Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-25-2004, 08:50 AM   #1
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
Default weight reduction
What kind of benifits are there with a lighter car?
How much weight must be removed to feel a diference?
kevin2.5rs is offline   Reply With Quote
Old 09-25-2004, 09:17 AM   #2
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Go down the drags, do a run with every thing as is....
Then, while you are there, remove Pass seat, rear seat, washer bottle, spare wheel/Jack etc etc etc etc and see how much faster you go..........
Alterantively, drill holes in EVERYTHING, Except brake and Fuel Lines!! LOLOL
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 09-25-2004, 10:18 AM   #3
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Go to this 1/4 Mile Calculator
1) Type in your vehicle's weight (with you in it).
1a: If you don't know your vehicle's weight with you in it, assume a weight (Ex: 3100lbs).
2) Type in the horsepower you car makes. If you don't know the horsepower, type in the horsepower you think your car makes (Ex: 165hp).
3) Press the 'Calculate ET (Elapse Time)' button.
4) Observe results
5) Repeat step #1 with a different weight and/or horsepower and continue.
Kevin Thomas is offline   Reply With Quote
Old 09-25-2004, 10:26 AM   #4
nySulli
Member#: 32617
2008 STi
F = M * A
the force will remain the same if your just removing weight, but with less mass, you obviously have faster acceration, goes for handling, braking, 1/4 mile times
aside from that, depending on where you lose the weight you can end up with a better weight distribution, losing unspring weight (anything in the suspension that moves with the wheels up and down, this can really benefit your handling by ensuring the tires spend as much time as possible planted on the pavement doing what their suposed to do
theres more benefits, but really less weight can really make a huge difference in how your car handles, good places to start are with the battery, even possibly relocating it to the trunk for better weight distribution, pulley's, flywheel will help put a little more power to the ground dropping the drivetrain losses, past that your mostly talking about removing stuff, and going with lightweight body panels, but that can get pricy
nySulli is offline   Reply With Quote
Old 09-25-2004, 10:56 AM   #5
Kevin Thomas
Member#: 110
1989 1989 XT6
50lbs if you are a professional driver. 100lbs if you are not.
Rotational weight: You will feel a difference with 3lbs or more removed.
Old 09-25-2004, 12:52 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yeah im doing bumper beams i did the front and im doing the rear, thats like 100 lbs! but im also 100x more likely to die in a wreck, oh man
Old 09-25-2004, 04:49 PM   #7
Jejunum
Member#: 15773
2011 Impreza WRX
oh man, thats funny. i was drinking a pop and almost spit it all over the screen after reading that.
Jejunum is offline   Reply With Quote
Old 09-25-2004, 07:14 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
heh well its true
also i found ut taht the rear is only 34 lbs, making it about 30 lbs lighter w/ the new rear beam, not bad but not tha tmuch
Old 09-25-2004, 08:41 PM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Not really, considering those bumper beams are stock on some of the old jdm cars.
Old 09-25-2004, 09:16 PM   #10
Bussman61
Member#: 32612
1996 SVX
Laguna Blue
Originally Posted by Kevin Thomas
If that thing is correct....
My poor car
Bussman61 is offline   Reply With Quote
Old 09-25-2004, 10:01 PM   #11
Defiantguy
Member#: 41268
2015 WRX
according to that, if you can run a 14.9 in the quarter mile with a 150lb driver your RS has about 229hp. Right...
Defiantguy is offline   Reply With Quote
Old 09-25-2004, 11:22 PM   #12
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
1/4 mile calculators never work.
Old 09-26-2004, 01:30 AM   #13
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
just removing the rear seats and the interior of the trunks and the spare and jack and package tray of my sedan i noticed the difference. that carpet is heavy in the trunk.
for an easy experiment add wieght and see what happens. the amount it would take to notice would be very close to the amount you would need to loose i would think.
greg donovan is offline   Reply With Quote
Old 09-26-2004, 02:13 AM   #14
rawrFERNY
Member#: 51517
2007 Outlander LS
rawrFERNY is offline   Reply With Quote
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 12:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 11:02 AM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 10:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 12:53 AM
