Old 09-21-2004, 01:36 AM   #1
012.5rst8
Member#: 44642
01 Turbo 2.5rs
Rally Blue
Impreza GC8 Need Help Bad
my 2001 2.5rs was having prolems misfiring on cylinder 2 and 4. So i did the easy thing ngk iridiums and magnecor wires, my check engine light dissapeared for about 2-4 days and then reappeared setting misfires on all 4 cylinders, is my coil pack bad or are the horror stories about magnecor causing coil pack problems coming true, Id appreciate any help or feedback. Thanks, Derek.
012.5rst8 is offline   Reply With Quote
Old 09-21-2004, 10:23 AM   #2
Mumbles
Member#: 248
Sound like the coil pack. That would pale in comparison if your head gaskets were gone and fouling the plugs.
Mumbles is offline   Reply With Quote
Old 09-21-2004, 10:40 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
could also be the magnecors .. they have a poor design and tend to slip off the spark plugs. try stock wires
Old 09-21-2004, 10:56 AM   #4
Mumbles
Member#: 248
Magnecors are just fine. If they ever slip you just get a pair on pliers and clamp them a bit. Adjustment no big deal. They are not a poor design.
Old 09-21-2004, 07:47 PM   #5
012.5rst8
Member#: 44642
01 Turbo 2.5rs
Rally Blue
Impreza GC8
thanks i will try the coil pack anyone know where i can get an aftermarket one? by the way my headgaskets were leaking i replaced them with metallic gaskets and then had a mis fire on cylinders 2 and 4 and i got ngks and magnecors added those and the light went away for a few days then came back with all cylinders misfiring i think its the coil, i need to get this fixed i have all parts for my turbo kit and am waiting to solve the misfire problem. thanks to everyone for your imput.
Old 09-21-2004, 08:17 PM   #6
Siper2
Member#: 1134
2007 BMW 328xi wagon
Maybe not poor, but wires sometimes coming off doesn't sound like a great design... You shouldn't ever have to crimp an ignition wire to get it to stay there.
I don't know, I haven't read great things about Magnecor, around here.
Try Exeter Subaru for the coil pack: www.subaruwrxparts.com
Siper2 is offline   Reply With Quote
Old 09-22-2004, 01:48 AM   #7
012.5rst8
Member#: 44642
01 Turbo 2.5rs
Rally Blue
Impreza GC8
thanks
Alaskan Needs Help!!!! Badly!!!!! rex02 Tri-State Area Forum 11 10-05-2003 09:14 PM
Need Help BAD!!! WRXGuyInUSA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 61 04-16-2003 12:01 AM
i need help bad ???? bruno Brakes, Steering & Suspension 2 02-19-2002 06:05 PM
Car still burns oil. Need help badly. Oil catch can solution? Andrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 06-21-2001 05:00 PM
