Old 09-15-2004, 12:40 PM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Necessary to disconnect battery for ECU swap?
To pop the ECU out and put a new one in, will it matter if the battery is connected? Thanks.
garface is offline   Reply With Quote
Old 09-15-2004, 01:05 PM   #2
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
definately wouldn't hurt, i'd do it just incase
overdose is offline   Reply With Quote
Old 09-15-2004, 01:05 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, there is full-time power there and you don't want to do the swap while the ECU is "live". More chance for damage that way. Be safe and disconnect the battery, the only thing you will lose is the settings in your radio.
Old 09-15-2004, 01:30 PM   #4
theBob
Member#: 43245
02 WRX
WR Blue
I was thinking that it would be a good idea. But then again, I never did -- and I've taken out the Ecu about a dozen times over 2 years. Knock on wood. Not a problem
theBob is offline   Reply With Quote
Old 09-15-2004, 02:10 PM   #5
subiesown
Member#: 53798
Considering that disconnecting is not a PITA at all, I would disconnect it any time you are doing anything with the electrical system. Don't know what adverse effects you may have from not doing it, but better safe than sorry.
subiesown is offline   Reply With Quote
Old 09-15-2004, 02:31 PM   #6
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
And your trip mileage on the odometer.
Coati is offline   Reply With Quote
Old 09-15-2004, 03:31 PM   #7
theBob
Member#: 43245
02 WRX
WR Blue
What about pulling the ECU fuse? I don't want to spend hours going over wiring diagrams, but with key off, ECU fuse out, seems to me that there shouldn't be any power there. Correct me if I'm wrong.
Old 09-15-2004, 03:55 PM   #8
Coati
Member#: 9106
2015 FXT - DGM
Why bother? You already need to have your wrenches out to take the footplate off. The whole operation takes a max of 10 minutes, even with taking the battery cable off. It's got to be one of the easiest mechanical projects on a WRX.
Old 09-16-2004, 12:21 AM   #9
theBob
Member#: 43245
02 WRX
WR Blue
Yeah, but the trip odometer.... You just can't get that part of your life back.
Old 09-17-2004, 01:17 AM   #10
subiesown
Member#: 53798
Hahahaha!
Old 09-17-2004, 02:35 AM   #11
vile
Member#: 32371
'02 t-rex wagon
platinum
ahhhh, nothing like hot swapping an esd device
vile is offline   Reply With Quote
A123 to make batteries for Chrysler electric cars AVANTI R5 Non-Subaru News & Rumors 2 04-07-2009 12:18 AM
WTB - '99-'01 RS to be used for a swap. Can have high miles/blown engine! jimbo1245 Private 'Wanted' Classifieds 0 07-23-2007 09:40 PM
disconnected battery, reflashed ecu, now car runs like **** ted@mb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-23-2007 12:54 PM
disconnected battery, does ECU need to re-learn? ihavebettersound AccessPort 4 08-10-2006 08:59 PM
Going out of country for 1 month... need to disconnect battery? Poe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-10-2002 02:52 PM
