Old 09-21-2004, 09:20 PM   #1
Thrilryder
Member#: 33542
2004 Wrx sedan
Unhappy I think my motor is dead
Well on my way to a friends house I started to hear a awfull noise coming from the engine. Actually sounds like loose change in the motor. Im thinking something on the bottom end broke, rod bearings? main bearings? Well I took the car to my local dealer to see if some chance I could be covered under the 5/60k powertrain warrenty, well of course I was denied due to my downpipe and exhaust, and turbo timer, they also said that there was once a blowoff valve on the car, which isnt true. Can I fight this?? If I have to pay out of pocket for this, how bad is the damage? Will I need a new block? If I can get the $$$ together I may go for the COBB 2.2 Stroker Kit ($2750) Wha kind of power would I expect to gain over just rebuilding back to stock? Will I need a form of engine management to take full advantage of .2 liters of displacement? Any and all advice from the people who have gone through the same thing will be very apreciated!
David
Thrilryder is offline   Reply With Quote
Old 09-21-2004, 09:57 PM   #2
kedrin
Member#: 48380
what exactly did they say was wrong with your engine?
kedrin is offline   Reply With Quote
Old 09-21-2004, 10:37 PM   #3
Thrilryder
Member#: 33542
2004 Wrx sedan
Well they pretty much did just a quick diag., didnt break the motor down or pull the engine pan. Im thinking that it just may be a bearing issue, b/c the motor would still run, but it just sounded like something broken and making metal grinding noises.
Old 09-22-2004, 12:05 AM   #4
my02turboWRX
Member#: 68448
2008 WRX STi
Cobb tunned by Surgeline
well it just cost me $1200 to get my car running after breaking a piston and bending a rod
short block
gaskets
fluids
parts
so to me its not expensive to fix the motor if the dont cover it
peace
my02turboWRX is offline   Reply With Quote
Old 09-22-2004, 05:02 PM   #5
Thrilryder
Member#: 33542
2004 Wrx sedan
bump
Old 09-22-2004, 05:45 PM   #6
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
I would protest the denial, or try an different dealer. They can only deny repairs if the parts caused or contributed to the damage.
bofh is offline   Reply With Quote
Old 09-22-2004, 06:25 PM   #7
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
screw the 2.2 stroker. get a USDM STi 2.5 block! upgrade the turbo, pump and injectors. get some management and you're good to go
ZoomnWRX is offline   Reply With Quote
Old 09-22-2004, 06:35 PM   #8
morphgabbin
Member#: 15466
2002 wrx
can't be sure what's wrong without seeing the car, but if it's the block I'll sell you another one for $400.
morphgabbin is offline   Reply With Quote
Old 09-22-2004, 07:59 PM   #9
jesse370
Member#: 12147
2005 g-35
ivory pearl
Go to the vendors section and buy a ver7 shortblock for a grand and be done with it.
jesse370 is offline   Reply With Quote
Old 09-22-2004, 11:00 PM   #10
zaxrex
Member#: 9898
Water Injected Blue
Sell me your heads...
zaxrex is offline   Reply With Quote
Old 09-22-2004, 11:09 PM   #11
Antyoo
Member#: 64161
2004 WRX
David
i would have put the car back to stock
and what made them say that the car had a BOV?
to get the best out of a stroker kit, you will need to re map the ecu for a 2.2 liter engine.
Antyoo is offline   Reply With Quote
Old 09-23-2004, 02:02 AM   #12
Thrilryder
Member#: 33542
2004 Wrx sedan
Is it better to get a ver7 over a ver8??
Old 09-23-2004, 08:03 AM   #13
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
The short blocks are basically the same. Your heads will bolt right up.
Zackbo is offline   Reply With Quote
Old 09-23-2004, 10:46 AM   #14
Thrilryder
Member#: 33542
2004 Wrx sedan
Isnt the Ver8 short block a 2.5?
Old 09-23-2004, 11:09 AM   #15
zaxrex
Member#: 9898
Water Injected Blue
no..
I think my AP2 is dead MB38 AccessPort 20 09-21-2008 03:49 AM
I Think My Utec Is Dead? RickDaTuner UTEC 1 05-05-2006 09:30 AM
Need help, think my unit is dead... can i play with yours? blitz WRX-pilot Southern California Impreza Club Forum -- SCIC 9 04-30-2004 04:37 AM
I think my car is dead, jim. ctwrxwagon General Community 2 01-08-2004 12:58 PM
My motor is dead..... STiShawn Mid West Subaru Owners Club Forum -- MWSOC 27 08-18-2001 02:45 AM
