Old 09-24-2004, 02:08 PM   #1
koolpimp
Member#: 25062
Default EJ20TT wiring and oxygen
Where would you find a wiring harness from an ecu to EJ20TT and also the oxygen senser in the exhaust pipe from the first turbo.
koolpimp is offline   Reply With Quote
Old 09-24-2004, 06:18 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Nippon Motors can get you a wiring harness. O2 sensors are likely the same as some US spec one. Are you putting this in an RHD mail wagon? Otherwise it won't fit in any LHD USDM Subaru...
Old 10-31-2005, 10:05 AM   #3
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Will it fit if the 2nd turbo is foregone and just the block is used?
jkjersey is offline   Reply With Quote
Old 10-31-2005, 10:26 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
You need to use single turbo exhaust manifolds, but the EJ20's from the TT's are essentially the same engine as the single turbo ones...
Old 11-13-2005, 04:22 AM   #5
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
Hey Bud,
Do a Google on 'Half Cuts' Then have a look from there, Adelaide Jap have some instock, there are PLENTY of these around Down under.
Cheers
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
FS: JDM 98 Legacy EJ20TT wire harness/ecu ftr'swrx Engine/Power/Exhaust 4 03-25-2009 04:30 PM
JDM EJ20TT wiring tomdewing Subaru Conversions 9 03-20-2008 01:01 PM
ej20tt wiring harness madmanind Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-14-2005 04:30 PM
WTB: Turbo Crossmember and GTB EJ20TT Wiring Harness bg5wagon Private 'Wanted' Classifieds 3 07-24-2003 10:48 PM
Testing MAS and Oxygen Sensor? Dbigworm General Forum Archive 1 03-27-2001 05:19 PM
