Old 09-23-2004, 08:48 PM   #1
stang-spanker
Member#: 44276
2004 WRX Wagon
Java Black--COBB Stage II
Default Learning up better than learning down with AccessPORT?
Assuming perfect tunes, there is a 5HP difference between the Cobb Stage 2 91 oct map and the 93 oct map (~4 at the wheels). But, if it isn't a perfect map matched to your car--probably not since every car is different--your ECU compensates within reason.
If the 93 oct map isn't spot on for your car, and you use 93 oct gas, your car will learn down. If you run the 91 oct map, but still use 93 oct gas, your car will learn up. Seems like you will end up at the same power level, but running the 91 oct map would give you that extra cushion of safety for a bad tank of gas, etc...
I discussed this with Cobb while trying to figure out if I had detonation, and they seemed to lean towards learning up. Any thoughts?
stang-spanker is offline   Reply With Quote
Old 09-26-2004, 01:56 AM   #2
jsmonet
Member#: 14190
2005 STi
white
if you start with too agressive a map and try to learn down, you REALLY need to hope for low boost levels, COLD days, and absolutely no hills. the only way to make this totally safe is to raise the octane in your tank with an additive such as toluene.
learning up is a MUCH better choice, esp. considering there's only a 5hp or so difference.
jsmonet is offline   Reply With Quote
Ok, Find a Better Stand Up Comedian Than.... TheBigBadYeti Off-Topic 68 05-31-2010 04:18 PM
OT come up with something better than "Reverse Blumpkin" ZMANNH25rs Off-Topic 43 06-02-2006 03:13 PM
275/40/17 with a tread wear better than 140 kaneda3 Tire & Wheel 2 02-05-2005 07:35 AM
Unlearned stock map better than learned? subiesown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-12-2004 08:57 PM
Will the STi tranny be able to handle up to 400 hp or hold better than the five speed acss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-07-2002 10:24 PM
