Old 09-19-2004, 08:25 PM   #1
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Smile My Cobb Stage 2 Dyno #'s and Boost Question
I put down 220/220 on Ultimate Performance's Dynojet on Saturday (scan of the dyno plot is soon to come). According to the A/F ratios measured at the dyno, I'm running extremely rich. I think there is more power that could be extracted from this setup, but right now it's running safe.
I'm running the Cobb Stage II 91 Octane Map
Borla Header
STi Uppipe
Stock Turbo
Stock BPV
Samco IC Hoses
Godspeed Downpipe
SPT Catback
I am seeing a boost max of around 17psi, then tapering down to about 12psi at redline. Is this the same boost pattern that other stage II users are seeing?
Jard is offline   Reply With Quote
Old 09-19-2004, 08:27 PM   #2
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Old 09-19-2004, 08:29 PM   #3
Ironlung
Member#: 52121
2004 WRX
Wow, I've never hit 17psi... i'm at 14 in 2nd and 15.5-16 in 3-5.
Jeff
Ironlung is offline   Reply With Quote
Old 09-19-2004, 08:30 PM   #4
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Does your boost hold that high the whole way to redline...or does it taper down?
Old 09-19-2004, 11:26 PM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Cobb's stuff tends to run rich silly rabbit. Richer is better than leaner. Sadly I didn't make it to that dyno day as I was at the Subaru Challenge. I would like to have met you and had a little wagon vs. wagon dyno session. I'm sure I would put down more than 220 though.
Old 09-19-2004, 11:58 PM   #6
QKWRX
Member#: 66711
01 BMW 330CIC
LMY
What map version are you running?
QKWRX is offline   Reply With Quote
Old 09-20-2004, 12:23 AM   #7
trustWRX
Member#: 40431
2009 Scion XB
COBB's own dynos show 224whp on their website so you're running right about what they claim it puts down so that makes me happy as well although I havent dynoed mine yet.
On the boost question mine hits 15.x then climbs up to 16Psi..holds there for a split second then tapers down. So yeah, it sounds about right.
I want to get mine dynoed soon.
Injen Turboback (no cats)
Stock uppipe w/ cat
GFB 50/50 BoV.
trustWRX is offline   Reply With Quote
Old 09-20-2004, 01:06 AM   #8
SonnyCrockett04
Member#: 48838
2008 Stage 2 STI
A.W.
I'm running stage 2 on 91 octane, gutted uppipe, Godspeed downpipe, and a Thermal catback and I can hit 16.5 PSI in 2nd-5th, tapering to 14PSI only in 2nd. I know it sounds crazy but it wasn't always like this. I've gotten it to run like this only after shortening the wastegate actuator arm a few turns.
SonnyCrockett04 is offline   Reply With Quote
Old 09-20-2004, 01:20 AM   #9
trustWRX
Member#: 40431
2009 Scion XB
Dang that would freak me out. I see my EGT's climb to 1300F and it freaks me out. Today I hit 1400F. The thing that freaks me out is the fact that my EGT probe is in my downpipe so the difference in actual temperature is probably around +200F. So maintaining a high Boost like you would probably blow my car up
Old 09-20-2004, 01:45 AM   #10
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
I just ran my car today, cobb stage 2, 93, v 1.20, up, dp, samco ic hoses. Im hitting a max boost of 15.8 in 3rd and 16.7 in 4th tapering off almost immediately. My EGTs also are fine, never over 1500 and my probe is in the right place. I got 12 1/4 mi runs in today, 80degrees, humid. My best time was 13.8 @97
imprzya is offline   Reply With Quote
Old 09-20-2004, 02:01 AM   #11
SonnyCrockett04
Member#: 48838
2008 Stage 2 STI
A.W.
I dunno I think I got a freak car....probably built on a Tuesday, ;D.
Old 09-20-2004, 02:41 AM   #12
AK*WRX*2004
Member#: 56485
2009 Ram 1500 CC SPT
R.I.P. Bro
Default .
Imprezya , isn't that a little low for the Cobb stg. 2??? I was going to go this path but if those are the regular #'s then i might have to reconsider... Thanks for the info. -Gene
AK*WRX*2004 is offline   Reply With Quote
Old 09-20-2004, 08:11 AM   #13
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I was thinking that I may have to shorten the wastegate actuator arm a little to get it to hold boost to redline, but if it's already doing what it is supposed to, then it's okay. The charts show that I'm not really losing power as it tapers to redline.
I'm running the Stage II 91 Octane v.1.20 map.
I'm surprised I didn't see at least a little gain with the header, but I'm confident it is keeping my EGTs nice and low. I have never seen over 1500 F with the probe in #4 cylinder in the header a few inches down.
Old 09-20-2004, 10:03 AM   #14
TurbojonLS
Member#: 38772
2 Cars, No Bling
Jared - Why aren't you running the 93 Octane map? You have figured out that we have 93 Octane in Virginia, haven't you?
TurbojonLS is offline   Reply With Quote
Old 09-20-2004, 10:06 AM   #15
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I was running the 91 Octane map mostly because I wanted to run the motor as safely as possbile (rich). It's not worth the extra 5hp to me that you get from the 93 Octane map. Also, sometimes I have to use 92 when I am back in PA.
Old 09-20-2004, 11:00 AM   #16
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
It was my first time ever racing, and i didnt have a decent run until about my 5th run. By then, my car was so hot that i was losing power. Also, you can compare it to this, and sti with header back exhaust was running a 13.4 and a vishnu stage 2 rex (like cobb stage 2.5) was running a 13.6, so my 13.8 was good for the hot day at the track.
Old 09-20-2004, 11:29 AM   #17
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
Originally Posted by STiJard
Shouldn't the hood be open w/ a fan blowing on the I/C!?!?!
snvin is offline   Reply With Quote
Old 09-20-2004, 11:32 AM   #18
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
With the hood closed, it's blowing directly into the scoop. There is a much better seal to the IC that way.
Old 09-20-2004, 12:12 PM   #19
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
Where are you located as well? I know down here in South Florida we will run almost half a second slower due to the heat and humidity.
rankink is offline   Reply With Quote
Old 09-20-2004, 12:44 PM   #20
GRNMTNRS
Member#: 7607
04 forester
red granite
Your boost levels are higher than mine as well. I am hitting no higher than 16.5 in any gear. I am running the 93 stage 2 ver1.20.
I want to see what sort of #'s I am putting down soon, as well.
Go Wagons......
GRNMTNRS is offline   Reply With Quote
Old 09-20-2004, 03:32 PM   #21
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
I'm in Wisconsin and we are having record heat. Yesterday we set a record at 85 degrees, and WI is alway humid, usually around 80%-90%. Sitting in rex was like sitting in a sauna, well, plus some humidity. SO yeah, i wanna run again when we finally get back to our normal temps of around 60F.
Old 09-20-2004, 04:31 PM   #22
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
added chart
Old 09-20-2004, 05:04 PM   #23
TurbojonLS
Member#: 38772
2 Cars, No Bling
How rich were you running? Did you get the AFR Printout too? I'm guessing no or you would have posted it too...
Old 09-20-2004, 05:08 PM   #24
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
just added
Old 09-20-2004, 05:43 PM   #25
rankink
Member#: 12901
2005 STi/95 VX
OK, kinda like S. Florida as we are around 85-95 with 90-100% humidity. Waiting another month until I test my stage 2 on the track with better temps and less humidity.
Just went cobb stage 2, some thoughts and questions. SiC Stoner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 03-24-2006 12:18 AM
My Cobb Stage 1 dyno #'s Drews_WRX Engine Management & Tuning 8 07-26-2004 09:12 PM
Cobb stage 1&2 dyno #'s speedypete Forester Forum 4 06-14-2004 12:26 PM
Cobb Stage 2 Dyno sheet AlanWRX Texas Impreza Club Forum -- TXIC 8 12-12-2003 05:36 PM
TurboXS stage 2 dyno #'s using stock muffler? blkwag Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 02-12-2002 07:46 PM
