Old 09-16-2004, 02:01 PM   #1
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Default Compression Ratios and Heads (STI, Spec C, etc)
Based on some of the results from my recent dyno tuning (http://forums.nasioc.com/forums/showthread.php?t=628790) , I thought I would extend the discussion about the compression ratios. Since I happen the have a selection of different heads sitting here in my garage, I took some measurements.
First, let's look at the specs of the three heads in question:
Head 1: Us STI Head. Visually, this is the 'small port' head with AVCS. Cams are the new STI cams, which are pressed on cam lobes. Lift on these cams looks very similiar to the SpecC, but duration is much less.
Combustion Chamber Size: 57ccs measured, Factory Spec: 58ccs
Intake Port Chamber Size: 130ccs
Exhaust Port Chamber Size: 100,115ccs (one is bigger then the other)
Head 2: US WRWX Head. Similiar casting to the above STI one. Small port, No AVCS.
Combustion Chamber Size: 51ccs measured, Factory Spec: 52ccs
Exhaust Port Chamber Size: 115,130ccs
Head 3: JDM V7 STI Spec C Head. Visually, large port casting, AVCS. Cams have higher lift and duration.
Combusion Chamber Size: 50ccs measured, Factory Spec: 48ccs
Intake Port Chamber Size: 151.5ccs
Exhaust Port Chamber Size: 113,130ccs.
Commentary
Looking at these three heads, the larger intake ports on the SpecC is obvious. The New US STI heads are based off the WRX casting, or a derivitive of that. They have the smaller ports, but a different combusiton chamber design. The chamber is larger and deeper, and the spark plug
thread depth is different. (longer) Obviously the SpecC heads seem the most desirable interms of stock flow possiblity. However, additional headwork on the STI heads may make them as good/better.
Second, let's look at how this data reflects on the compression ratio.
To determine the compression ratio, you need not only the Combustion chamber volume, but you also need piston dish, gasket thickness, and most importantly quench distance and volume (aka piston to deck height).
The head chamber data is derived from above, which we measured here. The piston volume of the stock STI pistons was also measured last night, and correlated exactly with other builders notes (22ccs).
The piston to deck height can be determined two ways. The first is to measure it. With the engine I have here, it measure out to about .015" or .38mm. Other people have measured it at .013" or .33mm, and a previous (less accutare) measure I made came to the same endpoint. The second method for determined this distance is to calculate it based on the compresssion height of the piston, the length of the rod, the stroke, and the total deck to crank height. Using that method, I came up with .39mm, which corresponds well to my other measurements. The gasket thickness can be measured with a crushed head gasket. I measured .6mm on both head gaskets when compressed.
Putting these numbers together results in the following table:
As you can see, the static compression of the stock motor using this method comes out to around 8.09:1, vs the factory claim of 8.2:1. This may be due to error in measurement, or more likly the translation from static to true dynamic or observed compression ratio. Either way, the relative compression values are still valid and educational.
Putting the WRX or SpecC heads directly on a stock block results in raising the compression ratio to approximatly 8.6-8.7:1. While this is by no means obnoxious, it is a significant change. In order to bring this CR back down, one could substitite the cometic gaskets which Axis Racing sells. These have a compressed size of about .051", or 1.3mm. With that change, CR would drop to 8.2:1.
Jeff Sponaugle
PDXTuning.com
*Thanks to Ron at Axis for a wealth of information on this topic!*
sponaugle is offline   Reply With Quote
Old 09-16-2004, 02:06 PM   #2
cronic
Member#: 9749
Good Work! Hopefully this will put an end to all the "what will my CR be with an e257"
cronic is offline   Reply With Quote
Old 09-16-2004, 02:15 PM   #3
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Good work Jeff.. Thanks
Clark
AZScoobie is offline   Reply With Quote
Old 09-16-2004, 02:47 PM   #4
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Informative as always.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 09-16-2004, 02:57 PM   #5
eightballrj
Member#: 18520
2005 L GT Limited
Thanks for the right up Jeff!
Richard
eightballrj is offline   Reply With Quote
Old 09-16-2004, 05:03 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
yea, thanks for the info that is awesome, so does that mean your engine wasnt actually at 9.5:1 then?
EDIT:nevermind just checked the other thread
i love these informative posts.
thanks, keep up the pioneering!
Ben
Old 09-16-2004, 05:49 PM   #7
AZScoobie
Member#: 8785
netcom.com
Yep. Since Jeff and I have the same motors (or did until he got pistons) I guess we where both at 8.71 to 1.
C
Old 09-16-2004, 05:54 PM   #8
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Wow, great info as always.
Oh, and noted at Imprezario as usual
jblaine is offline   Reply With Quote
Old 09-16-2004, 10:45 PM   #9
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
Thanks Jeff and Ron!
-st
singletrack is offline   Reply With Quote
Old 09-16-2004, 10:50 PM   #10
Davenow
Member#: 23676
ok so now I am confused.
What do you end up for (compression wise) with Version 7 heads on the usdm 2.0 wrx block?
Old 09-27-2004, 04:45 PM   #11
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
I'd be happy to know if the cc's on the V8 heads are the same as the V7 RA.
ebeck is offline   Reply With Quote
Old 10-21-2004, 04:10 PM   #12
kool168
Member#: 61006
very nice work done!
kool168 is offline   Reply With Quote
Old 03-07-2005, 02:18 PM   #13
HIREN
Member#: 51633
2013 GT-R
Thumbs up
Nice Info!
HIREN is offline   Reply With Quote
Old 03-08-2005, 01:30 AM   #14
hyp36rmax
Member#: 24537
2006 LanEVO9 RS
SFVoltron White
yahooo! just what i was looking for! great job even if im a little fewmonths late! haha, so now my question is this, what are the pros and cons of high and lower CR on a 2.5 with wrx heads? or another note derivatives such as sti cams, crower cams, jun cams, crawford cams...LOL
hyp36rmax is offline   Reply With Quote
Old 07-10-2005, 06:33 PM   #15
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default EJ257 combustion chambers
Jeff, could you confirm that the EJ257 combustion chambers are 57-58cc volume? Quirt stated that mine were 50cc. That would mean a helluva lot of milling, and a mistake in my custoom piston spec. I hope I haven't Swain Tech coated a few ashtrays. That would really suck.
Thx,
S.
n2xlr8n is offline   Reply With Quote
Old 07-10-2005, 06:58 PM   #16
Crawford Performance
Member#: 42075
Thx,
S.
Steve,
The US STI has a combustion chamber volume of 56cc with a spark plug installed.
The US WRX has a chamber volume of 49 to 50cc with a spark plug installed.
I am not quite sure about the 50cc statement you got from me
Quirt
Crawford Performance is offline   Reply With Quote
Old 07-10-2005, 07:03 PM   #17
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Originally Posted by Crawford Performance
Steve,
Quirt
I called before ordering my pistons...Chris asked you (without you coming to the phone) what the heads cc'd at, you stated 50ccs. I'm going to cc them myself when I get my burette back from work....stay tuned.
Old 07-10-2005, 07:18 PM   #18
Member#: 42075
I am sorry
Old 07-11-2005, 11:01 AM   #19
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I am sorry
...and I'm back to the drawing board. 56 +/- .2ccs
Measured each 3 times, head is level, etc.
I guess I'll be in touch for your ideas about where to go with this nightmare.
Old 11-04-2005, 01:03 AM   #20
gpatmac
Member#: 18446
2002 WRX wagon
psm
Jeff (or anyone),
Any idea about the v7 STi non-RA heads?
gpatmac is offline   Reply With Quote
Old 08-27-2007, 01:49 PM   #21
eclip5e
Member#: 14686
2002 RASpec Impreza
Dent Sport/visual assault
Anyone have the excel spreadsheet this was calculated from?
I'm building an ej207 with the Tomei 2.2l stroker kit and WRX (ported) heads. I need to calculated CR with a few different head gaskets.
eclip5e is offline   Reply With Quote
Old 08-27-2007, 03:50 PM   #22
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
added this thread to the forum sticky "Threads of note"
nhluhr is offline   Reply With Quote
Old 10-05-2007, 08:06 PM   #23
poormansporsche
Member#: 79798
Would like to know this also as I'm about to either buy new pistons and a block or just a block and I have JDM STI 7 (big port) cyl. heads.
cheers
poorman
Originally Posted by gpatmac View Post
Jeff (or anyone),
poormansporsche is offline   Reply With Quote
Old 03-26-2011, 01:43 AM   #24
nedalrabadi
Member#: 244358
1996 impreza
orange & black
what would be a piston choise for v8 jdm ej207 ?
wisseco,cosworth,CP,JE,etc?
nedalrabadi is offline   Reply With Quote
Old 01-31-2015, 10:42 PM   #25
Jazz30-06
Member#: 328787
1998 Impreza 2.5RS
Black Diamond Pearl
Jeff,
When you measured the 205 heads, was that before or after deshrouding the valves?
Jazz30-06 is offline   Reply With Quote
Compression Ratio & Heads Decision Question valetudospang Built Motor Discussion 12 08-27-2008 11:25 AM
What the compression test and leakdown tests SPEC for 05 STI hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-25-2005 04:43 PM
What is my new compression ratio? EJ18 heads w/ EJ20 block STi-Nismo Dood Subaru Conversions 1 01-08-2005 05:23 PM
Sti compression ratio and why its good dlowman STi Forum Archive 12 04-15-2003 09:55 PM
8.2:1 Compression Ratio and 3.9 Final Drive Jon [in CT] STi Forum Archive 43 01-22-2003 12:34 PM
