Welcome to the North American Subaru Impreza Owners Club Friday August 29, 2014
Old 09-18-2004, 01:06 PM   #1
dawhim
Member#: 51603
1996 impreza L
Red
Default what happen if you twist your oil filter too tight?
I didn't do the oil change myself last time and when I do the oil change after 3500 miles, I couldn't take off the oil filter by hands. I went to walmart to get an oil filter wrench to get that thing off.
the manual has a warning saying do not make the oil filter too tight.
the oil is totally black too. damn!
dawhim is offline   Reply With Quote
Old 09-18-2004, 01:08 PM   #2
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
over tightening could cause leaking. the reason the oil could be black is the brand of oil used. some are blacker than others.
MikeWRX-NJ is offline   Reply With Quote
Old 09-18-2004, 01:32 PM   #3
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
i've never been able to remove an oil filter by hand. and yeah, black oil is "normal" that's why it needs changing tighten a half turn or 3/4 past where the gasket seats.
DougM is offline   Reply With Quote
Old 09-18-2004, 01:37 PM   #4
cartel
Member#: 64681
2000 Impreza RS 2.5
If you can take the oil filter off by hand..........You the man.
cartel is offline   Reply With Quote
Old 09-18-2004, 05:02 PM   #5
Silver04WRX
Member#: 37644
2009 Legacy 2.5i
Like DougM said, if the oil is black, you know its doing its job.
Silver04WRX is offline   Reply With Quote
Old 09-18-2004, 06:37 PM   #6
dawhim
Member#: 51603
1996 impreza L
Red
I was asking some people about the oil filter wrench, then they just told me they twisted it off by hands.
Old 09-18-2004, 06:53 PM   #7
cnk
Member#: 10757
2013 BRZ Limited 6MT
I've never been able to get the filter off by hand. . .not on my WRX or the other cars I've worked on. I always tighten the filter on 1/2 -3/4 turns after the gasket touches and it's always been on tight when changing it afterwards. Just use the filter wrench and be happy.
Calvin
cnk is offline   Reply With Quote
Old 09-18-2004, 09:17 PM   #8
Cabal
Member#: 31159
2006 WRX, 2008 2.5i
San Remo Red
Ding. As long as you're tightening by hand, you really don't have to worry about over-tightening it. I've never used an oil filter wrench, but sometimes it does take a lot of effort if I did the full 3/4 turn when putting it on.
Cabal is offline   Reply With Quote
Old 09-19-2004, 12:18 AM   #9
Odin
Member#: 25428
2005 STi
Usually your hands are greasy. Sometimes it is an akward angle. Get and oil filter wrench. End of story.
Odin is offline   Reply With Quote
Old 09-19-2004, 12:52 AM   #10
squeech
Member#: 38280
2000 2.5RS w/ EJ205
tuned @ teh Ghetto Garage
Yeah, I hand tighten mine on, but come time for the change, I usually have to nudge it ever so slighty with a filter wrench before I take it off by hand the rest of the way.
squeech is offline   Reply With Quote
Old 09-19-2004, 11:04 PM   #11
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Same here. I think you really have to way overtighten an oil filter for it to leak.
Mike Wevrick is offline   Reply With Quote
Old 09-20-2004, 10:51 AM   #12
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
I always hand tighten mine, and come time to remove it, I am able to remove the filter by hand. Occasionally I have to use both hands. I've never had a problem with it leaking or coming loose.
Fram makes oil filters with a textured rubber coating on the ends to help increase your grip...handy. Some vinyl or latex gloves keep the oil off your skin as well as provide some extra gripping power.
The one and only time I've had a shop change my oil, I wasn't able to get the oil filter off. Not even with several different types of wrenches. Even the old screwdriver through the filter resulted in a broken #3 philips and still it didn't budge!
I was unable to budge it with a 14-inch pipe wrench. My 30-inch breaker bar with the end-cap style oil filter wrench simply dimpled in the flats on the filter!
I ultimately ended up crushing the metal can with large channel locks until I got a tear in the metal. I then cut the entire outside of the can off using tin snips until only the mounting flange was left. I ended up prying the mounting flange away from the face of the oil filter interface on the car, and using a centerpunch wedged in one of the holes in the mounting flange was able to hammer it around until it finally came loose and I was able to unthread it the rest of the way.
I called up and raised absolute living hell with the shop that changed it. There was absolutely no reason to have torqued it down that tight.
Needless to say, I've changed the oil myself on all my vehicles since then.
-Michael
f4phantomii is online now   Reply With Quote
Old 09-21-2004, 01:47 AM   #13
Rokan211
Member#: 66601
02 Impreza RS
If you get FRAM oil filters they have grips so it's not that hard to unscrew it with your hand. Although I found out the hard way that once you put on borla headers your hand can only touch about 1/4 of the oil filter... so an oil filter wrench is required
Rokan211 is offline   Reply With Quote
Old 09-21-2004, 01:59 AM   #14
squeech
Member#: 38280
2000 2.5RS w/ EJ205
Still do mine by hand after the Borla's (well, minus the stipulations I listed above). But you're right, Borla headers hang down a little farther and do present a little extra challenge for removal
Old 09-21-2004, 11:59 AM   #15
flyingmachine
Member#: 4430
2003 outback
tan/white
Simple trick I've learned from working w/ VWs(not enough room for a wrentch). Tighten w/ your non dominant hand, left for me since I'm right handed, and loosen w/ the dominant hand. Been doing it this way for 10 years w/out problems.
flyingmachine is offline   Reply With Quote
What happens if you dont change the oil filter? tommy2hotty Off-Topic 28 12-04-2006 10:35 AM
What happens if you don't let your engine Warm up in the morning? chillington General Community 112 12-09-2005 07:33 PM
This is what happens if you leave your car at my place for too long.... LotusDriftx Mid Atlantic Impreza Club -- MAIC 11 08-05-2005 09:33 AM
What happens if you grind your starter? SemperFiSti Newbies & FAQs 11 06-11-2004 04:05 PM
High Octane ... what happens if you don't stay with it? :-( makofoto General Community 13 10-28-2002 11:18 PM
