Old 09-19-2004, 12:06 PM   #1
stanghater
Member#: 69381
2005 Legacy GT Wagon
2002 hta green WRX
Default OMG!! *** happened?!?!
so i took my 02 impreza to the Albuquerque national dragway(5000+ ft). The car is bone stock. I was expecting 17 sec et since my probe gt runs 16's. The thing ran 19.2 at 70 mph. Is this normal? It was slightly rainy so the moisture was in the air but that shouldn't make that much of a difference. I think if i would have tried again i couldve gone into the 18's but still. This isnt normal is it?
stanghater is offline   Reply With Quote
Old 09-19-2004, 12:09 PM   #2
Defiantguy
Member#: 41268
2015 WRX
auto or manual? What were your 60' times? Gotta give us more info here.
Defiantguy is offline   Reply With Quote
Old 09-19-2004, 12:18 PM   #3
Slack
Member#: 17548
That is a horrible time, dude. I ran a 16.34 in my 2.2L in 95 degree weather.
Mick
Slack is offline   Reply With Quote
Old 09-19-2004, 12:42 PM   #4
stanghater
Member#: 69381
2002 hta green WRX
I realize that is a horrible time, 60ft was 2.8, 1/8th was 12.33, automatic tranny..... is there something wrong? i have a bumper to bumper warranty... should i take it in and say that i think its not running right and have them check it out?
Old 09-19-2004, 12:49 PM   #5
Stime187
Member#: 32779
'99 Tacoma
LightOfTheWild.com
Originally Posted by stanghater
60ft was 2.8
Thats the problem...
Stime187 is offline   Reply With Quote
Old 09-19-2004, 01:44 PM   #6
stanghater
Member#: 69381
2002 hta green WRX
i can see that 2.8 is a problem, but what is the problem
Old 09-19-2004, 02:26 PM   #7
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
search: lauching auto
RS_to_WRX_swap is offline   Reply With Quote
Old 09-19-2004, 02:59 PM   #8
piker28
Member#: 22664
basically autos are slowwwwww so you will get slowwww times
piker28 is online now   Reply With Quote
Old 09-19-2004, 03:34 PM   #9
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
My car was definitely faster than that stock. Try a few more runs and see if you can improve your 60' times. While you're at it, do a run manually upshifting through the gears, and do another run while powerbreaking. Despite the fact that those two feel faster, I think that you can actually do the best in a 4EAT by feathering the gas pedal to control upshifting.
DrBoy01 is offline   Reply With Quote
Old 09-19-2004, 03:53 PM   #10
Defiantguy
Member#: 41268
2015 WRX
just hold the brake and get the revs up and let off the brake when you see the 2nd yellow light.
Old 09-19-2004, 06:52 PM   #11
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
I don't see this a being reasonable with a 2.5 liter 4EAT. Regardless, the car isn't going to be fast. If for some reason you do try this method, don't power brake very long because you're heating the tranny fluid up.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 09-19-2004, 06:57 PM   #12
piker28
Member#: 22664
^^only way to launch autos, of course he wasnt exactly specific
you want to hold the brake to the floor rev to like 2k and only for a few seconds at most or else what imprezava says you will break axles and your tranny yada yada
and dont do it frequently
Old 09-19-2004, 07:08 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
stock 02 RS auto runs 18.1 @ sea level
Old 09-19-2004, 07:54 PM   #14
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Deleted...arrrgh
Kevin Thomas is offline   Reply With Quote
Old 09-19-2004, 07:55 PM   #15
Kevin Thomas
Member#: 110
1989 1989 XT6
*deleted*
Old 09-19-2004, 08:02 PM   #16
Kevin Thomas
Member#: 110
1989 1989 XT6
No, this is NOT normal. Your 1/4 mile time isn't normal. Your trap speed isn't normal.
I typed out a LONG post and pushed the wrong button and lost it all. So, I'll be brief with this one.
You need to improve your 60ft time to between 2.3-2.4. It's not great but a healthy stock 2.5 auto should be able to do this with it's low end torque. Let the car cool down for 30-45 minutes after you get to the track. Open the hood and let it cool.
Raise your tire pressure all around to the max setting allowable.
You should be expecting mid-high 16s bone stock. Low 17's on a HOT day. Trap speeds expected should be in the low-mid 80's range, not 70mph. Improving your 60ft time will help some but power is being lost.
If you have friends riding in the car with you while you are dragracing, get them out of there. Unload any unnecessary packages, stuff, weight.
Go to the track with no more than 1/4 of a tank of gas. 1 gallon of gasoline equals 5.8 to 6.5 lbs. That's 70-78lbs of weight you can rid yourself of if you are going on a full tank.
Every bit helps. I'm not going to post again about how to launch. I'm at work. If time permits, I'll post up l8r.
Oh, DO NOT USE HIGH OCTANE GAS. I'm talking about 100+. You will be slower. 89 octane should be fine or even 92 (no more) if you wish to use higher octane. I recommend racing with 89 to help raise your timing advance a bit. I know it does because I've tested it on a Pocketlogger. It helps when it's hot/warm out.
Old 09-19-2004, 08:45 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
the auto tranny has you limited...trying shifting it manually and see what happens
Old 09-19-2004, 10:50 PM   #18
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
My manual 1.8 L ran a 17.8... The automatic Toyota Trecel that I actually defeated in that round ran like an 18.1... Its unpossible to run a 19.2 with an RS
Old 09-20-2004, 12:14 AM   #19
rabbitnutz
Member#: 51940
you never put it into 1, then brought up the RPMS till the but byno doesn't feel alot of tourque, clicked it up into 2, brought up the rpms again then shifted into 3, and once you pass the lights, put it in D, coast for a bit, and slow down.....my best time with intake, underdrives, and a Apexn1 was 16.5...and i have .3 less litres than you.
rabbitnutz is offline   Reply With Quote
Old 09-20-2004, 02:30 AM   #20
stanghater
Member#: 69381
2002 hta green WRX
where is this info from?
Old 09-20-2004, 02:31 AM   #21
stanghater
Member#: 69381
2002 hta green WRX
i thought the exact same about the times, should i take it to the dealer? maybe something is wrong with the car, i ask this because we just bought it from the dealer and now im concerned...
Old 09-20-2004, 02:32 AM   #22
stanghater
Member#: 69381
2002 hta green WRX
by the way, half a tank of gas and everything emptied out of the car
Old 09-20-2004, 03:56 AM   #23
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Using the NHRA correction factor for their Stock classes, you're looking somewhere around 0.93 ( http://www.nhra.com/tech_specs/altitude.html ), which means his 19.2 is an altitude-corrected 17.86. Sounds pretty reasonable for a 4EAT with a 2.8 60' time.
As for the trap speed, well, that's just plain old sloooow. Are you sure you kept the hammer down all the way through the trap?
should i take it to the dealer? maybe something is wrong with the car...
Ummmm... NO. Imagine how that conversation would go. "Yeah, I just bought this car from you guys, but when I took it to the drag strip and raced it, it just wasn't as fast as I expected it to be." They'll laugh you out of the building.
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 09-20-2004, 04:02 AM   #24
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
car and driver vehicle comparison
but then again i am sure they weren't brake torquing it
Old 09-20-2004, 04:15 AM   #25
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
note: FWIW a 2002-2004 Auto WRX Wagon runs 16.0, if that gives you an idea of how doggy the Auto really is
with cams and NA work DoctorNick's RS only ran 16.8 @ 82mph
OMG!!!1 SKYLINE!!! omg omg omg omg omg omg omg omg INFIDEL Off-Topic 84 10-11-2006 12:06 PM
Omg Wtf Happened - insurance rates DaKP00r New England Impreza Club Forum -- NESIC 12 06-14-2006 09:04 AM
OmG ! what happened to South Coast Subie's Service Dept? RichQY Southern California Impreza Club Forum -- SCIC 45 09-18-2004 10:57 AM
OMG, what happened ?? (Friday Caption Contest) kpratte New England Impreza Club Forum -- NESIC 30 03-15-2002 01:33 PM
