Old 09-20-2004, 10:27 PM   #1
joenationwide
Member#: 70129
1998 SuBArU foReStEr
wHitE
Default Can I put stock WRX turbo setup on 98 Forester?
I cant get a good answer when I search on turboing the 2.5L so here is exactly what I would like to do:
Buy all stock WRX turbo parts; turbo, TMIC, exhaust, and all stock plumbing to run on my 98 2.5 forester. I want to know will all this stuff bolt up? And what would I need to do to get this to work? Im assuming I need to tune the ECU to retard timing, and run lower boost levels (6-8psi?) since I have a higher CR.
And if this is a feasable idea, what are the little details i would need to work out? Can I run my stock 2.5 NA ecu? Can I run stock 2.5 injectors/fuel pump? How do i run an oil feed/drain line to/from the turbo/engine block?
Ive tried searching the last couple days and I haven't found any clear answers. Also, no one has seemed to ask about this particular setup. Please help. Ive already got the wrx suspension, now I want to know if i can turbo it (CHEAPLY and RELIABLY).
thanks
scott
joenationwide is offline   Reply With Quote
Old 09-20-2004, 10:49 PM   #2
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Have you tried searching the Aftermarket forced induction forum?? Your engine is the same as the 98 RS. There are many people running this setup.
BTW, crossposting is bad mmmkay.
Old 09-20-2004, 11:30 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
put short yes you can...do some searchs and learn some...you wil also need a turbo crossmember to use all of the WRX's exhaust because of the manifold and uppipe...
Old 09-22-2004, 11:12 PM   #4
joenationwide
Member#: 70129
wHitE
Sorry for the bad ettiquitte with the crossposting....
OK I'll try to search some more.
But while Im here......Has anyone done this to their 2.5, or know of some links that has some info on this?
thanks
Old 09-23-2004, 09:57 AM   #5
linux>windows
Member#: 49517
we're up to 70k
linux>windows is offline   Reply With Quote
Stock WRX Turbo Setup and TGVs Turbo_Twinky NWIC Private Classifieds 7 06-19-2009 10:45 PM
Can you put 2002 WRX fog lights on a 98 2.5 RS?? Jin_WRX Electrical & Lighting 1 06-25-2008 11:22 AM
wrx wagon sways on 98 forester? hybrid gti 2 Brakes, Steering & Suspension 8 11-27-2007 01:20 PM
Can I put stock WRX turbo setup on 98 Forester? joenationwide Subaru Conversions 2 09-30-2004 01:19 PM
Looking for a stock wrx turbo setup plus parts! bambams247 Private 'Wanted' Classifieds 4 08-31-2003 04:07 AM
