridge and dishwasher; I wonder if it'd work here?
lark6 is offline   Reply With Quote
Old 09-12-2004, 10:20 PM   #20
Trip McNealy
Member#: 37338
2007 Legacy 2.5 GT
2009 Daytona 675
peanut butter or dry "pink" eraser. you don't need anything else. guaranteed.
Trip McNealy is offline   Reply With Quote
Old 09-13-2004, 01:07 PM   #21
PoopRSkupe
Member#: 48886
'00 WRS
'08 Forester XT
armor all usually works for me?
PoopRSkupe is offline   Reply With Quote
Old 09-13-2004, 08:15 PM   #22
turbokonejo
Member#: 68669
2000 Dodge Durango
Go to your local paint store and ask for (CLIXS)
turbokonejo is offline   Reply With Quote
Old 09-13-2004, 10:11 PM   #23
WRX4me
Member#: 4107
I've never tried this stuff, but I saw it in the catalog the other day:
Griot's Wax Remover
WRX4me is offline   Reply With Quote
Old 09-13-2004, 10:15 PM   #24
tejz
Member#: 58846
2004 WRX
Try armor all
tejz is offline   Reply With Quote
Old 09-13-2004, 10:23 PM   #25
jason2004STI
Member#: 43340
2004 STI
Java Black Pearl
Cool
I think peanut butter also removes gum from fabric.. It's a Wax/Gum remover/cleaner and a samich maker Laterzzzz
Peace
Jason
I love my STi
jason2004STI is offline   Reply With Quote
how to remove wax from bronze volk te-37's? ASpec818 Interior & Exterior Modification 7 08-11-2012 05:40 PM
Old Wax on Black Trim Parts code_hat Car Care & Detailing 4 09-17-2008 10:49 AM
how to remove rear windshield exterior trim sweendiggs Interior & Exterior Modification 2 09-20-2006 03:39 PM
How to remove wax from black trim?? rice h8r Off-Topic 26 05-20-2006 07:37 PM
Removing wax from black trim G-REX Car Care & Detailing 4 07-14-2002 06:34 PM
