Old 09-22-2004, 09:29 PM   #1
bigpaulo
Member#: 17655
2002 Impreza TS
low profile green
Default how much can you overfill oil before foaming occurs?
Yes, yes, I'm well aware of the dangers of too much oil... PCVs that suck up ungodly amounts of oil, blown seals, high oil consumption, foaming and apocolypse
However, it makes logical sense that, as long as the crankcase isn't frothing the oil at startup, having as much oil in your crankcase as possible will help it last longer and stay cleaner... seeing as how when the engine is under way, a good amount of oil is circulating around the engine and is not sitting in the oil pan, so the oil level while running is actually quite a bit lower than at startup.
So, does anyone know how much you can safely overfill a MY02 TS? Or any other late model Subaru variant?
bigpaulo is offline   Reply With Quote
Old 09-23-2004, 12:17 AM   #2
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
You'd probably be safest sticking to the rated capacities. You can safely go over by a little, but I wouldn't purposely do it.
Al_Smokemcrack is offline   Reply With Quote
Old 09-23-2004, 12:42 AM   #3
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
Unless yer car iz smokin like a diesel truck w/bad injectors.....
HeyChris is offline   Reply With Quote
Old 09-24-2004, 09:26 AM   #4
bigpaulo
Member#: 17655
2002 Impreza TS
low profile green
Default bump once...
bump once...
Old 09-24-2004, 10:46 AM   #5
jamesfacts
Member#: 51282
98 RS
black & blue from parking
PM davenow.... I think he once said 1/2 qt or so.
jamesfacts is offline   Reply With Quote
Old 09-24-2004, 12:27 PM   #6
DreddRS25
Member#: 51642
2008 WRX
I've had about a half-quart to much before. However my car burns about that much over 1500-2000 miles so it wasn't too bad. Though I don't recommend leaving it overflowed if possible to drain some out easily.
DreddRS25 is offline   Reply With Quote
Old 09-24-2004, 07:30 PM   #7
pooparu
Member#: 59750
1999 Jaguar XJR
blacker than your soul
I've put in 1/2 a quart over before and it had no dire effect that i could see. However i did go over by a quart in my old car (mercury mistake) and that led to several costly problems. unless you are burning/leaking like crazy I would stick to the factory numbers.
pooparu is offline   Reply With Quote
Old 09-25-2004, 07:08 PM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
I have an '02 Forester. The recommended is 4.2 quarts, but I just throw in 5. I've had the car since February and have changed the oil several times. I have yet to find a reason to not just put in an even 5 quarts.
Now you do bring up some interesting bad and good things that can occur if you go a little overboard with the oil. I'd like to add one good aspect that you didn't mention. Engines with a higher oil capacity run cooler, just thought I'd add that
Old 09-26-2004, 07:58 PM   #9
HeyChris
Member#: 2234
2013 F-XT
It would seem to make sense on an ecological manner to make it an even amount of oil... i.e. 5quarts... Since the wonderful Erle [oil] companies sell them by the quart. That way there's nothing wasted.... Or add an external oil cooler to make more volume of oil req'd... Just babbling out loud...
Chris.
Old 09-26-2004, 08:07 PM   #10
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
I overfilled my lawnmower with oil, seemed to mess it up. On steep grades oil got pushed into the piston (I think) and oil started burning. Got pushed into the exhaust and stayed there so whenever it heated up it would smoke slowly. I took the exhaust apart and cleaned it out and its all good now, but I bet big money that that wasnt good for it.
Trunk_Monkey is offline   Reply With Quote
Old 09-26-2004, 09:54 PM   #11
STi-MAN
Member#: 70252
05 STI
blue
dont over fill ur oil, foaming of oil is REALLY REALLy bad for ur car.
STi-MAN is offline   Reply With Quote
Old 09-26-2004, 09:54 PM   #12
chip4761
Member#: 55867
2005 Saabaru
AS
I overfilled my oil and my oilpan gasket blew out. The woman at the toll booth said, "You need some water." I said, "Oh? Why's that?" She replied, "Because your car is on fire." Fun times. I would try to avoid that if I were you.
chip4761 is offline   Reply With Quote
Old 09-27-2004, 11:43 AM   #13
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
hah
nice one chip
my gl was over by about a half qt
it would randomly smoke like NO OTHER
id be going down the freeway BOOM huge cloud of smoke hahaha the engine would also knock it sounded like when it would happen but i dont know how thats possible on a 1.8garbage engine
How much can YOU drink before you blow over the limit? find out! lol Defiant Autospeed Texas Impreza Club Forum -- TXIC 43 09-09-2008 12:24 PM
How long can you hold it before........... The_Triton Off-Topic 12 07-20-2004 01:36 PM
how much can you save each much ? PKduck Jr Off-Topic 26 02-14-2003 10:18 PM
how much can you safely turn up the stock turbo cronic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 10-10-2001 03:42 PM
How much can you lower with 18's? wrknrott Brakes, Steering & Suspension 2 08-10-2001 07:01 PM
