Old 09-24-2004, 08:52 AM   #1
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Default For those who use ARP head stud
what is the torque sequence on those, acording to ARP it just said 85ftlb that it but acording to Subaru:
1. 22ftlb,
2. 51ftlb,
3. backoff 180 degree,
4. bolt (a)(b) 25 ftlb
5. (c)(d)(e)(f) 11 ftlb
6. tighten all bolt by 80-90 degree
should i just do 85ftlb??? or should i go with 85ftlb and tighten all bolt by 80-90 degree more?
the reason i ask is because i blow head gasget 3 time already with in 1 month by doing just 85ftlb.
ChAi is offline   Reply With Quote
Old 09-24-2004, 12:00 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
85 ft lbs sounds really high. Was that just their generic spec? I am sure it would just fine threading into a cast iron block.
jeffg is offline   Reply With Quote
Old 09-24-2004, 12:52 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
my opinion would be to just follow the factory torquing specs. The thread pitch and bolt diameter haven't changed, so that shouldn't change the required torque. The material might have changed, but I can't see that varying too much.
Legacy777 is offline   Reply With Quote
Old 09-24-2004, 02:21 PM   #4
jeffg
Member#: 2958
2001 WRX (GC8)
The difference would be in the amount of stretch the bolt material has.
Old 09-24-2004, 06:19 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Chai, Forgive my ignorance. Two questions for you: 1. is this a dohc or sohc engine? and, 2. When did arp make head studs for a sohc? I know they are available for dohc.
Tim Sanderson is offline   Reply With Quote
Old 09-24-2004, 07:33 PM   #6
ChAi
Member#: 1277
1999 Minnam Stage 2
my engine is SOHC and arp does make head studs foe sohc
Old 09-24-2004, 08:29 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Got a part #? arp web site shows them for 2.0. 2.2, and 2.5, but their all the same part #. That does'nt make sense since all the 2.0's are dohc and all the 2.2's i've seen are sohc. There is a difference in head thickness so they would have to be different lengths hense different part numbers. The last I heard was that they only had them for dohc.
Question For Those Who Have Removed Heads Hayaboosted Built Motor Discussion 14 05-02-2008 11:30 PM
For those who use ARP head stud ChAi Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-25-2004 09:39 PM
Questions for those who use LCD monitors for games/movies Asinine Off-Topic 42 08-20-2004 10:15 AM
For those who use synthetic oil DanZ Service & Maintenance 51 02-20-2003 08:19 PM
For those who use paypal.. paultg New England Impreza Club Forum -- NESIC 6 02-08-2001 10:18 AM
