Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 09-14-2004, 09:15 PM   #1
mrmcderm
Member#: 25294
2003 LR Infiniti G35
WRB WRX Wagon (Sold)
Unhappy Loose steering at high speed in a wagon
Does anyone have an experience with, or insight into why my wagon steering get sloppy, or loose at higher speeds? I used to notice it about 85mph, then it started happening at 80. Coming home from work tonight it started at around 75mph.
It feels like the front end lightens up...or maybe like the steering box is getting 'overboosted'. All of the sudden the steering feel gets really light and it feels like it wouldn't take much to really whip it into a spin.
The feeling is not linear at all. 70mph feels like 30mph, 75mph feels like my mom's minivan.
I've seen one other post about this via search, but the guy posted in the wrong forum so there were no responses.
If anyone has any ideas, please let me know. And no, this is not the 'memory steer' problem...I have that problem also, and haven't upgraded the steering bushings yet. And even when I do, I really don't think they are going to solve this problem.
TIA,
M
mrmcderm is offline   Reply With Quote
Old 09-14-2004, 10:23 PM   #2
Integra96
Member#: 64196
2010 Family Sedan
Well, I know that the stock crappy alignment specs on some cars can make the steering feel funky like that. Maybe get a nicer performance alignment to see if it helps. Also, I noticed that having a bigger rear sway bar helped "stabilize" the steering feel at higher speeds on the highway.
Integra96 is offline   Reply With Quote
Old 09-14-2004, 11:06 PM   #3
majmun
Member#: 18298
2004 STi
Have you checked your tire pressures lately?
majmun is offline   Reply With Quote
Old 09-15-2004, 11:07 AM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Also you could swap the steering rack bushings for the Whitelines or Noltec and add an ALK to increase castor which gives a more solid on-centre feel at speed.
linsavy is offline   Reply With Quote
Old 09-15-2004, 02:27 PM   #5
blksubie
Member#: 55177
2010 G37S,
05 STi sold
what do the tire look like, i had the same problem and then i looked at my tire and saw I had wire showing on the inside of my tires.....very bad
blksubie is offline   Reply With Quote
Old 09-15-2004, 02:55 PM   #6
mrmcderm
Member#: 25294
No, I haven't checked my pressures in a couple of weeks, though I tend to run higher pressures...
And the insides of my tires are pretty worn. All 4 of my tires are cupped from a poor alignment job followed by months of my wife driving it while under inflated.
I will check my pressures tonight...
But do you think the tread wear could cause that effect?
Old 09-15-2004, 03:16 PM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
Tread wear or a poor alignment (could be linked). Toe out (excessive) will cause pretty poor performance at speed- even excessive toe in can too.
If the tread wear is that poor- I'd think about retiring them, if not an alignment (w/ a shop that will give you before/after printouts).
Big Sky
Old 09-15-2004, 06:53 PM   #8
newscooby
Member#: 995
2000 MkIV GTi&23 LSV
Red cars PWN me
In addition to the other replies...I noticed, on my stock suspension, the same characteristics you've described when I got to 100.
Suspension mods fixed that. But I'd definitely look into alignment and tires first.
newscooby is offline   Reply With Quote
Old 09-15-2004, 08:02 PM   #9
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
At 100, aerodynamics are definitely playing a roll and lift starts to rear its ugly head, no pun intended.
Arnie is offline   Reply With Quote
Old 09-15-2004, 11:37 PM   #10
pimpUall
Member#: 55424
2005 380hp LGT Wagon
It's your tires. I have an '04 wagon with 17 x 7.5 rota tarmacs w/ 225/45/17. I also have front and rear strut braces and a 4 point lower control arm brace. The rest is bone stock. When I have done 110+mph run it's very steady. No float or drama. If you have stock tires up the tires about 4 psi.
pimpUall is offline   Reply With Quote
Old 09-16-2004, 07:03 PM   #11
2Stroke
Member#: 36712
2003 WRX Wagon
I have the same feeling with my wagon, but in my case, I'd say it changes with speed as something like a parabolic curve, as opposed to being linear, but its predictable. When cornering at speeds above ~75 mph, and especially when cornering uphill and under acceleration, it feels to me like the front end is lifting more than usual. The front end feels light, and steering response is slower. I have to turn in sooner and farther to get the car thru a given corner.
I attribute it mostly to rearward weight transfer due to aero lift, compounded by the lift due to acceleration. Note that the acceleration lift further raises the front of the car, which in turn increases the aero lift/weight transer due to higher ""attack angle" (because I can't think of a better term for the angle of the car relative to the direction of airflow). I'm also thinking that the AWD system is contributing some gyro effect to the situation that is causing the car not to turn as well as it would in a 2-wheel drive car, but I don't have the expertise to quantify or even characterize that.
BTW, my suspension is stock, but I have good 215/45-17 tires on +52 offset rims, and my alignment is set at -1.0 camber, zero toe.
Sorry I don't have any specific answers, but suspension upgrades to keep the nose down should be the ticket here. I'll do some of that as soon as I finish thrashing the stock suspension.
2Stroke is offline   Reply With Quote
Old 09-16-2004, 07:15 PM   #12
2Stroke
Member#: 36712
2003 WRX Wagon
Any chance that you could write up a short (or otherwise) review of the lower control arm brace? Maybe in the "car parts" forum? /end hijack.
Old 09-17-2004, 11:37 AM   #13
pimpUall
Member#: 55424
To be honest, I put the top front and rear braces on about month after I got my car. Then a month I installed the lower brace. Then a month later I installed a set of rota 17 x 7.5 with 225/45/17. With the first braces it felt alittle stiffer. With the lower control brace the car felt even stiffer and would responde quicker and was more stable in turns. With the new rims and tires it's even more stable at hi speeds(a few 110+ mph) and really sticks in corners. I got all the bracing to keep the car stiff as it gets older. I plan on keeping my car for at least 5 yr and I want it to be in the future as it is now.
Old 09-24-2004, 03:16 PM   #14
mrmcderm
Member#: 25294
majmun, the tire pressures were the problem! They were back down to the stock values. I ran them back up to 36 front, 34 rear and the issue went away.
me thinks its time for new tires.
Steering Wheel jerks at high speed in the rain Imp06 Newbies & FAQs 11 07-29-2009 11:49 PM
Strange noise at high speed in '06 STI scrawshaw Tire & Wheel 1 12-24-2006 01:13 PM
Loose Steering at high speed Husky07 Brakes, Steering & Suspension 12 12-29-2005 01:52 PM
Is the speed-proportional steering wheel supposed to tighten up at high speed? njchen24 Legacy Forum 3 11-08-2005 07:20 PM
('93-'01) Steering wheel is loose at high speeds HydeX Impreza Forum 16 10-15-2001 09:58 PM
