Old 09-14-2004, 12:51 PM   #1
KJR
Member#: 16879
Default P1544 and motor won't rev over 2K rpm?
i just uninstalled my Cobb AP and reverted to stock. immediately i got a CEL. i scanned it and it read P1544(high EGT). this is without even driving the car, just starting it. went to drive it this morning and when the motor reaches 2K rpm in neutral, it dies. if it try to release the clutch, it dies at about 1500 rpm. seems like a fuel cut off or throttle sensor issue but who knows....
has anyone experienced this or know what may be the culprit?
thanks,
KJR is offline   Reply With Quote
Old 09-14-2004, 05:18 PM   #2
pbuckley
Member#: 39187
2004 Impreza
Are you sure you didnt flash the anti-theft map to the car?
pbuckley is offline   Reply With Quote
Old 09-14-2004, 05:25 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Your EGT sensor ist kaput. Simply disconnecting the sensor will allow full engine RPM operation, but will cause a CEL. Installing a 2.2k ohm 1/2 watt resistor in place of the sensor will eliminate the CEL.
Jon [in CT] is offline   Reply With Quote
Old 09-14-2004, 06:10 PM   #4
KJR
Member#: 16879
pbuckley, i am sure i have the correct map. i divorced the AP and viewed the Cobb welcome screen when the reflash was completed.
Jon, thanks for your advise. i will disconnect it and see what happens. i hope you're correct, that would be an easy fix.
Old 09-17-2004, 11:50 AM   #5
KJR
Member#: 16879
well Jon, you called it, thanks! strange thing, i have 70 more miles on the car since i unplugged the EGT sensor with no CEL. i aint complainin' tho.
Tapping sound when going over 2k rpm jondl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 51 02-05-2010 10:50 AM
Tapping sound when going over 2k rpm jondl Engine/Power/Exhaust 3 03-05-2009 11:31 PM
Car wont rev over 5000 RPM, pulled Map sensor and cars fine.... Please help!!! Cautionjump Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-08-2007 11:45 PM
Wont go over 2K RPMs!??! ATXImpreza Normally Aspirated Powertrain 4 03-14-2006 11:00 AM
95 Impreza L w/ 2.2L engine won't rev over 4100 RPMs - any thoughts? marcus12 Normally Aspirated Powertrain 12 11-17-2004 02:07 PM
