Old 06-18-2001, 11:22 AM   #1
mcv9802
Member#: 6597
2002 Impreza WRX
Sedona Red Pearl
Default Quick disconnect battery
Next month I'm going to be moving into Georgetown in DC and have a few concerns about security. One of the ideas I had was getting a quick disconnect setup for the battery and taking it out every night. Also remoting it to the trunk for easy access. My question is have any of you done this and if so what are the pros and cons. Is it effective. What about a killswitch that shuts off all electrical components. I also have a sidewinder alarm and the Autolock, but you can never be too safe. THanks for the input.
mcv9802 is offline   Reply With Quote
Old 06-18-2001, 03:25 PM   #2
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
I would just put realys on the power for the starter and fuel pump and wire them to your alarm. Taking the battery out every night will be a real hassle.
Chuck is offline   Reply With Quote
need quick help! disconnected battery, car not running normally anymore NMZ_WRX Newbies & FAQs 9 12-20-2009 09:52 PM
disconnect battery mainerex Newbies & FAQs 16 12-06-2004 02:06 PM
Necessary to disconnect battery for ECU swap? garface Factory 2.0L Turbo Powertrain 10 09-17-2004 01:35 AM
Going out of country for 1 month... need to disconnect battery? Poe Factory 2.0L Turbo Powertrain 7 06-10-2002 01:52 PM
disconnect battery, but keep power to ECU? bemani Factory 2.0L Turbo Powertrain 1 04-04-2002 01:00 AM
Message Board Statistics All times are GMT -4. The time now is 12:57 PM.
