Old 09-21-2004, 02:44 PM   #1
rhdude
Member#: 6637
2009 Acura MDX Sport
Default Hard starts- '98 2.5RS
Ok, well my car has been at the shop getting a new motor for a few months now, and I am close to getting it back. Problem is, The car has really hard starts, but as soon as it comes to temp, it runs fine. The tech said the fuel pressure is at 28-30psi at start up, and a little more at idle. It idles fine, just has hard starts. He said its not the fuel filter, and we put in a RS fuel pump, and a new WRX fuel pump, neither one solved the issue. He is looking into the injectors to see if they are somehow clogged. Does anyone else has any ideas of what may be wrong? I'm starting to second guess the tech's way of reasoning. A local guy mentioned that the impreza may have a cold start injector, is that true? Could that be causing it?
Thanks in advance,
Brian
rhdude is offline   Reply With Quote
Old 09-21-2004, 08:06 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
so the fuel pressure is low or high? have you checked lines and rails? I take it the injectors are going to be getting cleaned?
Old 09-21-2004, 08:51 PM   #3
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Fuel pressures are what I'm seeing during daily driving. I don't think the issue is there.
I'd be guessing more along the lines of the injectors or spark plug wires at the very longest shot. Maybe purchase one of those injector cleaner fuel add in, as I don't think you can take those out and scrub them off with a toothbrush or something (but I may be wrong about that).
Any thoughts on the starter motor as well? What about the electrical system, is that getting the starter enough current to get things moving properly?
I don't know really, just tossing ideas out there.
AJ
AJ711 is offline   Reply With Quote
Old 09-21-2004, 09:55 PM   #4
rhdude
Member#: 6637
Turns out its an electrical issue in the injector relays, they are'nt functioning as they should. He will be looking into it tomorrow. I may need a new ECU, but I can score one for $150...
spotted, green '98 2.5RS RidinLow Tri-State Area Forum 35 01-16-2002 05:53 PM
Blondie in '98 2.5RS Sighting... Ovaltine Vancouver Impreza Club Forum -- VIC 4 08-22-2001 09:44 PM
'98 2.5RS For Sale in Tampa! Opie South East Region Forum 1 07-12-2001 09:05 AM
For sale: '98 2.5RS couple FstrMnky Mid West Subaru Owners Club Forum -- MWSOC 1 06-11-2001 12:04 AM
Attn: All '98 2.5RS Owners - Survey Trey General Forum Archive 44 10-12-2000 04:55 PM
