Old 09-25-2004, 08:36 PM   #1
just one blunt
Member#: 28244
2003 WRX
Default Check engine light question....
I just got my up pipe and turbo back installed on thursday and today I got a check engine light. I got the 02 sensor welded on , but I am wondering when will the check engine light go off, and does it damage the engine at all with the light on??? thanks
just one blunt is offline   Reply With Quote
Old 09-25-2004, 08:45 PM   #2
SINthetic
Member#: 53775
03 WRX
You threw a code from not having a cat. Did you put the resistor in the factory EGT wiring?
SINthetic is offline   Reply With Quote
Old 09-25-2004, 08:45 PM   #3
zaxrex
Member#: 9898
Water Injected Blue
It will go off when the bulb burns out, or when you pit in a MIL eliminator, or when you grind out the O2 sensor and do the mechanical fix w/ the probe extendor.
That won't hurt your engine, but you will never know when you have a real problem and a bad code is thrown under your cat innefeciency code.
Searches help alot too.
zaxrex is offline   Reply With Quote
Old 09-25-2004, 08:52 PM   #4
just one blunt
Member#: 28244
2003 WRX
I got it installed at Precision Tuning and Rich installed an 02 bung so I could plug in the sensor but i still got the light....just as long as its not doing any damage....
Old 09-25-2004, 09:11 PM   #5
WRXturboAWD
Member#: 23735
2002 Impreza WRX
Platinum Silver Metallic
Its probably from your up pipe, not the downpipe. Did you you use the 2.2K resistor for the EGT probe?
-Dan
If not, here is the link to what you need to do http://forums.nasioc.com/forums/show...ppipe+resistor
WRXturboAWD is offline   Reply With Quote
Old 09-26-2004, 02:21 AM   #6
dElKwOn
Member#: 71184
Chapter/Region: HIIC
2002 ewg'd vf-34'd
GDA AMS Tuned !
yup sure should try and put that resistor in the egt probe harness , had the perrin up-pipe it came with the resistor and the check engine light stayed off , until i put on an catless down pipe & got the bloody cat ineffieciny code . accessported the ecu and cel turned off .
dElKwOn is offline   Reply With Quote
Old 09-26-2004, 08:04 PM   #7
NvrEnuff
Member#: 66219
2004 WRX
www.ratemyshocker.com
I've got some issues with my exhaust insta;; as well...I have an Invidia TBE, catless; and a catless uppipe and downpipe. But I dont have the CEL fix in yet. I noticed my car is smoking, my mechanic says its too rich, can this be the case???
NvrEnuff is offline   Reply With Quote
check engine light question jlam86 Vancouver Impreza Club Forum -- VIC 7 11-28-2006 06:06 PM
check engine light question - 05 STi STIGuy116 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-16-2006 10:25 PM
2005 STi check engine light question STIGuy116 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 02-27-2006 07:40 PM
[B]Check Engine Light question regarding uppipe/downpipe[/B] Moshpit552 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-21-2004 02:36 AM
Check engine Light Question P1443 speedrkj Tri-State Area Forum 8 02-26-2003 07:39 PM
