Old 09-23-2004, 06:35 PM   #1
droche
Member#: 69112
2011 WRX
Dark Grey Metallic
Default Trouble finding parts for an '05 2.5 RS
Hi all -
I just bought an 05 2.5 RS and I'm looking to putting a little money into it... The only problem is, vendors don't seem to be listing parts for 2005 yet. Does anyone know what parts will fit my car? In what ways is it identical to earlier models? Specifically, I'm looking at installing a CAI, rear sway bar, rear (maybe front, too) strut brace, and maybe a cat-back exhaust later on. Any 05 owners out there had any luck, or know what will work for my car?
cheers
droche is offline   Reply With Quote
Old 09-23-2004, 07:05 PM   #2
regan
Member#: 52744
1999 Outback
61 VW Bug
all will fit from a 2004. the only one i am not sure on is the cai.
-regan
regan is offline   Reply With Quote
Old 09-23-2004, 08:02 PM   #3
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
CAI is different, the 05's are MAF cars. The exhaust is the same as the 02-04 models.
For a CAI, I think since its MAF, you can do the cone filter + MAF adapter like alot of the older model MAF impreza owners do (me included). I'm not sure if the 05 has a fender snorkel either, but if it does that would also be a good place to start. The 05 also has a new style intake manifold, which will make compatibility a bit different (although it is a much better design)
For suspension parts, look for 05 WRX parts (minus the front swaybar).
Old 10-21-2004, 07:31 PM   #4
dmatthew
Member#: 69247
2005 2.5 RS Wagon
Crystal Gray Metallic
any luck on finding a CAI for the 05's?
dmatthew is offline   Reply With Quote
Old 10-21-2004, 10:02 PM   #5
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
-regan
Not correct Kostamojen is right, 05's are MAF based again, why... we're not sure.
As for suspension = 04+ Springs work, 02+ Struts Work, 02+ Rear Swaybars fit, 02+ Strut Tower braces work
Don't bother with the front swaybar, the stock is 20mm anyway.
I'm going to be checking out and doing some test fits for CAI intake kits on my friends 2005 Impreza RS Sedan tomorrow evening, i'll get back to you.
Bry
BrysImpreza is online now   Reply With Quote
Old 10-21-2004, 11:25 PM   #6
dmatthew
Member#: 69247
2005 2.5 RS Wagon
thanks brys!
Old 10-22-2004, 12:00 AM   #7
nySulli
Member#: 32617
2008 STi
you might want to contact cobb on the cai, see if their 99' one will fit since its built for MAF
nySulli is offline   Reply With Quote
Old 10-22-2004, 12:34 AM   #8
Evan_Ng
Member#: 45548
2004 Impreza
SIlver
wrx suspensions fit on RS?
i thought it would cause the front of the car higher than the rear???
Evan_Ng is offline   Reply With Quote
Old 10-22-2004, 01:23 AM   #9
dmatthew
Member#: 69247
2005 2.5 RS Wagon
I tried lurking around the cobb rs/ts forums but no news about 2005 parts unfortunately
Old 10-22-2004, 02:19 AM   #10
piker28
Member#: 22664
i had wrx springs in my rs i dont see how it would be different? the struts are the same
piker28 is offline   Reply With Quote
Old 10-22-2004, 05:09 PM   #11
dmatthew
Member#: 69247
2005 2.5 RS Wagon
bump to keep the thread alive! I just basically want to know what CAI's I can use for my car lol
Plus I should be able to use any exhaust system as well right? Like Cobb's?
Old 10-22-2004, 05:25 PM   #12
piker28
Member#: 22664
basically at this moment, no intakes
email cobb and ask if the 99 MAF intake they made will work, i dont think it will though
cobbs exhaust should work
Old 10-24-2004, 03:55 PM   #13
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I measured the distance between the MAF bolts on the 2005 RS, it's 9mm X 5mm, which is the same as the 93-99 Impreza.
The distance of the throttle body to the spot the MAF is located is about the same as the 93-99 Imprezas and the MAF has a 3" round inlet that would connect to an intake with a silicone sleeve.
Option 1. Kartboy MAF Filter Adaptor + K&N Panel Filter
Option 2. E-bay MAF Filter replicas / K&N replica Filter
Option 3. Generic Intakes from e-bay. I'm not sure if Cobb Makes a 93-99 Intake, so I'm not going to suggest it.
Find someone in your area with a modded 93-99, see if you can just do a quick test fit.
The only thing I didn't look for was an IAT sensor like the 03/04 NA Imprezas have. Wish I could be of more help, but the setup looks very similar to the older engines, just a very nice new Intake manifold.
Old 10-24-2004, 04:22 PM   #14
rawrFERNY
Member#: 51517
2007 Outlander LS
not sure if this helps but cobb does have a 99 model cai
http://cobbtuning.com/impreza/powerpackage1.html#cai
rawrFERNY is offline   Reply With Quote
Old 10-24-2004, 11:07 PM   #15
dmatthew
Member#: 69247
2005 2.5 RS Wagon
I thnk I will email cobb with regards to the '99 intake. Hopefully it'll work on the 05's!
thanks for all your help guys
Old 10-25-2004, 06:46 PM   #16
dmatthew
Member#: 69247
2005 2.5 RS Wagon
I got an email from Cobb Good to know one is currently in development!
Derek,
Unfortunately the 2005 CAI requires a redesign from the 99 version. Once Josh has completed the development of the new intake, we will make an announcement on the www.cobbtuning.com homepage.
Cheers,
Justin
COBB Tuning
www.cobbtuning.com
www.wrxforum.com
Old 10-25-2004, 07:20 PM   #17
Caplin 2.5
Member#: 71203
2005 2.5rs
NO I URGE YOU NOT TO GET A Cold Air Intake for you 05 2.5rs. I Just bought an AEM air intake for my car and the mounts are off. I'm tryin to get it to work. Im going today to check and see if subaru sells a mount, cause the problem is that the intake pipe as an extention where the pipe is to mount on another mount that is in the engine bay, the difference between 04 and 05 is that the 05 doesn't have that mount that the 04 does. but Im gonna go down to subaru and see if they could get it, if it works then ill tell you to get it. I also got an Injen intake for my 05 2.5rs that was origanlly made for a 99 rs but it didn't fit either again the mounting spots were wrong and the pipe was too short.
Caplin 2.5 is offline   Reply With Quote
Old 10-25-2004, 07:29 PM   #18
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
bump for a fellow 2.5 05 owner looking for an intake!
vwown3d is offline   Reply With Quote
Old 10-25-2004, 08:08 PM   #19
piker28
Member#: 22664
aem didnt make an intake for the 05, so you bought an 04 to use? check out the post from cobb the 99 ones wont work so time to wait again
Old 10-25-2004, 08:39 PM   #20
Caplin 2.5
Member#: 71203
2005 2.5rs
Yeah i bought the 02-04 AEM cold air intake, and i need to see if subaru has some extra mounts. cause the main problem with it is that the pipe has no where to mount.
Old 10-26-2004, 08:47 AM   #21
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Thats pretty much the case with any cold air intake for the Impreza, there are no mounting spots, thats why most of us just fab something out. The only one that is really stable is the Cobb and that's only because it has a solid filter going into the fender.
Old 11-02-2004, 03:51 PM   #22
dmatthew
Member#: 69247
2005 2.5 RS Wagon
darn it..I need a CAI
Old 11-02-2004, 04:27 PM   #23
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
twizzle, i second that call for a CAI
Old 11-02-2004, 04:51 PM   #24
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I've already told you the current options, all you have to do is decide which one, then become our guinea pig to see if the 2005 MAF's are as delicate and picky as the 1999's were (broke like it was their primary function)
Old 11-02-2004, 05:25 PM   #25
dmatthew
Member#: 69247
2005 2.5 RS Wagon
I am scared to be guinea pig tho
FS/NY: OEM parts from an 03 2.5 RS seesPiKegrind Engine/Power/Exhaust 19 02-23-2009 01:16 PM
('93-'01) interior panels needed for an 99 2.5 rs 2 door my04sti Impreza Forum 2 11-04-2004 02:00 AM
03 wrx aero parts on an 04 2.5 RS?? digi Interior & Exterior Modification 10 12-24-2003 03:47 PM
Will these parts fit an 04 2.5 RS??? digi Interior & Exterior Modification 8 12-16-2003 11:44 PM
Turbo Parts for a 2002 2.5 RS SubaruRallySport Normally Aspirated with bolt-on Forced Induction Powertrain 2 08-22-2002 04:04 AM
