Old 09-24-2004, 12:57 PM   #1
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Default What size t-bolt clamp for compressor outlet?
I'm using an APS DR650 with tbolt clamps on the tbody coupling and worm clamps throughout on the rest, i'm sick of tightening/dealing with leaks on the worm clamp @ the compressor outlet, which size tbolt should i go pick up from napa?
overdose is offline   Reply With Quote
Old 09-24-2004, 02:49 PM   #2
InfamousDX
Member#: 25413
I THINK a 2.5 or 2.75" because I tried a 3" and it was too big by a little bit... ended up using the clamp that came with the kit.
what size is the turbo intake side outlet Rexxyou Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-22-2008 09:42 PM
What size t-bolt clamps for APS DR725 jaysant1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-05-2007 08:03 PM
Size of hose clamps for turbo Inlet tube? What about Perrin short ram? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-25-2005 08:08 PM
What size T-Bolt Clamps should I order for a Perrin Silicon IC Y-Hose kit? wrx05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-01-2005 04:41 PM
What size banjo bolt for Deadbolts 20g? F22-Raptor Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-09-2004 07:48 PM
