Old 06-18-2001, 04:18 PM   #1
czo79
Member#: 6752
Default redline synth gear oil
I know people have covered this...but is the correct redline oil to run in a 5spd (97 legacy 2.5 GT) the 70w90NS? I have been unable to get the search function to work....
Thanks
Micum
czo79 is offline   Reply With Quote
Old 06-18-2001, 04:25 PM   #2
CSM101
Member#: 2805
2001 Impreza 2.5RS
BRP
Yes.
CSM101 is offline   Reply With Quote
Old 06-18-2001, 04:31 PM   #3
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
yes, use "NS" in tranny only.
Albert is offline   Reply With Quote
Old 06-18-2001, 06:37 PM   #4
cvalle-sd
Member#: 420
2001 Cr-V
I used 3 qt. NS w / one quart Lt. Shockproof. I may try a 50/50 mix. I do a lot of heel/toe and blip-throttle downshift, so I like the idea of better metal-to-metal prevention.
cvalle-sd is offline   Reply With Quote
Old 06-18-2001, 07:36 PM   #5
HomerJay
Member#: 1135
2005 WRX WAGON
I don't know about the legacy, but a lot of RS owners have had problems with Redline being too thin and have resorted to mixing with a heavier weight to avoid the problem.
-JOE
HomerJay is offline   Reply With Quote
Old 06-19-2001, 11:18 AM   #6
EchoWrx
Member#: 4101
2000 Impreza
Talking What I use...
Use lighter fluid U have better or faster shifting use heavier fluid U have better bearing wear protection. Redline recommends: 4 quarts of 75-90ns is good in the front tranny, 1 quart of 75-90~ is good in the rear. 75-90ns(non-slip) or 75-90~ or MTL-90 can be used in front or rear tranny/diff just fine. I know Impreza owners who use all of these in different combinations. It gives the car a different feel with diffrent combinations.
1) 75-90~ is more for protection, it is slipperier and has better protection for Tranny bearings and rear diff, but it's harder to get into gear with this fluid, sychronizers may not like this to much. Also you get less lock-up with your rear LSD differential.
2)MTL-90 has less protection for your gear box (it's better than any normal Tranny fluid). It is easier to shift and locks up very well. U may need to change more often than standard fluids (Instead of 50K, change @ 27-30K...not bad...)
3)75-90ns good wear protection, easier to shift into gears, and the rear lsd differential would lock up or react faster. Works well in Minnesota cold weather. But when it gets California/Arizona hot, the shifting gets crunchy and the Tranny bearings don't like this.
Just remember that bearings last twice as longer than synchronizers do.
Also read this http://www.cobbtuning.com/tech/gearoil/index.html
Good luck
Gill
EchoWrx is offline   Reply With Quote
Old 06-19-2001, 02:50 PM   #7
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Question Where???
Where is the cheapest place to obtain some MTL-90 to do the whole car? I'm at 30k and it needs done.
omahasubaru is offline   Reply With Quote
Old 06-19-2001, 03:15 PM   #8
HomerJay
Member#: 1135
2005 WRX WAGON
Contact the guys on the redline website, they'll let you know the best place to purchase in your area.
Old 06-19-2001, 03:17 PM   #9
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
Question
what do you think about using MTL 70w 80 in the transmission and 75w 90 on the rear end? plus i live in the caribbean, where we have a lot of humedity and hi temperatures.
Santo Domingo 2.5 RS is offline   Reply With Quote
Mobil 1 synth gear oil travmn Transmission (AT/MT) & Driveline 18 10-13-2002 10:51 AM
redline tranny/gear oil newbie sewbie Southern California Impreza Club Forum -- SCIC 8 09-13-2002 12:31 AM
WTB: Redline 75W90NS Gear Oil Ryan24 North West Impreza Club Forum -- NWIC 25 08-01-2002 10:12 PM
Redline Lightweight Gear Oil zemmo Transmission (AT/MT) & Driveline 6 03-26-2002 10:51 PM
Redline 75W90 gear oil FengShui Canada Region Forum 1 10-19-2001 03:02 AM
