Old 09-22-2004, 09:07 PM   #1
evorev
Member#: 39836
95 subie L
maroon & mud
Default 1.8L oil capacity?
hey, i'm doing an oil change... does anyone know what subaru says is the correct oil capacity for a 1.8L ???
thanks,
-brett
evorev is offline   Reply With Quote
Old 09-22-2004, 09:27 PM   #2
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Best bet would be to check the owner's manual. It will tell you directly in there.
AJ
AJ711 is offline   Reply With Quote
Old 09-22-2004, 11:07 PM   #3
Ice Master
Member#: 44662
2002 2.5 TS
Numbers are not from me:
Web site
1995 Subaru Impreza L 1.8L:
ENGINE CRANKCASE:
4.2 qt's (About 4.5 in my car)
MANUAL TRANSMISSION:
3.7 qt's (AWD) 2.7 qt's (FWD)
AUTOMATIC:
8.4 qt's (AWD & FWD)
REAR DRIVE AXLE:
.8 qt
FRONT DRIVE AXIL:
1.3 qt's
GAS TANK:
13.2 gal
COOLING SYSTEM:
6.2 qt's 3.1qt's to 3.1qt's water 50/50
I asume you that you are changing the oil in the crankcase. With an old engine you might have to put more. start with a bit more than 4 quarts check your volume and then start your engine adjust it with the dipper. Dont forget to put your drain plug back, i had a bad experience.....
Ice Master is offline   Reply With Quote
Old 09-23-2004, 10:42 AM   #4
DoinkMobb
Member#: 3787
2008 Gay
Car
I used about 4.5 qts in my '95.
DoinkMobb is offline   Reply With Quote
95 1.8L oil leak (having trouble getting the pump off) DreadyRider Newbies & FAQs 2 05-05-2010 09:54 PM
'93 1.8L oil pres./amp/water temp gauge install? sick1.8t Interior & Exterior Modification 0 08-05-2002 02:06 AM
1.8L oil spill Hawk296 Normally Aspirated Powertrain 6 02-26-2002 06:33 PM
WRX oil capacity harrydog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-30-2001 07:59 PM
Oil Capacity [Q] Peaty General Forum Archive 8 02-24-2001 12:53 AM
