Old 09-12-2004, 08:13 PM   #1
Ricowrx
Member#: 37032
2004 STi
WRB w/sets of gold&silver
Post Ultimate Racing Fuel injectors w/ top feed rail kit for STI
Has any one been using ultimate racing's 785cc fuel injectors with there top feed fuel rail and wiring kit? How did the injectors and the fuel rails work out for you? Any problems with the install big or small? How was it wiring them up?
How was it tuning the car with them as apposed to the stock ones? Any and all information would be more than greatly appreciated! The reason I ask this is I went with the perrin side feed fuel rails for the sti with there modded injector and found out that there fuel rail setup was pure crap and I really didn't want to put the stock rail's back in (i shouldn't of even took them out in the first place) and was thinking about ultimate racing fuel setup. Thanks -Dave
"Ultimate Racing Flow-Matched Injector Kit
- 785cc Flow-Matched Low Impedance Fuel Injector Kit (Set of 4)
- Comes with Injectors, Resistor Pack, Wiring Kit with Relay, and Wiring Connectors
- For use with Top-Feed Fuel Rails"
Ricowrx is offline   Reply With Quote
Old 09-13-2004, 07:04 AM   #2
happasaiyan
Member#: 37731
i have 'em. i like 'em. the install was fairly straightforward. it was my first time removing the intake manifold, so it took some time to get the whole job done, but yeah, just make sure you take your time to do everything right the first time.
happasaiyan is offline   Reply With Quote
Old 09-13-2004, 09:17 AM   #3
yeager
Member#: 39121
2004 sti- URstg3
psm
I've got the same rails/injectors, but have not yet installed them. They look fairly straightforward, but as the above post mentions, you'll have to remove the intake manifold. I'll be using them with the sr55.
happasaiyan, where did you mount the resistor pack?
yeager is offline   Reply With Quote
Old 09-13-2004, 09:56 AM   #4
RoyBoy016
Member#: 44621
2002 RSX Type-S
I'm looking into these also.
RoyBoy016 is offline   Reply With Quote
Old 09-13-2004, 09:58 AM   #5
happasaiyan
Member#: 37731
there is a bolt on the passenger side on the opposite side of the fender. right in front of the FBC. i screwed the bolt in holding the resistor pack in.
to make it more stealthy looking, i went to the local hardware store and bought some black plastic wire casing like the oem stuff and put the wires in there. then i electrical taped them together. you couldnt see it if you werent really looking for it.
maybe ill take some pics of the engine bay and post them later on.
Old 09-13-2004, 01:42 PM   #6
yeager
Member#: 39121
2004 sti- URstg3
psm
please do.
Old 09-13-2004, 11:36 PM   #7
Ricowrx
Member#: 37032
2004 STi
Does it provide enough fuel for you setup? What horse power do you think they will max out at? Thanks -Dave
Old 09-13-2004, 11:37 PM   #8
Ricowrx
Member#: 37032
2004 STi
Also how was your idle and your tuning with them? Thanks
Old 09-14-2004, 01:28 AM   #9
happasaiyan
Member#: 37731
81% IDC @ 18psi @ redline. with the SR50.
just remember, these are the same injectors UR provides with their GT35R kit.
onto the pics:
ps- idles great. tunes flawlessly.
Old 09-14-2004, 02:04 AM   #10
Pirana
Member#: 55197
I like how you kept the black trim on the intercooler opening.
Pirana is offline   Reply With Quote
Old 09-14-2004, 04:23 AM   #11
Ricowrx
Member#: 37032
2004 STi
happasaiyan thank's for all the info. -Dave
Old 09-14-2004, 06:43 AM   #12
happasaiyan
Member#: 37731
makes for unexpecting prey!
Old 09-14-2004, 06:43 AM   #13
happasaiyan
Member#: 37731
no prob, just trying to help.
Old 09-14-2004, 08:48 AM   #14
yeager
Member#: 39121
2004 sti- URstg3
psm
thanks for the pictures. i think the black wire-casing was a good call.
Old 09-14-2004, 09:59 AM   #15
Subaloo
Member#: 38217
2003 WRX
BLUE
Not sure if this helps, but I have the UR 785cc's on my WRX (not with the STI top feed rails) and it idles like stock Have my resistor pack hooked to the same spot as well.
Subaloo is offline   Reply With Quote
Old 09-14-2004, 10:09 AM   #16
happasaiyan
Member#: 37731
btw, i had to buy extra wire. what they gave wasnt enough for where i mounted the resistor pack.
Old 09-14-2004, 01:04 PM   #17
yeager
Member#: 39121
2004 sti- URstg3
psm
thanks. good to know.
Old 09-14-2004, 01:41 PM   #18
happasaiyan
Member#: 37731
can you spot the IC sprayer?
Old 09-14-2004, 01:55 PM   #19
Pirana
Member#: 55197
No, unless its that little black button on the top left?
Old 09-14-2004, 02:24 PM   #20
happasaiyan
Member#: 37731
yep!
Old 09-14-2004, 05:13 PM   #21
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
http://www.projectwrx.com/modules.ph...howpage&pid=32 <-- another spin on the install.. it's the same thing for the STI as it was for me.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 09-15-2004, 03:43 AM   #22
Ricowrx
Member#: 37032
2004 STi
Is there any place to pickup the rails and injectors at a cheaper price? Where did you guy's get yours? Thanks -Dave
Old 09-15-2004, 09:16 AM   #23
yeager
Member#: 39121
2004 sti- URstg3
psm
IM ultimate racing on AOL: Ultimate Racing3
or call them directly. Darryl was very helpful and the inj/rails were sent immediately. I think I paid 900 or so for injectors, rails, walbro pump.
Turbo XS UTEC Delta, Perrin Top Feed Fuel Rails, and Ultimate Racing 1000cc Injectors subiefan7162 Engine/Power/Exhaust 9 07-16-2009 10:58 PM
For Sale: Ultimate Racing 1000CC injectors & Fuel Rails + TGV deletes Side Feed syoung0298 Engine/Power/Exhaust 33 07-07-2009 09:41 PM
..:: BLITZ genuine fuel injectors 700cc top feed ::.. NEW MR2fanatic Engine/Power/Exhaust 0 05-01-2009 02:59 PM
ultimate racing fuel injectors 785cc essejwrx Engine/Power/Exhaust 0 10-23-2006 06:21 PM
WTB: ultimate racing fuel injector and rail kit for a US STI 04-05 element1 Private 'Wanted' Classifieds 2 04-08-2005 02:01 PM
