Old 09-23-2004, 10:08 PM   #1
pooparu
Member#: 59750
1999 Jaguar XJR
blacker than your soul
Question Gauges in Radio slot
I just put a Sony CDX M800 into my '99 2.5 GT Avant. The old head unit was a double system the new one is not. I am thinking about filling in the dead space with some meters. I'm not sure which ones to get, the car has 102,000 miles so Oil Pressure will most likely be one. Anyone have recommendations for company and/or types of gauges to use? Any input will be appreciated.
pooparu is offline   Reply With Quote
Old 09-24-2004, 01:52 PM   #2
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
I use oil temp instead of pressure, just preference I suppose. My car started running ~10 degrees F higher, and it was due to me being low ~1 quart.
Tom
SlideWRX is offline   Reply With Quote
Old 09-24-2004, 04:50 PM   #3
bboy
Member#: 56468
04 Improved STI
Dirty White
There are DIN panels for three guages, either 45 mm or 52 mm. Omori is the only company I know of that makes the 45 mm guages. 52 mm can be had from many.
See:
http://www.egauges.com/vdo_agrp.asp?..._Inserts&Cart=
These are turned toward the driver, for easier viewing:
http://www.omorimeter.com/P107-Skyline_R32-3.jpg
Old 09-25-2004, 09:38 AM   #4
TreyS
Member#: 42478
2004 WRX STi
White/Gold
The 02+ opening is not a full double DIN opening, it's a double ISO and the first link above for the 52mm gauges will not fit.
Example, any aftermarket radio cannot use the trim ring on the WRX because it's ISO. A DIN opening could use the trim ring around the radio.
TreyS is offline   Reply With Quote
Old 09-29-2004, 10:56 PM   #5
sandiegowrx
Member#: 41743
sandiegowrx is offline   Reply With Quote
stock 3-gauge kit: radio slot vs dash top? Bluefoton Electrical & Lighting 8 03-23-2007 10:29 AM
Idea, Digital gauge in clock slot. Undepelo General Community 21 11-12-2004 01:43 PM
Gauges in Radio slot pooparu Electrical & Lighting 4 10-02-2004 05:30 PM
60mm GReddy Meters in Radio slot?? RIwrx Interior & Exterior Modification 0 09-23-2002 10:29 AM
Gauges in DIN slot mike270 Interior & Exterior Modification 4 02-22-2002 01:00 PM
