Old 09-25-2004, 07:03 PM   #1
wistful
Member#: 745
2004 STi
Java Black Pearl
Default 245-40-17 on STi stock rims.. nono?
I need new tires for my car.. ride.. steed... or as Usher calls it.. my whip. I'm definitely going with Kuhmo MXs... now the question goes with sizing. Should I get OEM size of 225/45/17 or 245-40-17. I've done a search and read that there's no rub. Are there any downfalls about going to that larger size? Will it fit on 7.5" wide rims? Thanks a lot guys.
Don
wistful is offline   Reply With Quote
Old 09-25-2004, 07:26 PM   #2
porque
Member#: 57102
For one thing, I think your speedometer/odometer would be off.
porque is offline   Reply With Quote
Old 09-25-2004, 07:28 PM   #3
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
I would like to know the answers to his question, but also more to the point of the 05 rims which are 17x8". Can a 245 fit comfortable on there?
Thanks!
- dow
dowroa is offline   Reply With Quote
Old 09-25-2004, 07:48 PM   #4
Silver04WRX
Member#: 37644
2009 Legacy 2.5i
Don
Look here:
http://www.tirerack.com/tires/Spec.j...omCompare1=yes
Kuhmo MXs, as well as most other tires in 245/40/17 will only fit on 8-9.5"
Silver04WRX is offline   Reply With Quote
Old 09-25-2004, 07:56 PM   #5
BHawk
Member#: 61860
2004 WRX STi
Originally Posted by Silver04WRX
Look here:
Really? It has already been done. It's a tight fit, but it can be done. The only thing I would worry about is the tire sidewall stiffness being compromised by an excessive amount of curve needed to get the fit.
On another note the stock RE070 225/45R17 are as wide as most performance 245/40R17s and some 255/40R17s. It's really a confusing game. I would not hesitate to go with a tire like the BFGoodrich G-Force T/A KD in 245/40R17. The Kumhos may also fit.
BHawk is offline   Reply With Quote
Old 09-25-2004, 08:37 PM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
You can run 245s on a 7.5" rim without any problems, the MXs aren't that wide. In autocross guys run 275 Hoosiers on them.
Old 09-26-2004, 12:23 PM   #7
austinpike
Member#: 11279
2o11 wrx dgm
2oo8 tribeca swp
speedometer won't be off much, 225/45 + 245/40 are practically the same diameter. heck the STi speedo is already like 5mph off.
tire size calculator
Personally I would think 245/40 max for an 8" rim, maybe 235/45 on a 7.5." But then I'm not trying to push the limits of adhesion.
austinpike is offline   Reply With Quote
Old 10-01-2004, 04:45 PM   #8
wistful
Member#: 745
2004 STi
Java Black Pearl
update: they fit! no rubbing. However, I'm still deciding whether I like the MXs or not. ITs only been two days.
Don
Old 10-01-2004, 06:56 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Don
Give then at least 1k miles.....mine were a bit greasy until they wore down a bit....just wait 'til they are under 1/2 tread
Old 10-02-2004, 02:10 AM   #10
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
yeah totally. new tires always feel less than good.
nhluhr is offline   Reply With Quote
Old 10-04-2004, 09:16 AM   #11
dowroa
Member#: 17498
No More Subarus :(
Don
You running any camber more than stock? If so, how much? You got a 'drop' on the car? Coilovers/springs? If so, how much?
Thanks for answering out survery! Here is our two cents for your time!
Sincerely,
Dow
Old 10-04-2004, 09:30 AM   #12
wistful
Member#: 745
2004 STi
Java Black Pearl
no suspension mods yet. stock camber in the rear. I think like -1.25 in the front?
Don
Old 10-04-2004, 11:21 PM   #13
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Don,
you could have asked on lersoc I'm running 255/40/17 VictoRacer rubber on my stockers. I have a little bit of rub. But I have about 1.5" drop and well i also do 1.0g turns with these tires
SloRice is offline   Reply With Quote
Old 10-06-2004, 12:39 AM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
Originally Posted by SloRice
....But I have about 1.5" drop and well i also do 1.0g turns with these tires
That's it?
Jay Storm
Old 10-06-2004, 04:33 PM   #15
jsalicru
Member#: 58031
this is interesting... Im on Tein Coilovers and I heard rubbing the other day.... I took off the tire and noticed that the rubbing was on the INSIDE, and not the outside like I thought... Stock tires BTW...
jsalicru is offline   Reply With Quote
Suspension Effects of 245/40/17 on stock '06 WRX Wagon? zenphoenix Tire & Wheel 2 11-22-2009 01:11 AM
245/40/17 on 06 sti bbs wheels substi0406 Tire & Wheel 3 04-21-2008 03:53 PM
245 40 17 on stock 06 bbs ozzy370 Tire & Wheel 12 12-25-2007 12:57 PM
245/40/17 on stock suspension? sssp Tire & Wheel 2 08-14-2007 12:31 PM
245/40/17 on an STi? ringmaster Tire & Wheel 24 12-27-2003 10:48 AM
