Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 09-22-2004, 02:58 AM   #1
ghostfoot7
Member#: 61040
dead sexy blue!
Default Excessive driver side window wind noise
Does anyone else have a lot of wind noise on the driver side window when driving? Anyone have any remedy for this? Thanks.
ghostfoot7 is offline   Reply With Quote
Old 09-22-2004, 10:38 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
If you're under warranty, have the dealership adjust or replace the gusset at the front edge of the door. If you are not under warranty, adjust it yourself.
Brian
Old 09-22-2004, 01:31 PM   #3
ghostfoot7
Member#: 61040
dead sexy blue!
Unfortunately not under warranty... have no idea what a "gusset" is...sounds like what a fat english prince would wear. No idea how to adjust said item of clothing... Intend to check internet... Can't seem to type in full sentences...
Thanks captain...
Old 09-22-2004, 01:54 PM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
You can try to lubricate the rubber seals with some silicone. They get dry after a while and the silicone helps to soften them back up. I use Pyroil Silicone spray.
Calvin
cnk is offline   Reply With Quote
Old 09-22-2004, 02:05 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
The gusset is the piece that is opposite the base of the exterior rearview mirror. It is slightly adjustable, and is most often the cause of wind noise in the cabin on the newer models (older models it was the outside mirrors making noise).
Brian
Old 09-22-2004, 11:19 PM   #6
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Ghetto solution: Lower your driver's side window completely and open your door. Locate the little triangular rubber/plastic piece near the base of your sideview mirrow and squeeze the top of it together gently. It seems that this little rubber "triangle" that forms a seal around the glass sometimes gets deformed. When the gap is wider than the pane of glass, it causes wind noise.
It may not seem like a technical solution, but it works very well given that your wind noise is actually coming from that area.
BJamerican is offline   Reply With Quote
Old 09-23-2004, 02:28 AM   #7
ghostfoot7
Member#: 61040
dead sexy blue!
Thanks to all for the help...I'll give it a shot!
Old 09-26-2004, 05:33 PM   #8
lalaporter
Member#: 32946
2013 WRX Hatchback
white
Lightbulb Wind noise
I started getting wind nose on the rear of the driver side front window. Several days later the window would not close. Turned out two of three bolts that hold the power window motor in place fell out. Fixing that also fixed the wind noise.
lalaporter is offline   Reply With Quote
'04 Wind noise in driver side window! zacek Interior & Exterior Modification 26 05-01-2007 06:47 PM
2002 Legacy L Driver's Side Mirror Wind Noise cMags Legacy Forum 5 10-27-2005 06:47 PM
('93-'01) Wind noise, coming from drivers side window?? impresivesoob Impreza Forum 3 02-27-2004 06:28 PM
Noise at drivers side window Icon25rs Service & Maintenance 5 09-23-2002 04:39 PM
