Old 09-21-2004, 03:45 PM   #1
alpinelegacy
Member#: 69431
2001 Legacy Sedan
GT Ltd Conversion
Default '01 Legacy...exhaust options?
Hey guys,
I'm working with a stock '01 Legacy L Sedan. I need more power, but don't have the cash to go out and pick up something like an '01 2.5 RS or something like that, so I'm just gonna stick with what I got and make it decent.
I'm investigating Borla headers (part #17183), an Injen cold air intake (part #RD1210P), and a K&N air filter (Part # 332154). Any suggestions for a decent catback exhaust system? I'm looking for something with a nice and deep sound, but not very loud. Any suggestions?
alpinelegacy is offline   Reply With Quote
Old 09-21-2004, 04:26 PM   #2
Lukass
Member#: 66880
03 2.5 RS
Platinum
If you want power, stay away from borlas. A lot of people here boast about stromung for power and sound but it gets kind of expensive. If you want all out power, get MRT. if you like sound though and really don't car about performance, get borlas. As far as an intake goes, get a ganzflow, they are cheaper than and injen and from my experience give you top end and retain bottom end.
LUKE
Lukass is offline   Reply With Quote
Old 09-21-2004, 04:35 PM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
FYI your Legacy has the same power as an RS. Try a WRX axleback+custom straight pipe+Brullen headers for a cheap exhaust setup w/ significant power gains.
jamesfacts is offline   Reply With Quote
Old 09-21-2004, 04:39 PM   #4
alpinelegacy
Member#: 69431
2001 Legacy Sedan
GT Ltd Conversion
so anything I find for a 2.5RS will work on my engine? granted if the year is right
Old 09-21-2004, 09:32 PM   #5
Chi_San
Member#: 53558
2002 WRX Wagon
Incorrect. Well, in a way. Remember, the underside of the actual car is different between a Legacy and an Impreza.
I'm gonna get a Cobb racing cam, probably a decent axle back exhaust, and a Cobb CAI for my '00 Legacy L Sedan.
Chi_San is offline   Reply With Quote
Old 09-21-2004, 09:58 PM   #6
iON Performance Inc
Vendor
Member#: 7673
alpinelegacy - We offer a cat-back exhaust for the BE & BH body styles. The following are just two examples. 1st being single 3.5" tip and 2nd being 4".
Drop us a PM or email for more info.
Forgo the Borla headers; you'd get more out of a hi-flow cat replacement.
iON Performance Inc is offline   Reply With Quote
Old 09-22-2004, 05:41 PM   #7
omahasubaru
Member#: 1594
1995 WRX
2011 WRX
Ion... quit whoring my wife's car! j/k
How about you run some newer/improved pictures?
Here's a couple exterior ones just for good measure
*click any of them for a larger version
omahasubaru is offline   Reply With Quote
Old 09-23-2004, 12:41 AM   #8
METHOD757
Member#: 58143
2000 LEGACY GT LIMIT
BRONZE
i did it the cheap way i went to mideke or however you spell it and had a custom pipe form my cat back with a performance muffler with a 4 inch tip and i gained about 8 hrs not much but it was only 100 bucks
METHOD757 is offline   Reply With Quote
Old 09-23-2004, 11:58 AM   #9
alpinelegacy
Member#: 69431
2001 Legacy Sedan
GT Ltd Conversion
IC, now what exactly is to be gained by installing a catback system? I know there's an audible difference and also a performance boost, but how much of a boost should be expected for this vehicle?
Old 09-23-2004, 03:31 PM   #10
iON Performance Inc
Vendor
Member#: 7673
alpinelegacy - Power gains all depend on whether or not you have other performance components (ie: headers, hi-flow cat, cams, intake, engine management). On the EJ25 motors the average gain is between 4-7whp gains. [for 2.25 piping]
Old 09-23-2004, 04:15 PM   #11
alpinelegacy
Member#: 69431
2001 Legacy Sedan
GT Ltd Conversion
so what happens when you increase the piping size? lets say 3" (hypothetically of course)
You say EJ25...I thought the Legacy sedan had an EJ253?
Old 09-23-2004, 11:50 PM   #12
Chi_San
Member#: 53558
2002 WRX Wagon
My '00 Legacy Sedan has EJ251.
If you were to go to 3", you would get really high flow, but since you're NA, you will have almost no torque at all. NA engines get torque from backpressure in the exhaust system. 2.25" would be about the largest you would want to go, which also happens to be about the smallest you would want on a FI setup.
Old 09-24-2004, 01:44 AM   #13
iON Performance Inc
Vendor
Member#: 7673
omahasubaru - Lookin' good
alpinelegacy - Unless you're going turbo, 3" is WAY overkill. N/A's operate on the principle of EGV (exhaust gas velocity). If you plan on staying N/A; 2.25" is the largest size you want to go on the street (unless you're building a crazy N/A motor and doing track; which which case 2.5" is more suitable).
EJ25 is the general designation for the 2.5L EJ series motor.
Chi_San - 'tis not backpressure it's EGV which is required to make power.
Old 09-24-2004, 09:36 AM   #14
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
side note:
is 2.5" not the way to go for a normal everyday driver?
is it really too large?
is the difference between 2.25" and 2.5" going to be that noticable (other than the loudness) powerwise?
I'm asking because i'm looking into exhausts myself.
anyone got a used one for sale?
iamrazor is offline   Reply With Quote
Old 09-24-2004, 09:56 AM   #15
nySulli
Member#: 32617
2008 STi
http://cobbtuning.com/legacy/
brullen is some great stuff, but just so you see all of your options check out cobb
nySulli is offline   Reply With Quote
Old 09-24-2004, 12:07 PM   #16
alpinelegacy
Member#: 69431
2001 Legacy Sedan
GT Ltd Conversion
So, if 2.25" gives you more low-end torque than a 2.5", what would the pluses/minuses or going to a 2" system?
@Chi_San - do you know what exactly differs between the EJ251 and the EJ253?
Old 09-24-2004, 12:25 PM   #17
DreddRS25
Member#: 51642
2001 Impreza RS
BRP
Stock diameter is 1 7/8" so going to 2.0 will not yield much of a difference.
I have a custom 2.25"MP+WRX axleback and my RS has a little more pep.
DreddRS25 is offline   Reply With Quote
Old 09-24-2004, 12:51 PM   #18
alpinelegacy
Member#: 69431
2001 Legacy Sedan
GT Ltd Conversion
Thanks a million for all the explanations guys...sorry for being such a complete neophyte!
I know that a catback system replaces everything from the catalytic convertor and back, but where does the axekback system start/finish and what parts does it include/not include in a catback system?
We've also agreed that a 2.25" catback system would be the most beneficial, but the screenshots ION posted earlier are 4"....is that just the tip or the whole system?
Old 09-24-2004, 01:08 PM   #19
nySulli
Member#: 32617
2008 STi
the systems 2.25", as for going to 2", the problem is the backpressure begins to restrict the exhaust flow, the to any good NA exhaust is to keep exhaust gas velocity as high as possible, to big a pipe, and things really slow down, and don't allow the previous exhaust pulse to help pull the current pulse down the exhaust, again, to small a pipe, and things can't flow smoothly, theres just to much gas trying to fill the same space, and flow is less then optimal
axel back replaces just that, the axel back section, if you look under the car, you'll see where the stock midpipe ends and the axel back section begins, its basically the muffler plus the pipe that snakes around the axel to the midpipe, and ends at the stock location, since the axel back section is the most costly portion anyways, i think its well worth it just to get the whole cat back system
Old 09-24-2004, 01:59 PM   #20
iON Performance Inc
Vendor
Member#: 7673
alpinelegacy - It's the tip size that the 4" is referring to. Our N/A cat-backs are available in both 2.25" or 2.5".
Old 09-24-2004, 02:07 PM   #21
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
iON - I think i've asked before, but whats your pricing look like?
Old 09-24-2004, 02:16 PM   #22
iON Performance Inc
Vendor
Member#: 7673
iamrazor - pricing isn't allowed to be posted on a technical thread. please contact us via PM or email. Pricing depends directly on piping diameter and the # of tips etc.
Legacy 2.5i exhaust options rs2.5-3.0 Normally Aspirated Powertrain 10 04-05-2008 01:55 PM
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
95 legacy exhaust options sick1.8t Legacy Forum 8 01-16-2006 10:50 AM
Legacy exhaust options subette Normally Aspirated Powertrain 21 08-06-2001 08:44 AM
'01 Legacy GT owners...how do you like your cars? mvb Legacy Forum 7 06-08-2001 05:08 PM
Message Board Statistics All times are GMT -4. The time now is 10:55 PM.
