Old 09-23-2004, 08:08 PM   #1
John Kerr
Member#: 70950
1995 Impreza
blue
Question won't start after a fill up
Help! My 95 Impreza 1.8 won't start after I fill it up at the pump. If I let it sit for 10-20 min it starts right up. Is there a vacum on the tank or is the vented cap pluged or is it a fuel pump problem? Any other ideas. I take a ferry to work every day and can't shut the car off or it won't start. I had to be pushed off once and towed another time. Help! tired of hanging out at the gas station!
John Kerr is offline   Reply With Quote
Old 09-23-2004, 08:15 PM   #2
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Get your fuel system checked.
Al_Smokemcrack is offline   Reply With Quote
Old 09-23-2004, 09:48 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
fuel filler, fuel canister, vent valves...
something is wrong/blocked/old/broken
best have a Subaru tech take a look at it and pinpoint it for you.
good luck!
Jamie
www.subiegal.com
Old 07-14-2008, 09:40 PM   #4
HOLLYW00D
Member#: 44954
2004 FXT
sorry to dig this up, but if anyone else has this issue here was my problem/solution:
at some point i mixed up the vacuum lines on the purge control solenoid valve. when i went to fill up, some fuel went down the little drain hole. no biggie right? well, with the lines mixed up, i was sucking that fuel up into the intake manifold. try as i might the car would not start. when it did start, i'd have to keep the revs up because it was pig rich. no cel's at any point running with the hoses mixed up, so check that out first.
HOLLYW00D is offline   Reply With Quote
Old 07-15-2008, 01:00 AM   #5
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
If you haven't been messing with anything i'd say you have a bad case of fuel tank sediments, and you should probably check your fuel filter.
Chocoholic005 is offline   Reply With Quote
Old 07-15-2008, 01:12 AM   #6
HOLLYW00D
Member#: 44954
2004 FXT
pardon my ignorance and please don't take this the wrong way, but a clogged fuel filter would starve the engine of any gas. it surely would not "fix" itself by waiting any amount of time.
After I filled up some gas, the car won't start zac5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-17-2009 06:19 PM
Car won't start after first start plaines Service & Maintenance 0 01-17-2007 05:55 PM
Car wont start after tank fill up!! SSsleeper96 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-22-2005 10:05 AM
HELP - Car won't start after turbo install Needles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 06-30-2005 08:23 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-11-2001 11:35 PM
