Old 09-19-2004, 07:15 PM   #1
deviseltd
Member#: 51760
Default cutting pinks yay or nay?
O.k. all you PINK lovers and promoters you now who you are.......im going to get then for my sti..i only wish they were a tad lower but everything ive read says they handle greatand are a great suspension upgrade. What if one was to cut, let's say a half of inch to 3/4 of inch off, what do you think would be the outcome.would they handle the same, the spring rate would remain the same??? or would it make them pointless and basically tein s techs at that point.........has anyone ever done this???
deviseltd is offline   Reply With Quote
Old 09-19-2004, 07:27 PM   #2
DILLIGAF Racing
Member#: 29440
2015 WRX
you do not want to cut your springs, period
DILLIGAF Racing is offline   Reply With Quote
Old 09-19-2004, 07:36 PM   #3
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Not a good idea to do. If you want lower, definitely buy something already made lower.
Arnie is offline   Reply With Quote
Old 09-19-2004, 07:39 PM   #4
DILLIGAF Racing
Member#: 29440
2015 WRX
better than cutting. Get a blow Torch out, heat the springs up REAL hot, and push down on that corner, then throw water at them. Instantly lowered.
Old 09-19-2004, 07:44 PM   #5
hyp36rmax
Member#: 24537
2006 LanEVO9 RS
SFVoltron White
hmmm just buy lower springs, if you cut the springs then the integrity of the springs as well as the perrformance will degrade to the point where its not even worth it anymore, why dont you just get some coilovers to get the handling and look, otherwise there are some others such as the prodrives, eibach, tein, and others you can def go for....
hyp36rmax is offline   Reply With Quote
Old 09-19-2004, 07:47 PM   #6
DILLIGAF Racing
Member#: 29440
2015 WRX
oh yeah, if you couldn't tell, I was being sarcastic. NEVER heat springs. Just buy lower springs if you want a lower stance.
Old 09-19-2004, 08:19 PM   #7
Handsdown
Member#: 29355
and cracked
Handsdown is offline   Reply With Quote
Old 09-20-2004, 02:38 AM   #8
moss
Member#: 10197
Where did you come from? I've been told since day one, NEVER CUT SPRINGS. you cut them, you destroy its integrity...
only people i've seen cut springs are ricey honda owners... you're not one of them now are you?
moss is offline   Reply With Quote
Old 09-20-2004, 03:17 AM   #9
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I make fun of my friend daily who has cut spirngs on his integra. dont join him.
RS_to_WRX_swap is offline   Reply With Quote
Old 09-20-2004, 08:49 AM   #10
wrxman02
Member#: 24162
2014 Legacy 2.5i
2012 Impreza 2.0i
no way. they look great the way they are.
later
andy
wrxman02 is offline   Reply With Quote
Old 09-20-2004, 11:07 AM   #11
Siper2
Member#: 1134
2007 BMW 328xi wagon
I'm fairly certain there's some "lowering springs" in the STi pink lineup. They are lower than the standard ones, perhaps??
Siper2 is offline   Reply With Quote
Old 09-20-2004, 05:26 PM   #12
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
Cut springs = Rice
No springs = Fried Rice... mmm... fried rice (drools)
NWWagon is offline   Reply With Quote
Old 09-20-2004, 11:41 PM   #13
AaronWRX
Member#: 7194
2011 997.2 Turbo
contact progress group. http://www.progressauto.com/ give them a call and find out what they have in the works. they make springs with a so-cal style drop. you may need camber bolts to correct your alignment
AaronWRX is offline   Reply With Quote
Old 05-11-2005, 12:35 PM   #14
Pipercub
Member#: 2188
2004 Impreza STI
82 BRAT with 12 in. lift
I agree that 99% of the time cutting springs is just not the way to go, typicaly a honda with stock struts, springs cut in half so you are either bouncing off the bump stops or the struts are totally usless at that spring rate. However, in this case, the STI spring with a mild cut made it exactly what I was looking for. I ran STI V5 struts with P1 springs on my RS-T for about 4 years and was reasonable satasfied. When I got the STI last year the ride height (no I don't want slammed, just an inch and some change lower) and spring rate were a little too soft for me. I bought a set of STI pinks and was really dissapointed, it seemed to have even more front end dive and the ride height didn't drop by much at all. I knew I would not keep these on the car so I figured why not experement with them. I cut off one coil from the bottom, exacty even with the end of the coil using a liquid cooled cutter. On the rear I cut 2/3 of the bottom coil. I re-installed them on the car and after letting them settle and a few hundred miles I am very please to report that the result is ideal. The ride height is just right, about an inch of fender gap is maintained for reference, the car is not slammed and has pleanty of travel left. The spring rate is still well within what the struts can damp yet the front end dive is completely gone, body roll is much less than stock, and the ride quality while firm is not abusive. These springs are now exactly what I was looking for.
Pipercub is offline   Reply With Quote
Old 05-11-2005, 12:38 PM   #15
EntrustXXX
Member#: 79484
04 WRX
you can cut dead coils and not have any problems but from what i remember the front springs don't have dead coils, everyone like to talk **** about cut springs but in all honesty you could cut a half a coil or a coil and you nor anyone would know the difference
EntrustXXX is offline   Reply With Quote
Old 05-11-2005, 12:40 PM   #16
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
my answer: nay nay nay nay nay.
eltrouble is offline   Reply With Quote
Old 05-11-2005, 12:52 PM   #17
narenji
Member#: 12727
Its got internal
combustion ftw!
god, rice is invading the subaru community... just get some tein s-techs... why waste a perfectly good set of sti pinks?
narenji is offline   Reply With Quote
Old 05-11-2005, 01:11 PM   #18
Pipercub
Member#: 2188
2004 Impreza STI
Amazing, results are somehow less valuable than conjecture....... The STI pinks were far from perfectly good, now they are.
Old 05-11-2005, 01:15 PM   #19
EntrustXXX
Member#: 79484
04 WRX
only people how have actually cut springs should be allowed to post about this. i cut a half coil from the front of my scion springs and it's been fine
Old 05-11-2005, 04:29 PM   #20
Vikingmoose
Member#: 50319
2006 STI
Why is that? I've never cut springs on any car, but that is because I know better. I have a BS in Mechanical Engineering and had to take a course on vibrations, which covered a lot about springs. Any mechanical engineer out there will tell you that cutting springs arbitrarily will seriously compromise the springs properties, or as others have said "integrity". Just because you think everything is ok, doesn't mean it is. ALL springs have characteristics and properties based on several things, and by cutting springs you are changing those characteristics and properties. Have you done any calculations before cutting your springs? If I put some basic equations for springs in front of you, I think you'd be surprised how complicated this is.
I don't mean to single you out, this is more of a general comment. But please trust me when I say, "DO NOT CUT YOUR SPRINGS!" Any mechanical or vibration engineer will back me up.
Vikingmoose is offline   Reply With Quote
Old 05-11-2005, 04:36 PM   #21
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
I'm on coilovers so this doesn't apply to me. And I think that I would sell the pinks and buy some shorter springs if I were you...however my question is:
If the spring is linear, not progressive, the spring rate would not change if you cut them, would it?
thrdeye is offline   Reply With Quote
Old 05-11-2005, 06:04 PM   #22
Pipercub
Member#: 2188
2004 Impreza STI
"I don't mean to single you out, this is more of a general comment. But please trust me when I say, "DO NOT CUT YOUR SPRINGS!" Any mechanical or vibration engineer will back me up."
"Any mechanical engineer out there will tell you that cutting springs arbitrarily will seriously compromise the springs properties, "
Very sorry to dissapoint you exactly as you challenged. As a Scientist II for Boeing in the space program I can assure you I have sufficient engineering and scientific credentials and I do not back you up. Of course other than to agree that modifying the springs does comprimise/alter the properties. In this case the end result was desireable with reasonable spring rate and ride height. I understand your doubt as the average spring cutting job is a height based choice and usually the results are as flawed as the planning. But I will not agree that the results I got are somehow invalid because the majority of other results are negative.
Old 05-11-2005, 07:04 PM   #23
Vikingmoose
Member#: 50319
2006 STI
Pipercub-
I don't disagree that good results can be had. But the truth of the matter is most people just cut without thinking about what the results will be, other than their car is now lower. We both agree that modifying the springs does comprimise/alter the properties, but my main point was the fact that if you don't know what you're doing then things may/will not turn out how you wanted.
Did I make myself clearer?
Old 06-06-2005, 10:41 PM   #24
Call_me_Tom
Member#: 60972
^^^Thanks for all of the help. Here are before and after pictures.
Stock Set Up
STI Springs & WRX Struts (Sorry for the bad pic I used a cheap cam that day)
STI Springs & STI Struts (Note Front springs bottom coil cut, Rear untouched)
Call_me_Tom is offline   Reply With Quote
Old 06-06-2005, 10:47 PM   #25
Call_me_Tom
Member#: 60972
Stock Set Up Front
STI Springs Front
STI Spings (cut) STI Struts Front
tint strip on window or no?pics? mud flaps yay or nay? evol04gt Interior & Exterior Modification 20 05-10-2009 01:21 PM
electric cut out? yay or nay? ClutchNY Southern California Impreza Club Forum -- SCIC 15 05-06-2008 02:41 PM
pinks and pump on TD04 - yay or nay FCmaniac Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 10-02-2007 07:30 PM
Pink plates proposed for DUI drivers - yay or nay? Hank3 Off-Topic 65 11-20-2005 10:12 PM
Group N tops with SPT pinks or Prodrives... yay or nay? Davemeister Brakes, Steering & Suspension 2 08-12-2005 10:07 AM
