Old 09-15-2004, 09:46 PM   #1
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
Unhappy No luck with O2 Extension
Hey i just installed a PDM O2 Sensor Extension this last weekend because i've been getting the P0420 code. After install i cleared code and it has been working since, until today. Well more like until an hour ago, i was driving down the highway and up came the CEL! Damn it, i thought that thing would have fixed it?! Now what are the chances that my O2 Sensor is bad and thats the reason i'm getting CEL?? Is there anything else i can try before cutting wires?
P.S. I have CAI and borla headers, thats it i swear.
Brindor2.5 is offline   Reply With Quote
Old 09-15-2004, 09:55 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Did you have the cel with stock header? You could try header wrap to keep in some heat.
You may just need a new o2-air/fuel sensor.
Tim Sanderson is offline   Reply With Quote
Old 09-15-2004, 10:23 PM   #3
squeech
Member#: 38280
2000 2.5RS w/ EJ205
tuned @ teh Ghetto Garage
Might want to check the O2 sensor. I have a CAI and Borla's on my RS, and I've never seen a CEL...
squeech is offline   Reply With Quote
Old 09-16-2004, 12:24 PM   #4
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
I did not get it with the stock headers. It didn't come on right away after i put the new ones on, took a little while, little less than a week i'd say.
Yeah? Where could i find that? Both on the car and store wise.
Old 09-16-2004, 12:29 PM   #5
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
Is there an easy way to check it?
P.S. I just read about how having bosch sparkplugs can cause problems, and i think those are the ones i have. Should i buy new sparkplugs??
Old 09-16-2004, 01:02 PM   #6
squeech
Member#: 38280
2000 2.5RS w/ EJ205
If you are using OEM sparks still, I'm pretty sure NGK makes those, and not Bosch.
P0420 actually stands for Catalyst Inefficiency, and is not usually thrown because of an O2 sensor, but rather a cat problem. I don't know much more about it than that.
Shot in the dark: If you used the stock gaskets when headers were installed, there could be an exhaust leak (doesn't usually throw a light though...)
Old 09-16-2004, 01:32 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
It won't be the air/fuel aka front O2 sensor unless you are throwing CEL 0133. The 0420 is the cat inefficiency code thrown by the lambda aka rear O2 sensor. Some car's are just pickyer than others. My Cobb headers throw 0420's every 500 miles even with the PDM extension. Once I started getting the 0133 and had fried my front O2 sensor, I just gave up on it. I have smog coming up, so changed the front sensor and put the stock headers back on. No CEL for over 500 miles, so I know my cams aren't the culprit. Unfortunately, it is just something we have to live with when modding cars...
Old 09-16-2004, 01:42 PM   #8
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
Yeah, with borla headers my o2 extender didn't work for me either. Running those borlas on some of our cars, the cel is just going to be there.
Ruff is offline   Reply With Quote
Old 09-16-2004, 02:27 PM   #9
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
yea, i have the borla header, and stromug cat back exhasut, and a cobb intake, and have had no Cels ever. and ia have had them on for months.
Shane
PARANOID56 is offline   Reply With Quote
Old 09-16-2004, 03:22 PM   #10
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
i too have CAI and Borla headers.. no CEL
the ONLY time i got that CEL, indeed, my rear 02 sensor was bad.
i'd suspect the sensor iteself at this point.
you may want to inspect it for visible damage (my wiring was fray'd)
good luck
Jamie
www.subiegal.com
Subie Gal is offline   Reply With Quote
Old 09-16-2004, 06:15 PM   #11
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
So i've gathered that the first thing to try and replace is the O2 sensor before replacing the CAT. Any chance that maybe replacing the sparkplugs with NGK?
Old 09-16-2004, 08:40 PM   #12
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I've had the cel since o2 I think. The dealer changed the cat twice and the o2 sensor once. After my warranty was up I just left it. Had the cel ever since. p0420. Maybe I should buy a new rear o2. They are pretty pricey though, is there an alternative? Anybody have a part # for a bosch or something?
Old 09-17-2004, 12:32 PM   #13
00RScoupe
Member#: 57535
2004 FXT
Maroon
Well in my case the extender didn't eliminate the problem, but made it easier to live with.
Personal Observation:
P0420 pops up more frequently with more highway driving, hence giving credence to the hypothesis that the borla headers cool down too quickly. Driving around town less air gets moved under the car and in the engine bay so the computer is happier. Those who have wrapped their borlas (Subie gal included) seem to do much better than those of us that like our borlas naked. I am pretty close to just wrapping mine. Lots of threads on this over at RS25.com.
00RScoupe is offline   Reply With Quote
Old 09-17-2004, 01:49 PM   #14
rabbitnutz
Member#: 51940
i'd say change the rear 02 sensor, and if you get the urge, wrap the headers...it's not a bad idea to do it, but probably not nessicery....
rabbitnutz is offline   Reply With Quote
Old 09-17-2004, 03:07 PM   #15
BlkTS02
Member#: 50142
2002 2.5TS
MBP
My headers are jet-hot coated, still gives a CEL with the extension.
BlkTS02 is offline   Reply With Quote
No luck with the ladies. FiveDoorSVT Off-Topic 332 06-11-2008 09:43 AM
No luck with Parkades Woody Vancouver Impreza Club Forum -- VIC 15 08-10-2004 12:23 AM
I have no luck with cars. Car damage pics. aod Off-Topic 57 07-03-2004 04:47 AM
no luck in the Dressup/Style Forum, trying my luck here MattDell Mid Atlantic Impreza Club -- MAIC 3 05-16-2002 04:40 PM
Searching boards all day with no luck.... krnbk2 General Forum Archive 12 10-22-2000 08:08 PM
