Old 09-25-2004, 11:55 AM   #1
Will98RS
Member#: 15816
1998 Impreza RS
Default turn on gauge for two amps
quick question. for two amps (500bd and 500x both from rockford fosgate) what gauge turn on lead do i need? right now i have a really tiny one designed for one amp. do i need to take out the HU to run a thicker gauge?
thanks
will
Will98RS is offline   Reply With Quote
Old 09-25-2004, 12:03 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Don't worry. The amount of current used for turn-on is very low, on the order of a few milliamps. Whatever wire you have now is fine. If you really want to be sure you're not exceeding any ratings, there should be an indication in the specs for each amp for what the turn-on circuit current is, and in the HU specs for the max current that can be drawn from its turn-on output. Most HUs have more than enough current available for two or more amps.
Old 09-25-2004, 03:19 PM   #3
Will98RS
Member#: 15816
1998 Impreza RS
thanks, i didnt even think about the HU current, i was thinking about the current capacity of the wire
Old 09-25-2004, 06:49 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
even if you had 20 gauge it would be fine, what you have to worry about with multiple amps is the headunit's ability to supply enough current. Most headunits don't have a problem with 2-3 devices, but more than that and you should really get a relay.
Old 09-26-2004, 04:57 PM   #5
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
I am impressed. I think this is the first thread on NASIOC I have read with ALL good info... granted theres only 2 reply's.. but they are both pretty much spot on. Bravo!!!
~v6
V6TurboTA is offline   Reply With Quote
Old 09-26-2004, 10:03 PM   #6
tdxflex
Member#: 13634
The largest amp turn-on wire recommended gauge I've seen is 16ga, old Xtant 1001dx amp. I think most amp install kits use 18ga.
tdxflex is offline   Reply With Quote
Old 09-26-2004, 10:23 PM   #7
11SECWRX
Member#: 16193
2014 Wrx
CBS
the best thing to do is use a relay after the headunit turn on wire if your are worried about current.
11SECWRX is offline   Reply With Quote
Old 09-26-2004, 10:42 PM   #8
Will98RS
Member#: 15816
1998 Impreza RS
i saw a website that recomended the relay but if i can get away with splicing one wire for both amps that would be much much easier
Old 09-27-2004, 01:56 AM   #9
locosti04
Member#: 70940
2004 Impreza WRX STI
Java Black
you don't need a relay... splice the 1 wire and send it to the other amp. if you are using more than 2 amplifiers then it might not be a bad idea to use a relay.
locosti04 is offline   Reply With Quote
Old 09-27-2004, 07:32 PM   #10
Will98RS
Member#: 15816
1998 Impreza RS
i got it set up, thanks guys...i would consider using a relay except my power line are all pretty now and i dont want to mess with that
turned on heat for a sec, now no A/C DoinkMobb Service & Maintenance 5 07-19-2009 03:55 PM
Woman sits on toliet for TWO YEARS ?!? subenerd Off-Topic 116 10-08-2008 11:29 AM
Which wire to use for the amp turn on lead? '04 WRX Phylomatic Car Audio, Video & Security 27 04-21-2008 04:43 AM
Autometer Nexus gauge turns off when headlights turned on wazup Electrical & Lighting 1 08-13-2006 03:58 AM
Remote turn on wire for Basslink, where to tap it? 03WRXMA Car Audio, Video & Security 14 10-29-2003 09:07 PM
