Go Back   NASIOC > NASIOC Classifieds > Private 'Wanted' Classifieds
Old 09-19-2004, 04:13 PM   #1
Bad Wagon
Member Sales Rating: (17)
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Default STi Drive Shaft, Propeller Shaft ETC..
I need a STi 6MT drive shaft, or if anyone of somthing that will 100% SURE FIT thats would be great. Any information would be great.
Johann
Bad Wagon is offline   Reply With Quote
Old 09-19-2004, 10:23 PM   #2
stirex
Member Sales Rating: (60)
Member#: 17952
I have a brand new USDM 6MT driveshaft for sale.
Which rear diff are you using? JDM/USDM?
stirex is offline   Reply With Quote
Old 09-21-2004, 06:59 PM   #3
rx7turbo1
Member#: 31378
He has a JDM sti trans (6spd) and rear diff(r180). Are they the same bolt pattern as the USDM to your knowledge?
rx7turbo1 is offline   Reply With Quote
Old 09-21-2004, 08:51 PM   #4
stirex
Member#: 17952
they are not the same bolt pattern
you can also use a 4eat driveshaft, afaik
Old 09-22-2004, 12:50 PM   #5
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
4 eat does not work. same length but they do not mate at the diff.
The R-180 is different and it is the rought of my mal content.
USDM STi will fit, thought and I am looking for one so if you gots one hit me up.
Johann
Old 09-22-2004, 03:00 PM   #6
garface
Member Sales Rating: (55)
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
The US STi shaft doesn't fit the JDM diff from what I've heard.
garface is offline   Reply With Quote
Old 09-22-2004, 06:50 PM   #7
stirex
Member#: 17952
correct, its not even close to fitting the 01/02 jdm unit.
check to see if your 5mt shaft has the same bolt pattern.
If it is too small mine should definitely work
edit- you say the auto shaft does not mate, if it needs the larger bolt pattern the one I have will work. I really wish I had my camera right now
Old 09-27-2004, 10:25 AM   #8
stirex
Member#: 17952
any updates?
Feeler: '04 STi Propeller Shaft (Drive Shaft) beaviscih TXIC Private Classifieds 4 11-30-2007 06:44 PM
Turbo vs. Non-Turbo Propeller Shaft Design latinskllz Transmission (AT/MT) & Driveline 3 02-18-2005 09:15 AM
sti driveshaft/main propeller shaft Benjamin Tang Transmission (AT/MT) & Driveline 0 05-07-2004 04:36 PM
Propeller shaft compatability?? Wrx Vs. GC8 sube151 Transmission (AT/MT) & Driveline 7 11-23-2003 02:16 PM
Questions about propeller shaft FederalAuditor Transmission (AT/MT) & Driveline 4 05-14-2003 11:31 PM
