Old 09-22-2004, 09:38 PM   #1
Brandon Clifton
Member#: 68965
1994 Touring Wagon
1995 Legacy L
Unhappy Help! need factory turbo PCV routing
I have a aftermarket turbo'd 2.2L and would like to know what the factory turbo PCV routing looks like.
My car, stock
*both valve covers into intake pipe between filter and throttle body
*crankcase vent splits off, one side goes into intake pipe between filter and throttle body, one side goes thru PCV into manifold between throttle body and heads
My car, currently
*both valve cover breathers and crank case breather all tied together and go into intake between filter and turbo inlet
Your factory turbo car, stock
*driver's side valve covers goes ______________
*passenger's side valve cover goes______________
*crankcase vent goes _______________
Thanks in advance!
[email protected]
Brandon Clifton is offline   Reply With Quote
Old 09-22-2004, 10:25 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
there is a thread on this in the afi forum. since lots of those guys use the ej22T block. there is also some heavy discussion at bbs.legacycentral.org
subiekid is offline   Reply With Quote
Old 09-23-2004, 06:21 AM   #3
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
It doesn't really matter as long as all three have positive ventilation, ie; go to a place of negative pressure. All three of mine are fed into a catch can and then to the turbo inlet.
Kent
wrx plus is offline   Reply With Quote
Old 09-23-2004, 01:08 PM   #4
Brandon Clifton
Member#: 68965
1994 Touring Wagon
1995 Legacy L
How much oil do you get in your catch can per mileage? I think I gathered about 1 ounce in 100 miles.
Old 10-14-2004, 02:07 PM   #5
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
vrg3 is offline   Reply With Quote
Help needed with turbo lag and steering. didirey001 Newbies & FAQs 11 11-18-2008 06:15 PM
HELP need cheap turbo tomorrow!!! selvar05WRX NWIC Private Classifieds 7 02-23-2008 01:49 PM
HELP NEEDED! perrin turbo inlet. NerdyAlaska Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-17-2006 06:36 PM
Help! Need factory '01 muffler projectrally New England Impreza Club Forum -- NESIC 17 07-10-2004 01:40 AM
Help! Need new turbo ASAP fastfood North West Impreza Club Forum -- NWIC 11 08-22-2003 01:24 PM
