Old 09-13-2004, 06:07 PM   #1
pcauwels
Member#: 37676
Question Clock Gauge Replacement for Stock Turbo Gauge Pod
I recently installed a center gauge cluster (WRXtra) with Omori 52m gauges, Boost, EGT, Oil Pressure (Rally Sport Direct).
I know have 3 devices that display boost; Stock Boost Gauge, Blitz TT, and now the Omori center cluster gauge.
I really miss the clock and really do not need 3 boost gauges...
I've been looking for a analog or digital clock that fits in the 42mm gauge pod. That way, I can keep the pod and replace the boost with the clock.
Does anyone know of a analog clock or digital clock that would fit in the stock boost gauge pod? I believe the pod is for 42mm gauges, but I'm not sure.
Thanks.
pcauwels is offline   Reply With Quote
Old 09-13-2004, 06:29 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
brunetmj is offline   Reply With Quote
Old 09-13-2004, 06:34 PM   #3
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Most aftermarket clock gauges would be sized for 2 or 2 1/16 inch diameter openings. However, it may be possible to find oem clock gauge that are smaller than that. The only way I know to find such oem clocks is through eBay. It will most likely be a used one. I bought a used VDO clock gauge through eBay that came off some Audi or VW. That time, I recall seeing several small (sub 2 inch diameter) VDO clocks floating around. You could get lucky.
satrya is offline   Reply With Quote
Old 09-13-2004, 07:09 PM   #4
pcauwels
Member#: 37676
Originally Posted by brunetmj
That is definitely what I'm looking for, but that one is too large.
I believe that 2-1/16" gauges are 52mm and the stock boost gauge is 42mm.
Satrya,
I'll definitely look around on eBay, maybe something will turn up.
Old 09-14-2004, 12:25 PM   #5
brunetmj
Member#: 8023
2004 2.5 RS
In case you cant find anything i have seen single 52mm gauge pods that snuggle in where the A pillar meets the windshield. Might be an alternative.
wtb steering wheel pod for stock boost gauge hubble1953 Private 'Wanted' Classifieds 0 11-24-2008 09:57 PM
WTT: 3 gauge A-pillar pod for stock 3-gauge clock replacement pod hobbzz Private 'Wanted' Classifieds 12 09-05-2006 05:42 PM
Help me find replacements for stock gauge TylerTR Interior & Exterior Modification 7 12-12-2005 12:35 AM
WTB: MD: stock turbo gauge and pod callgauer Private 'Wanted' Classifieds 0 09-09-2005 11:07 AM
Gauge panel for stock Subaru gauge pod ProdriveWRC Private 'For Sale' Classifieds 12 09-25-2004 05:08 PM
