Old 06-18-2001, 07:13 PM   #1
ImprezaGuy
Member#: 4400
2000 Impreza Rs
Sedona Red Pearl
Default HEader Torque Specs
What are the torque spec for the bolts on the heads and the bolts between the header and the first cat. Thank you
ImprezaGuy is offline   Reply With Quote
Old 06-19-2001, 01:59 AM   #2
ImprezaGuy
Member#: 4400
2000 Impreza Rs
Sedona Red Pearl
Default BUmp
bump
Old 06-19-2001, 03:16 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
ask and you shall receive...
<img src=http://albums.photopoint.com/j/View?u=1182273&a=8706954&p=50618084></img>
MAKE SURE to use the correct units of torque. For most of us, that's ft-lb which is the last value. Don't use newton-meters or kilogram-meters by mistake.
ColinL is offline   Reply With Quote
Old 06-20-2001, 02:13 AM   #4
ImprezaGuy
Member#: 4400
2000 Impreza Rs
Sedona Red Pearl
Default bump
bump
Old 06-20-2001, 09:39 AM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Question bump?
um, are you bumping this for others to see or do you not know which bolts you are asking about are located on the diagram?
Old 06-20-2001, 03:28 PM   #6
ImprezaGuy
Member#: 4400
2000 Impreza Rs
Sedona Red Pearl
Default Why Bumping
I cant read the diagram very well. It looks to me that both are a T3 spec. But the T3 says (i think) 22.4 lb-ft. Is that what you get out of it too?
Old 06-20-2001, 03:40 PM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
whoops, you PMed me the exact same thing. well anyway, if anyone else wants this page from the MY00 factory service manual and wants to be able to read it better go here:
http://albums.photopoint.com/j/View?...nce=0&res=high
Old 07-24-2001, 02:04 PM   #8
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
That IS 22.4 ft-lb correct?? Neither photo is very clear...
donjuan is offline   Reply With Quote
Old 07-24-2001, 02:17 PM   #9
Dan00RS
Member#: 1367
2000 Impreza 2.5RS
Blue Ridge Pearl
Yes 22.4 ft-lb +/- 3.6 for both the bolts on the heads and the bolts between the header and the first cat.
Dan00RS is offline   Reply With Quote
Old 07-24-2001, 02:21 PM   #10
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Thanks...they're coming off this weekend so I needed to find the #'s.
Old 07-24-2001, 04:32 PM   #11
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Wow, when I installed my borla I guessed 20 ft-lbs. not to shabby...
LUME is offline   Reply With Quote
Old 08-06-2001, 02:26 PM   #12
m750
Member#: 2278
8Sti | 07 allez
White | Comp
does anyone have a clear picture of this? I'd like to print one off, but it comes out way too blury... please...
Email it to me...
thanks
Aaron
m750 is offline   Reply With Quote
Old 08-06-2001, 03:28 PM   #13
jetfire67
Member#: 4926
1988 FC3S 10th AE
& 2009 STI
i torqued mine at exactly 30lbs. should i loosen them?
jetfire67 is offline   Reply With Quote
Old 08-06-2001, 06:38 PM   #14
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Question
Is torquing bolts really important? As long as it's tight nothing will go wrong right? What happens if it's too loose or too tight? Thanks.
Mike
MagicMT is offline   Reply With Quote
Old 08-08-2001, 08:48 PM   #15
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Bump. I don't know if I should be worried or not. Took off and put back on: passenger & rear seats and rear right tire. I also put on: midpipe, muffler, rear sway bar... They aren't on as tight as it was stock.
Mike
Old 08-10-2001, 01:33 AM   #16
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
No one knows?
Header torque specs MarcsRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-03-2004 12:36 AM
WRX Header torque specs needed sperry Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2002 11:45 PM
stock header bolt torque specs OMAHA2.5RS Service & Maintenance 1 03-08-2002 04:07 PM
Need Torque specs for Header bolts george Normally Aspirated Powertrain 3 01-03-2002 09:26 AM
WRX Torque Specs for Exhaust Header Bolts Neil Wallerstein Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-30-2001 01:48 PM
