Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 09-14-2004, 10:12 PM   #1
Amir1987
Member#: 62281
2004 WRX STi
White/Gold BBS
Default Boost Creep with COBB AP?
I Called COBB and they said my sti I should not have boostcreep when using
a TBE with an AccessPort. I hope this is true so I dont have to send of my turbo to get it ported(would much rather not). Also I know of some people boosting up to 20-21 P.S.I is that boost creep or spike?
Anybody know whats the deal?
Amir1987 is offline   Reply With Quote
Old 09-15-2004, 07:56 AM   #2
hawker800mech
Member#: 53923
2013 Legacy Limited
Boost creep is when you are on the gas and the boost just keeps "creeping" up and keeps going until you let off the gas, of course. If it hits a certain psi, the ECU will "kill" the engine until the boost drops. My brother-in-laws STI did that after he got his TBE on and I thought I killed his brand new car when it happened. That was in the winter. This is due to the inablity of the wastegate to keep up and bypass enough gases to control the boost. A boost spike is when you are on the gas and the boost will peak above set psi and then settle down to set psi while still on the gas..
hawker800mech is offline   Reply With Quote
Old 09-15-2004, 09:18 AM   #3
meridock
Member#: 37868
2010 Corvette Z06
Try the newer maps LWG map. Also - is the TBE catless?
meridock is offline   Reply With Quote
Old 09-15-2004, 03:16 PM   #4
Amir1987
Member#: 62281
2004 WRX STi
White/Gold BBS
Thanks for the reply's
yes the TBE is catless
Old 09-15-2004, 03:42 PM   #5
meridock
Member#: 37868
2010 Corvette Z06
Catless TBE may be a problem - even with a COBB setup. Have you tried the LWG maps from COBB?
Old 09-15-2004, 03:49 PM   #6
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Listen to Cobb...no need to port. Depending on your elevation, peak boost will vary. There are several maps you can experiment if you have boost problems. To answer your question, boosting up to 20-21psi would be considered overboost.
dsmperformance is offline   Reply With Quote
Old 09-21-2004, 09:23 PM   #7
my04sti
Member#: 61501
04 subaru sti
blue 12.68 @ 106 mph
Cobb told me it wouldnt be a problem. Ill be running a catted TBE in a couple days,and I was wondering the same thing. Anyone else have any insight on this?
Greg
my04sti is offline   Reply With Quote
Old 09-22-2004, 03:12 PM   #8
BOFslime
Member#: 23845
2015 FLAT SIX
I have a catless APS 3" tbe, and a stg2 cobb map flashed to my ecu. Turbo is stock and unmodified/unported, it does NOT boost creep at all.
The reason the car's creeped in the first place was because of the stock waste gate duty cycle curve, it assumes the back pressure seen with the exhaust that came on the car, when you take that away, bam.. you get creep. Lot of people have fixed this mechanically by porting, rather than though the ecu mapping, because tuning was limited when the wrx sti first came out in the us.
BOFslime is offline   Reply With Quote
Old 09-22-2004, 06:01 PM   #9
my04sti
Member#: 61501
04 subaru sti
Thanks for the help,I cant wait to use the stage 2 map.
Greg
Old 09-29-2004, 10:10 PM   #10
my04sti
Member#: 61501
04 subaru sti
No boost creep here! The car pulls so hard,Im very happy with my setup. I had to use the lwg map. No complaints at all. I am going to the dyno friday and racing saturday.
Greg
boost creep with STi intercooler on a Cobb v2 tuned wrx mrdrd04rex Engine Management & Tuning 5 11-28-2009 09:25 PM
vf22 boost control with Cobb AP Sausage AccessPort 0 06-26-2006 12:08 PM
Boost controller with cobb AP? booimaghost Engine Management & Tuning 11 06-03-2005 02:01 AM
